Forum Topic - umount /dev/io-net/en1 with 6.3.2:
If I do umount /dev/io-net/en1 I get the following entry in slog that comes up every 5 sec (period_ticks is set to 10 )
lr_tk_pkt()  bad l4_index: 1
Is this something I should worry about?
- Mario
Re: umount /dev/io-net/en1 with 6.3.2
No.  The qnet resolver is trying to transmit on an L4
which no longer exists, because you unmounted it,
and is whining about it.  If it's swamping your slogger,
you can run qnet with the "no_slog=1" option, which
still allows qnet's internal event ringbuffer to work (see
cat /proc/qnetstats).
