Forum Topic - Bulk udp read:
Bulk udp read
When doing read() on a datagram stream, each read() return one packet.  Is there any way to read multiple packets in a
single operation.
When receiving data from a GigE camera we get a packet every 30us.  Would like to cut down on the context switches.
Re: Bulk udp read
Yes, and this is expected and according to specs for UDP sockets. In
fact, when you think about it, you want to keep the packet boundaries,
so there isn't much option other than introducing new ancillary data
which tell you the boundaries or in-line data markers or length fields.
None of which are in the standard/de facto socket interface.
>    Is there any way to read multiple packets in a single operation.
Several choices come to mind. Perhaps using BPF which can return you
several packets in one read is an option, but you've got to check if you
can control the latency (how much it waits to bulk them up before giving
them). And because it's unprocessed directly from driver you'd have to
do some protocol work in your code. Or you can create your own custom
interface with the stack which bulk packets and package them with
boundary information according to your preference. Or, easiest might be
to use plain read(). But I'm not sure if it'll still return each packet
or not, I haven't tried, and you'll have to figure out a way to restore
your packet boundaries...
If the packets all have constant size, maybe that can help you with
Just ideas to try, but hope it helps...
/P
