Forum Topic - if_attach return SIGABORT:
Hello All.
I've some difficulties with if_attach function :
On my HW, there are several network controlers that shall be initialised at the same time.
To do such, I dectect each ctrls and puts it's information in linked list.
To register my driver to the network stack, I need to call if_attach each time there are ctrls on my HW.
Basicaly, on my develepment system, I have 2 controlers.
Strange stuff : When I call 1 time with my first controler it register the device without any problem.
When I do an ifconfig I ca see my device registered.
When the second controler is registered, I'm catching a SIGABORT signal.
Attached, screenshot of debugger when it occurs.
Do you know why this append ?
Thank you very much.
Attachment: Image reveiving_SIGABORT.JPG 2.83 MB
Re: if_attach return SIGABORT
I get those messages on slogger :
Feb 01 06:08:30    1    14     0 if_attach: ex_init: 16
Feb 01 06:08:30    5    21     0 run fault pid 622635 tid 2 signal 6 code 0 ip 0xb033b879 tmp/io-pkt-v4-
hcgvarlet124360136316929
pthread_mutex_init() returned EBUSY:
EBUSY
	The given mutex was previously initialized and hasn't been
        destroyed.
You need to use a separate struct ifnet for each interface.
On Fri, May 29, 2009 at 06:24:30AM -0400, Guillaume Varlet wrote:
> Hello All.
The stack probably panic()'d.  Check the sloginfo for
more information.  BTW the source for the stack is
in the networking repo in this project.
