Forum Topic - qconn doesnt work after migration:
    I've just migrated the kernel from 6.3.2 to 6.4.1(QNX momentics ide 4.6.0), and re-coded the network driver which is
 a native io-pkt driver.
    Host(windows) and target(arm9) can “ping" each other. But when I want to debug an application via qconn, I found
that IDE cant connect to the target. Then I telnet the qconn port (8000) to the target under windows, cant connect too.
    I made a tcpdump, shows that target gets the "qconn request packet"(used the wireshark to check out what the qconn
request packet is like...), but driver doesnt tx any packets, it seems the protocol stack doesnt make any response to
that request.
    Q:
Is the qconn shipped with momentics 4.6.0 compatible with the new io-pkt framework? Should I add any other libaries to
image besides libsocket?
# netstat
Active Internet connections
Proto Recv-Q Send-Q  Local Address          Foreign Address        State
tcp        0      0  *.8000                 *.*                    LISTEN
udp        0      0  *.*                    *.*
# pidin -p qconn
     pid tid name               prio STATE       Blocked
    4103   1 sbin/qconn          10r SIGWAITINFO
    4103   2 sbin/qconn          10r CONDVAR     (0x120bc0)
    4103   3 sbin/qconn          10r RECEIVE     1
    4103   4 sbin/qconn          10r RECEIVE     3
# pidin -p qconn fd
     pid name
    4103 sbin/qconn
           0       4 rw        0 /dev/ser1
           1       4 rw        0 /dev/ser1
           2       4 rw        0 /dev/ser1
           3       5 rw        0 I4TCP  *.8000                *.*                   LISTEN
           4    4103
           0s      1
           2s      1 MP        0 /dev/dbgmem
           4s      1 MP        0 /dev/profiler
attachment's my build file
Attachment: Text s3c2440.build 12.75 KB
Re: qconn doesnt work after migration
Yes, qconn should work with io-pkt. And AFAIK if qconn starts then all
libs it needs must be available. What other programs it might need
depends on what you're doing, e.g. I believe pdebug is necessary on the
target for debugging with the IDE. Looks like you've got that though.
(Just check that it's available in qconn's path?)
Can you connect to any other TCP service on the target? E.g. telnetd,
sshd? What about UDP or raw IP? Does anything work?
What do the driver stats and the stack stats say? (nicinfo and netstat
-p ip/tcp)
Is there another driver you can try with and see if that works? E.g.
your original devn (io-net) driver?
Hope this may help!
/P
   thanks a lot for early reply, Patrik
   With your help,I found something wrong...
>-p ip/tcp)
# nicinfo
dm0:
  DM9000 Ethernet Controller
  Physical Node ID ........................... 000000 000000
  Current Physical Node ID ................... 111213 141516
  Current Operation Rate ..................... 100.00 Mb/s full-duplex
  Active Interface Type ...................... MII
    Active PHY address ....................... 0
  Maximum Transmittable data Unit ............ 1500
  Maximum Receivable data Unit ............... 1500
  Hardware Interrupt ......................... 0x6b
  Memory Aperture ............................ 0x1800300 - 0x18003ff
  Packets Transmitted OK ..................... 3
  Bytes Transmitted OK ....................... 126
  Broadcast Packets Transmitted OK ........... 0
  Multicast Packets Transmitted OK ........... 0
  Memory Allocation Failures on Transmit ..... 0
  Packets Received OK ........................ 318
  Bytes Received OK .......................... 24468
  Broadcast Packets Received OK .............. 0
  Multicast Packets Received OK .............. 318
  Memory Allocation Failures on Receive ...... 0
  Single Collisions on Transmit .............. 0
  Multiple Collisions on Transmit ............ 0
  Late Collision on Transmit errors .......... 0
  Transmits aborted (excessive collisions) ... 0
  Transmit Underruns ......................... 0
  No Carrier on Transmit ..................... 0
  Receive Alignment errors ................... 0
  Received packets with CRC errors ........... 0
  Packets Dropped on receive ................. 0
  Short packets .............................. 0
  Total Frames experiencing Collison(s) ...... 0
# netstat -p ip/tcp
netstat: ip/tcp: unknown or uninstrumented protocol
But isnt tcpip the default protocol of io-pkt???
why the protocol isnt up?
