Re: difference between io-pkt-v4 and io-pkt-v4-hc when encryption
not used
02/11/2010 7:46 AM
post47115
not used
On Thu, Feb 11, 2010 at 03:18:09AM -0500, Andrew Sherk wrote:
> Customer is using io-pkt-v4-hc -p tcpip forward
> My understanding is that they are not needing any of these:
> IPv6
> Crypto / IPSec
> 802.11 a/b/g WiFi
> Bridging
> GRE / GRF
> Multicast routing
> Multipoint PPP
> Also, the target need not forward packets from one interface to another; only communication between two local
processes is required over the loopback device.
> If they run only "io-pkt-v4" instead of "io-pkt-v4-hc -p tcpip forward" what will be the difference be in CPU usage,
if any, however minimal?
There shouldn't be any difference in cpu usage.
