Forum Topic - io-net on 6.3 taking a huge CPU Utilization (80%) over time:
We are running QNX 6.3 on x86 CPUs and using io-net with both TCP as well as QNET on a 8 node network out of which only
3 of them are QNX nodes that use QNET and the rest are non-qnx nodes using TCP. After running this system for 48+ hours,
 we suddenly see the io-net taking close to 70% of CPU and then take more and hang the total system. Any idea as to what
 might cause the io-net to be such a hog.
Re: io-net on 6.3 taking a huge CPU Utilization (80%) over time
Using the instrumented kernel and taking a system profile will show if
there's an external application that's interacting with io-net, causing it
to run ready.  Another possibility that comes to mind is a bad driver
which isn't releasing memory or is otherwise behaving incorrectly.  Make
sure that you have a shell that's running at a high priority (> 21) so that
you can still access the system if io-net consumes all CPU.
For io-net to be consuming CPU, I would expect it to be either sending
packets continuously or receiving packets continuously.  Have you
checked to see what your network traffic looks like using some sort
of network sniffer?
What type of network card are you using?
Is there any information from sloginfo may be helpful?
What does nicinfo report in terms of statistics?
What are the command line options that you pass to io-net?
Are you running io-net with any customized code (filters etc.)?
Does this happen on all three nodes or only one of them?
What does the memory usage on the system look like?  Does io-net's
memory consumption increase with time (pidin -p io-net mem)?
(Lots of questions :->).
    Robert.