RE: qconn doesnt work after migration
># nicinfo
Please set the first byte of your mac address to be zero instead
of 0x11, because you have accidentally set the multicast bit
in a unicast address.
There's a better way to generate a mac address, if you're
going to use this on a larger network.
aboyd
Re: RE: qconn doesnt work after migration
> ># nicinfo
> aboyd
Thank a lot and a lot , Andrew.
It works! I didnt know that mac address has such a rule....
I see Andrew already spotted the problem for you, but for anybody
listening, here you see that all the packets you received were treated
as multicasts (because of that MAC address).
/P
sorry, i typed a bad command just now...
now here's what i got:
# netstat -p ip
ip:
        38 total packets received
        0 bad header checksums
        0 with size smaller than minimum
        0 with data size < data length
        0 with length > max ip packet size
        0 with header length < data size
        0 with data length < header length
        0 with bad options
        0 with incorrect version number
        0 fragments received
        0 fragments dropped (dup or out of space)
        0 fragments dropped (out of ipqent)
        0 malformed fragments dropped
        0 fragments dropped after timeout
        0 packets reassembled ok
        38 packets for this host
        0 packets for unknown/unsupported protocol
        0 packets forwarded (0 packets fast forwarded)
        0 packets not forwardable
        0 redirects sent
        0 packets no matching gif found
        0 packets sent from this host
        0 packets sent with fabricated ip header
        0 output packets dropped due to no bufs, etc.
        0 output packets discarded due to no route
        0 output datagrams fragmented
        0 fragments created
        0 datagrams that can't be fragmented
        0 datagrams with bad address in header
# netstat -p tcp
tcp:
        0 packets sent
                0 data packets (0 bytes)
                0 data packets (0 bytes) retransmitted
                0 ack-only packets (0 delayed)
                0 URG only packets
                0 window probe packets
                0 window update packets
                0 control packets
                0 send attempts resulted in self-quench
        18 packets received
                0 acks (for 0 bytes)
                0 duplicate acks
                0 acks for unsent data
                0 packets (0 bytes) received in-sequence
                0 completely duplicate packets (0 bytes)
                0 old duplicate packets
                0 packets with some dup. data (0 bytes duped)
                0 out-of-order packets (0 bytes)
                0 packets (0 bytes) of data after window
                0 window probes
                0 packets received after close
                0 discarded for bad checksums
                0 discarded for bad header offset fields
                0 discarded because packet too short
        0 connection requests
        0 connection accepts
        0 connections established (including accepts)
        0 connections closed (including 0 drops)
        0 embryonic connections dropped
        0 delayed frees of tcpcb
        0 segments updated rtt (of 0 attempts)
        0 retransmit timeouts
                0 connections dropped by rexmit timeout
        0 persist timeouts (resulting in 0 dropped connections)
        0 keepalive timeouts
                0 keepalive probes sent
                0 connections dropped by keepalive
        0 correct ACK header predictions
        0 correct data packet header predictions
        0 PCB hash misses
        0 dropped due to no socket
        0 connections drained due to memory shortage
        0 PMTUD blackholes detected
        0 bad connection attempts
        0 SYN cache entries added
                0 hash collisions
                0 completed
                0 aborted (no space to build PCB)
                0 timed out
                0 dropped due to overflow
                0 dropped due to bucket overflow
                0 dropped due to RST
                0 dropped due to ICMP unreachable
                0 delayed free of SYN cache entries
        0 SYN,ACKs retransmitted
        0 duplicate SYNs received for entries already in the cache
        0 SYNs dropped (no route or no space)
        0 packets with bad signature
        0 packets with good signature
        0...
it seems tcp received the request. why doesnt the qconn socket accept the request? It's just listening peacefully,but
does nothing...
