Forum Topic - ifconfig, qnet, io-pkt:
I've encountered some interesting behavior that intertwines ifconfig/tcpip with qnet.
The qnet stack is running, but it is not going over tcp/ip.  If I do an ifconfig fxp0 down on the node, qnet traffic
appears to stop for a while, then begins again.
I noticed it when I did a
on -f node ifconfig down
qnet traffic stopped, but then after a few minutes came back up again.
I found a post where an IP address was being set with ifconfig that suggested the NIC may be reinitialized by this step.
Is this so?  Is there a way to prevent ifconfig from interfering with qnet?
Kevin
Re: ifconfig, qnet, io-pkt
step.
If a link is marked down it shouldn't be operational.
If qnet happens to work on it that's probably a bug
but it might happen with older io-net based drivers
via the shim.
RE: ifconfig, qnet, io-pkt
"If a link is marked down it shouldn't be operational.
via the shim."
Shouldn't ifconfig only work on the tcp/ip stack?  It is a tcp/ip
configuration tool, not a qnet configuration tool....
Kevin
> via the shim."
I don't think so. Qnet is a protocol that runs on
various link layers.  If the link is marked down
nothing, including qnet, should go over it.
