Forum Topic - BOOTP & IP address asignemnt:
We needed a BOOTP client for our product, so I am writing one.  I have the process complete up until I assign the
information (IP address & etc) to the interface.
I am wondering if there is a graceful way to accomplish this assignment?
Looking at the DHCP client it looks like it prepares a script file and passes it off to some other app.
Would I be able to create a similar script file and pass it off to the same application?
If so, what is the app and what parameters could I have it set for me?
Or could you tell me where to find the code to look through to figure that out for myself?
Jared
Re: BOOTP & IP address asignemnt
I would have thought that the shipped DHCP client is backwards
compatible with BOOTP but maybe I'm misunderstanding what you're
attempting to do...
>    I have the process complete up until I assign the information (IP address&  etc) to the interface.
You're looking at the right spot for example how to configure IP address
etc. However, you may have missed the code that configures the IP
address. The DHCP client does have code for directly configuring the IP
address by itself (configure.c:ifconfig()), but it also passes
parameters to a script (dhcp-up, qnx_client.c:run_script()). Please see
the docs for the list of environment variables passed to this script:
http://www.qnx.com/developers/docs/6.4.1/neutrino/utilities/d/dhcp.client.html
Yes, you can create your own script. Not sure what you refer to as "same
application" though.
The idea is that you'd write your own script which implements your local
configuration policy.
HTH
/P
We actually need BOOTP & DHCP to run at the same time.  I also don't know if you can strip out the DHCP flag from the
options to get it to work with BOOTP servers.
Thank you for pointing out the location of the ip address assignment code and other options.  That is what I was looking
 for.
Jared
On 16/02/10 09:01 PM, Jared Roundy wrote:
> We actually need BOOTP&  DHCP to run at the same time.
That's odd. Maybe you can teach me about why and when that is necessary?
>    I also don't know if you can strip out the DHCP flag from the options to get it to work
with BOOTP servers.
Don't the servers that don't recognize the option simply ignore it?
looking for.
Ok, great, glad I got something right :-)
/P
