Forum Topic - Does shim driver work with Filter/converter module?: (3 Items)
        I want to know if the shim driver which is used for backward compatibility to use with io-net NIC driver from
QNX6.4 under io-pkt, is workable even for the filter/converter module.
I am porting the filter module from io-net to io-pkt. If this shim driver works for filter/converter module then I can
try using the shim driver.
I have browsed through the forum and internet for porting related info but was able to find an example of using the pfil
 hook to access mbuf  at
http://www.qnx.com/developers/docs/6.4.1/io-pkt_en/user_guide/migrating.html
Can anyone please give me some more input on using mbuf so that I can straight away convert to iov type or point me to
some example in BSD implementation, which at least reduces my effort in understanding.
Regards
Vinod
Re: Does shim driver work with Filter/converter module?
Hi Vinod:
   The shim layer only provides compatibility for the driver interface.  The filter / converter interface is in the
stack, so the shim layer won't do anything for you.  There's more information on io-pkt filters located here:
http://community.qnx.com/sf/wiki/do/viewPage/projects.networking/wiki/Filtering_wiki_page
And a good (if complicated) example is here:
http://community.qnx.com/integration/viewvc/viewvc.cgi/trunk/lib/io-pkt/sys/lsm/nraw/?root=core_networking&system=
exsy1001
You can also look at how mbufs and npkts are converted by taking a look in the shim layer here:
http://community.qnx.com/integration/viewvc/viewvc.cgi/trunk/lib/io-pkt/sys/dev_qnx/shim/io-net.c?revision=1&root=
core_networking&system=exsy1001&view=markup
(look for npkt2mbuf and mbuf2npkt).
Still a large learning curve, but I hope this helps,
    Robert.
Thanks Robert.
I have one more question. In my posting I have included a link of the sample code (example of adding a hook and removing
 a hook and the entry function etc.)  for io-pkt. This code when compiled gives me errors for all the pfil calls, like
pfil_get_get(), pfil_add_hook(), pfil_remove_hook() etc. Do I have to include any library. I am building this on QNX6.4.
0. I have all the header files needed for io-pkt.
I get an error saying the above pfil calls "was not declared in this scope".
Can you please let me know if I have to include any libs
Vinod
