Forum Topic - Is it possible for io-pkt to release (purge) open socket file descriptors?:
Hi I'm chasing an odd problem.
Here's a snippet of code:
    tempFD = socket( PacketFamily, SOCK_STREAM, 0 );
    setsockopt( tempFD, SOL_SOCKET, SO_REUSEADDR, (char *) &one,
sizeof(int));
    bindReturn = bind( tempFD,  (struct sockaddr *) &sock,
sizeof(sock));
   if ( listen( tempFD, backlog) == 0)
       while( ! tc_is_shutdown() )
          FD_ZERO( &readSet );
          FD_SET( tempFD, &readSet );
          timeout.tv_sec = 1;
          timeout.tv_usec = 0;
          result = select( tempFD + 1, &readSet, 0, 0, &timeout );
          if (result == -1)
             break;
          else if (result == 0)
             if ( tc_is_shutdown() )
                 break;
             else
                 continue;
          if ( ! FD_ISSET( tempFD, &readSet ) )
              continue;
          ses_handle = accept( tempFD, ( struct sockaddr *)&sock, &len);
          if (setsockopt(ses_handle, SOL_SOCKET, SO_RCVTIMEO,
(char*)&tcptimeout, tcptimeoutLen) == -1)
            perror("Set SO_RCVTIMEO: FAILED")
          <more stuff here>
Well, I've had a failure report come my way which pretty much indicates
the following: the setsockopt() after the accept() returned a failure
which indicated that the File Descriptor was invalid.
Question:  under what circumstances would the io-pkt stack purge it's
current file descriptor list (if ever)?
Maurice Gibbs
Software Designer
CommTest WaveReady BU
JDS Uniphase Corp.
613.843.2326
Re: Is it possible for io-pkt to release (purge) open socket file descriptors?
> sizeof(int));
> sizeof(sock));
>           timeout.tv_sec = 1;
>           if (result == -1)
>              break;
>                  break;
>              else
>                  continue;
>               continue;
>           <more stuff here>
It depends on the errno from setsockopt().  You should also
check the return from accept().
It should never do that.
