Re: Brainteaser #1 (multi-threaded NetBSD drivers)
11/26/2007 12:39 PM
post2939
On Sun, Nov 25, 2007 at 07:51:33PM -0500, Ralf GB wrote:
> "How do you make a NetBSDdriver operate in a multi-threaded mode? (Code
> snippet required.)"
> I did a diff between the original NetBSD drivers and the ones under
> sys/dev/ic/. The notes in sys/dev/doc/port_bsd.txt were also quite
> helpful.
> In order to port a NetBSD driver one has to sprinkle NW_SIGLOCK() and
> NW_SIGUNLOCK() throughout the source because the interrupt handler is
> atomic under NetBSD but can be interrupted under QNX.
> For the two drivers I looked into (i82557.c, rt2560.c) the function
> xxx_start() has to be called with the lock held.
> Making a NetBSD driver multi-threaded can be achieved by changing the
> call to
> pci_intr_establish(pc, ih, IPL_NET, fxp_intr, sc);
> to
> pci_intr_establish_exten(pc, ih, IPL_NET, fxp_intr, sc, 0);
> Take a look at pci_conv_qnx.c, line 450:
> void *
> pci_intr_establish(pci_chipset_tag_t pc, pci_intr_handle_t ih, int
> level,
> int (*func)(void *), void *arg)
> * By default the porting lib throws IRUPT_NOTHREAD
> * which will pare the stack down to single threaded
> * pulse mode. If you're sure the driver in question
> * does all the right things WRT locking, use
> * pci_intr_establish_exten().
> return pci_intr_establish_exten(pc, ih, level, func, arg,
> IRUPT_NOTHREAD);
> BUT: As the comment above says: One has to make sure locking is correct!
> Is this the code snippet you have in mind?
A+ from me.
