Forum Topic - Reg - How the packet will going to application:
In the network driver, once gets the packets from the hardware.
it calls the ( ifp->if_input() ) function to send the packet to the stack.
How the stack will process the packet and give to application.
tell with aby example.
1.ip_input or ether_input
Please exaplain the code flow because i m not able to understand the code.
Thanks and Regards
K.Senthil
Re: Reg - How the packet will going to application
On Mon, Jul 27, 2009 at 03:35:34AM -0400, Senthil K wrote:
If it's an ethernet driver ifp->if_input() should
point to ether_input().  ether_input demux's based
on the ethertype and may call ip_input().
It will go to ip_input(),there they called schednetisr() function,after that how the packets reaches to the application.
For ex ping application.
How the ping utility will get the packet from the ip_input function.
Thanks and Regards
K.Senthil
On Tue, Jul 28, 2009 at 02:10:05AM -0400, Senthil K wrote:
application.
further in the input process soreceive() will be called which will
queue the packet on a socket buffer, wakeup() a blocked message pass
context which in turn will MsgReply to the application.  Compiling
a debug variant and firing up gdb may help here.
HI Sean,
In wakeup() function.
is there is no MsgReply function call.
Can you please explain from wake up function how it will reaches to application.
Thanks and Regards
K.Senthil
On Wed, Jul 29, 2009 at 06:50:14AM -0400, Senthil K wrote:
> HI Sean,
wakeup() wakes up a context blocked in ltsleep()
(sbwait() calls ltsleep() under the covers).  So
a context blocked waiting for data to queue in
a socket buffer will wake up in this manner.
