Forum Topic - unable to init devnp-shim.so: unknown error:
Hello.
I recently upgraded from 6.3.2 to 6.4.0 and i have to use io-pkt instead of io-net. I use a Freescale MPC5200 Lite Board
 and the most recent BSP.
Using io-net i used following line and everything worked fine:
io-net -dmpc5200 mac=xxxxxxxxx,verbose -ptcpip
Now with io-pkt, this is the line:
io-pkt-v4-hc -d shim "lib/dll/devn-mpc5200.so" -v -ptcpip mac=xxxxxxxxxx
I entered the full address of the library because i thought that might help, i also tried without the path.
The libraries that i need are included (devnp-shim.so and devn-mpc5200.so).
During the boot, this is the message that i get:
If I use this command:
io-pkt-v4-hc -dmpc5200 -v -ptcpip mac=xxxxxxxxxx
The error message changes to:
unable to init devn-mpc5200.so: unknown error
Does anybody know a solution?
What further information do you need?
Re: unable to init devnp-shim.so: unknown error
On Wed, Dec 17, 2008 at 08:37:41AM -0500, Peter Fischer wrote:
> Hello.
Board and the most recent BSP.
Try this:
io-pkt-v4-hc -dmpc5200 mac=xxxxxxxxxx
Thank you for the help.
Your line is right, I works now.
