Forum Topic - imx27:Ethernet issue:
I am working with i.mx27. I ported qnx and serial port is enabled. Now i
try to enable the ethernet. As it has FEC, i enabled the relative script
in build file and i get the display
Welcome to Neutrino on the Freescale MX27ADS (ARM 926 core) Board
Starting ethernet driver ...
But when i try to ping it with other local system, it displays
# ping local ip addrs
PING ..................................... : 56 data bytes
ping: sendto: No route to host
Referring TCP/IP document's Troubleshooting part, i was able to get
io-net and drivers running in my system, display
# pidin -p io-net mem
     pid tid name               prio STATE           code  data
stack
       5   1 proc/boot/io-net    10r SIGWAITINFO       76K  544K
8192(132K)*
       5   2 proc/boot/io-net    21r RECEIVE           76K  544K  4096(132K)
       5   3 proc/boot/io-net    10r RECEIVE           76K  544K   4096(68K)
       5   4 proc/boot/io-net    10r RECEIVE           76K  544K   4096(68K)
       5   5 proc/boot/io-net    20r RECEIVE           76K  544K  4096(132K)
            libc.so.2          @ 1000000             408K   12K
            devn-mcimx27.so    @ 106a000              40K  8192
            npm-tcpip-v4.so    @ 1076000             324K   20K
            proc/boot/io-net   @   fe000 (       0)        8192
            proc/boot/io-net   @ 1069000 (       0)        4096
When i try to get my server information and map hostname to ip address
using
cat /etc/resolv.conf and
cat /etc/hosts
It display /etc/... ... no such file or directory
# cat /etc/resolv.conf
/etc/resolv.conf: No such file or directory
# cat /etc/host
/etc/host: No such file or directory
# netstat -in
sh: netstat: not found
Can anyone help me in resolving this problem.
Thank u
*/Regards,/*
/V.Murugadoss
We recently installed the spam filter from Abaca. It's over 99% accurate.
Check it out - http://www.abaca.com/promo.htm?domain=gdatech.co.in
Re: imx27:Ethernet issue
> stack
> 8192(132K)*
> using
> cat /etc/hosts
> # cat /etc/host
> # netstat -in
> Thank u
> */Regards,/*
> /V.Murugadoss
answered here:
http://community.qnx.com/sf/discussion/do/listPosts/projects.bsp/discussion.bsp.topc3534
