Forum Topic - io-net behavior with multiple cells: (3 Items)
Hi
I have a system where io-net modules are arranged as follows:
cell 1, endpoint 0: ethernet up producer (responsible for interfaces en0 & en1)
cell 1, endpoint 1: ethernet up producer (responsible for interface en2)
cell 2, endpoint 0: ppp up producer ( responsible for interface ppp0)
                             Same module registers IP-PPP convertor module to io-net
Question:
How does stack determine which packets need to go through ppp interface? I ask this because my route table (shown below) is unable to explain this to me!
For example, if i ping 10.10.13.13 using example below, i do not know how stack determines that ppp0 is the correct outgoing interface.
When is the interface ppp0 (for that matter any other interface) is created? Is this when driver registers to io-net? so any ifconfig commands on that interface works only after driver has registered, right?
Any pointer to detailed explanation of what happens during io-net registration will be very helpful?
Regards
VG
ifconfig output
ifconfig
lo0: flags=8009<UP,LOOPBACK,MULTICAST> mtu 33212
	capabilities=7<IP4CSUM,TCP4CSUM,UDP4CSUM>
	enabled=0<>
en0: flags=842<BROADCAST,RUNNING,SIMPLEX> mtu 1500
	address: 00:40:43:32:87:f8
en1: flags=843<UP,BROADCAST,RUNNING,SIMPLEX> mtu 1500
	address: 90:70:20:01:88:00
	inet 10.118.209.171 netmask 0xffffff00 broadcast 10.118.209.255
ppp0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> mtu 1500
	address: 00:e0:00:00:e0:00
	inet 192.168.253.145 netmask 0xffffffc0 broadcast 192.168.253.191
	inet alias 10.10.12.13 netmask 0xffffff00 broadcast 10.10.12.255
en2: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> mtu 1500
	address: 00:40:43:15:03:cb
	inet 192.168.255.126 netmask 0xffffff80 broadcast 192.168.255.127
	inet alias 192.168.255.125 netmask 0xffffff80 broadcast 192.168.255.127
route show output
Destination      Gateway            Flags
default          10.118.209.1       UG
10.10.12.0       10.10.12.13        U
10.10.12.13      10.10.12.13        UH
10.10.13.13      10.10.13.13        UH
10.118.209.0     link#3             U
10.118.209.1     0:f:34:2b:64:c7    UH
10.118.209.103   0:15:17:b9:bb:f4   UH
10.118.209.106   0:21:9b:6d:90:e4   UH
10.118.209.171   90:70:20:1:88:0    UH
127.0.0.1        127.0.0.1          UH
192.168.253.128  192.168.253.145    U
192.168.253.145  192.168.253.145    UH
192.168.255.0    link#5             U
192.168.255.1    1a:70:1f:37:9:18   UH
192.168.255.126  0:40:43:15:3:cb    UH
255.255.255.255  10.118.209.171     UG
Re: io-net behavior with multiple cells
On Wed, Jul 07, 2010 at 12:52:59PM -0400, Vineet Garg wrote:
> Hi
> Question:
outgoing interface.
If you look at the output from 'netstat -rn' there's probably an
interface associated with that route (ppp0).
Correct.
Hi Sean
Is it possible that netstat -rn shows a route that is not seen in output of
"route show" ?
Another important to mention here is that i have not created any manual
route to accomplish this interface selection.
Can stack somehow automatically determine that a route towards this IP lies
on ppp0?
Regards
Vineet
On Wed, Jul 7, 2010 at 10:42 PM, Sean Boudreau <community-noreply@qnx.com>wrote:
> > Hi
> & en1)
> module to io-net
> > Question:
> me!
> Correct.
> Technology
> http://community.qnx.com/sf/go/post58853
