Forum Topic - when does the iface_hook() gets invoked:
   In io-pkt implementation , when does the iface_hook gets invoked. I mount the filter and I see the input hook and
output hook get invoked as a when packets come in and go out of stack. But I am unable to see the message I have put in
when the iface_hook is added.
If I am not wrong this gets invoked when the filter module attaches to the driver ethernet driver module.
I do not see this happening.
I am just executing the sample code.
Can anyone please put in the right direction?
Regards
Vinod
Re: when does the iface_hook() gets invoked
On 13/01/10 08:20 PM, Vinod Kolapuram wrote:
The PFIL_IFNET hook is invoked when the interface is attached (created)
or detached (destroyed).
>   I mount the filter and I see the input hook and output hook get invoked as a when packets come in and go out of
stack. But I am unable to see the message I have put in when the iface_hook is added.
You probably loaded the filter after the interface was created.
Hope this helps!
/P
Hi Patrik,
              Well that is my question. When you say the interface is attached to which interface are you referring. My
ethernet driver has to be mounted even before my filter gets mounted right?
My question is how to exercise my attach functionality and why doesn't the pfil filter module get attached to the active
 ethernet driver.
Regards
Vinod
I'm sorry, I don't really understand where the misunderstanding is. If
anybody else knows, please jump in!
Please see below...
The network interface, e.g. en0 or wm0. What you create by loading a
devn-/devnp- network driver with correct parameters and which you remove
by calling ifconfig <ifname> destroy. In stack terminology this leads to
"attaching" and "detaching" the interface respectively.
Maybe the confusion is with these terms vs. the pf API which uses terms
"attach" and "detach" interface hooks? It's because they too refer to
the same event happening in the stack when they're called.
>   My ethernet driver has to be mounted even before my filter gets mounted right?
I don't think there's a requirement that one loads before the other.
active ethernet driver.
I'm afraid I don't understand what you mean here.
As I wrote before, "The PFIL_IFNET hook is invoked when the [network]
interface is attached (created) or detached (destroyed)." I.e. if you've
already loaded the network driver, then the network interface has likely
already been created and the PFIL_IFNET hook will be called for it until
the it is destroyed.
I'm hoping the above will help, if not then here's a good wiki page on
the topic:
http://community.qnx.com/sf/wiki/do/viewPage/projects.networking/wiki/Filtering_wiki_page
/P
Hi Patrik,
              I have added some log messages on each function of the sample pfil filter code which you are reffering to.
 I even have one message when the interface is attached or detached.
My question is, in my case when the pfil filter module is mounted manually with mount command from the shell, by then
already the ethernet driver is loaded and available.
Do you mean to say the pfil hook interface is attached to the ethernet driver when I mount the pfil filter module
Or
the pfil hook interface is yet to be attached to the driver. If it is yet to be attached, then how do I attach my pfil
filter module to the ethernet driver. Only then it makes sense to extract the stack data.
I just posted one more question please respond to that.
Vinod
Hi Vinod:
I think that the confusion is coming from the fact that the pfil hook attaches itself to the stack (above the driver
interface), and not into a driver .
The iface hook will get invoked when an ethernet interface is either added into the stack (mounted) or removed from the
stack (destroyed).   There doesn't have to be any driver interface present when you load in the pfil hook.
The sample code does something a bit peculiar in that it detaches itself as soon as any interface is destroyed.  This
was just a convenient mechanism for showing how to remove the pfil hook and not representative of any standard way of
operating.
The ifacecfg hook will get called if you re-configure any interface (e.g. by bringing any interface up or down).
   Robert.
> Hi Vinod:
>  itself to the stack (above the driver interface), and not into a driver .
> into the stack (mounted) or removed from the stack (destroyed).   There
Robert Can you please help me find in QXN boot up sequence as I want to mount my pfil filter module before the ethernet
driver is loaded. I think its in some rc files. Please let me know where to change the sequence
> soon as any interface is destroyed.  This was just a convenient mechanism for
>  of operating.
Can I reconfigure the ethernet driver devn-i82544.so. I mean its running under io-pkt and I think the driver cannot me
unmounted in io-pkt.
>    Robert.
Vinod
On 14/01/10 07:26 PM, Vinod Kolapuram wrote:
>> Hi Vinod:
ethernet driver is loaded. I think its in some rc files. Please let me know where to change the sequence
You're in control of this (at least the parts that are discussed in this
context). You can create your own script inside an image. But I'm
assuming from your earlier questions that you are using a standard PC
install, in which case you have several options, e.g. can change the
enum scripts or slay the stack in rc.local and restart it with the
drivers and lsms in the order you want... The latter is probably easiest.
>>   of operating.
I don't understand what you're asking, it doesn't make sense.
Reconfigure and unmount are two different things.
/P
On 14/01/10 05:25 PM, Robert craig wrote:
> Hi Vinod:
Yes, thanks Robert,
I see that it makes sense that this was where the confusion was coming
from...
/P
On 14/01/10 03:53 PM, Vinod Kolapuram wrote:
> Hi Patrik,
to. I even have one message when the interface is attached or detached.
Yes, the ethernet driver is already loaded an the network interfaces it
creates are already created. Hence when you load the example filter the
stack won't call any PFIL_IFNET hooks for creation of interface since
the interface already exists.
> Or
The pfil hook interface is to the stack, not the driver. Your example
pfil code is registering hooks with the stack not the driver.
Sure, I'll try my best :-)
PS. If you need prompt support then please go through the appropriate
QNX support channels. We're a community here and everyone here makes
every attempt to help on their own time but sometimes there's a lot to
do... :-)
Hope we'll get this cleared out, have a good weekend!
/P
