Forum Topic - Samba Client, and Server:
Hi, got two questions:
1) does QNX feature a samba client that support smb v4, to connect to Windows 2003 shares?
2) AFAIK there is no samba server in QNX. Is there one in pkgsrc?  I tried to find it, but it's so big, I didn't see it.
Any help would be appreciated.
- Malte
Re: Samba Client, and Server
Check out fs-cifs whcih ships with 6.4.x
AFAIK there are different authentification algorithms across various Windows versions. E.g. in older versions you do not
 need to specify a domain, and fs-cifs will try '*' as the domain, etc.
Does the 6.4.1 fs-cifs actually support mounting shared folders from a Windows 2003 server? The docs only mention
Windows NT 'or other SMB servers'.
- Malte
not need to specify a domain, and fs-cifs will try '*' as the domain, etc.
FWIW, I just used 6.4.1 fs-cifs to mount a shared folder on a Windows
2003 server.
Try yourself, and if you speak SMB then you can look at the packet
capture to see what dialects and domains etc are used...
Hope this helps you!
/P
>  versions. E.g. in older versions you do not need to specify a domain, and fs-
> Windows 2003 server? The docs only mention Windows NT 'or other SMB servers'.
> 2003 server.
> /P
Thanks Patrik!
it.
Did you check out the binary packages page?:
http://community.qnx.com/sf/wiki/do/viewPage/projects.pkgsrc/wiki/BinaryPackages
There's one here:
ftp://ftp.netbsd.org/pub/pkgsrc/packages/QNX/i386/6.4.1_head_20090724/All/
Or they should be able to build their own from pkgsrc/net/samba.
AFAIK fs-cifs should work as the client.
I'm not sure
/P
I'm not sure I understand your question because I'm not that familiar
with the details of the CIFS protocol. What is version 4?
Here's the documentation links in case that helps:
http://www.qnx.com/developers/docs/6.4.1/neutrino/utilities/f/fs-cifs.html
http://www.qnx.com/developers/docs/6.4.1/neutrino/user_guide/fsystems.html#CIFS
it.
That's correct, I don't know of a QNX CIFS/SMB server.
Please check the pkgsrc project on foundry. I believe there's net/samba.
Sorry I can't be of much more help.
/P
