How to find out if that's a HW fault?
05/02/2009 9:21 AM
post28560
Hi
In one of customer installations on 6.3.0SP3 after some time EN1 interface drops offline (not actually offline, but
loses all communications) while EN0 remains still operational. After rebooting everything works well again. Both
interfaces are integrated on motherboard and are handled by a single io-net process. Is there a way to tell for sure
what's happening there (if it's a hardware or software fault)?
The machine is kept running, so that I'll be able to request for additional info on Monday if necessary. Here's
something to start with.
The symptoms are the same before: EN1 stops responding to both TCP/IP and QNET. EN0 is still active and functioning. I
was able to grab the following info for you:
# nicinfo /dev/io-net/en1
INTEL 82544 Gigabit (Copper) Ethernet Controller
Physical Node ID ........................... 003048 B037CB
Current Physical Node ID ................... 003048 B037CB
Current Operation Rate ..................... 100.00 Mb/s full-duplex
Active Interface Type ...................... MII
Active PHY address ....................... 0
Maximum Transmittable data Unit ............ 1514
Maximum Receivable data Unit ............... 0
Hardware Interrupt ......................... 0xb
Memory Aperture ............................ 0xd0200000 - 0xd021ffff
Packets Transmitted OK ..................... 16489506
Bytes Transmitted OK ....................... 1550295660
Broadcast Packets Transmitted OK ........... 27233
Multicast Packets Transmitted OK ........... 0
Memory Allocation Failures on Transmit ..... 0
Packets Received OK ........................ 16603917
Bytes Received OK .......................... 1545543297
Broadcast Packets Received OK .............. 57710
Multicast Packets Received OK .............. 0
Memory Allocation Failures on Receive ...... 0
Single Collisions on Transmit .............. 0
Deferred Transmits ......................... 7
Late Collision on Transmit errors .......... 0
Transmits aborted (excessive collisions) ... 0
No Carrier on Transmit ..................... 0
Receive Alignment errors ................... 0
Received packets with CRC errors ........... 0
Packets Dropped on receive ................. 11905
# /sbin/ifconfig
lo0: flags=8009<UP,LOOPBACK,MULTICAST> mtu 33212
capabilities=7<IP4CSUM,TCP4CSUM,UDP4CSUM>
enabled=0<>
en0: flags=8c43<UP,BROADCAST,RUNNING,OACTIVE,SIMPLEX,MULTICAST> mtu 1500
enabled=0<>
address: 00:30:48:b0:37:ca
inet 192.168.1.70 netmask 0xffffff00 broadcast 192.168.1.255
en1: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> mtu 1500
enabled=0<>
address: 00:30:48:b0:37:cb
inet 192.168.10.44 netmask 0xffffff00 broadcast 192.168.10.255
# pci
PCI version = 3.00
Class = Display (VGA)
Vendor ID = 8086h, Intel Corporation
Device ID = 2972h, Integrated Graphics Controller
PCI index = 0h
PCI Mem Address = d0000000h enabled
PCI Mem Address = c0000000h enabled
PCI IO Address = 30c0h enabled
PCI Int Pin = INT A
Interrupt line = 10
CPU Interrupt = ah
Class = Mass Storage (IDE)
Device ID = 27c0h, 82801GB/GR/GH (ICH7 Family) Serial ATA Storage Controller IDE
PCI index = 0h
PCI IO Address = 0h enabled
PCI IO Address = 30b0h enabled
PCI Mem Address = ffeffc00h enabled
PCI Int Pin = INT B
Interrupt line = no connection
Class = Network...
Re: How to find out if that's a HW fault?
05/04/2009 7:48 AM
post28592
As an update I would like to say that this seems to be a driver fault. Today we tried it on backup hardware and EN1
still dies.
Here is some io-net data as well.
# pidin -p 77835 mem
pid tid name prio STATE code data stack
77835 1 sbin/io-net 10o SIGWAITINFO 64K 5964K 8192(516K)*
77835 2 sbin/io-net 10o RECEIVE 64K 5964K 4096(132K)
77835 3 sbin/io-net 10o RECEIVE 64K 5964K 4096(68K)
77835 5 sbin/io-net 10o RECEIVE 64K 5964K 4096(68K)
77835 6 sbin/io-net 21o RECEIVE 64K 5964K 4096(132K)
77835 7 sbin/io-net 21o RECEIVE 64K 5964K 4096(132K)
77835 8 sbin/io-net 20o RECEIVE 64K 5964K 4096(132K)
77835 9 sbin/io-net 20o RECEIVE 64K 5964K 4096(132K)
77835 11 sbin/io-net 10o RECEIVE 64K 5964K 4096(68K)
77835 12 sbin/io-net 10o RECEIVE 64K 5964K 4096(68K)
ldqnx.so.2 @b0300000 348K 20K
npm-tcpip.so @b8200000 276K 32K
devn-i82544.so @b824d000 36K 4096
npm-qnet.so @b8257000 160K 36K
/dev/mem @40100000 (d0100000) 128K
/dev/mem @40120000 (d0200000) 128K
Io-net is started by hardware autodetect scripts and then qnet is mounted in with custom parameters. These parameters
can vary depending on configuration settings available to user. The defaults (which I believe are used there) are
periodic_ticks=50,conn_est_timeout=10,conn_est_retries=1,conn_up_idle=10,conn_up_retries=10,tx_ticks=1,tx_retries=200,
do_crc=1,res_retries=0,probe_no_l4_time=500,slow_mode=12000,auto_add=1500
Also, here is binaries identification information
# ls -l /lib/dll/npm-tcpip.so
lrwxrwxrwx 1 root root 15 Jan 27 01:16 /lib/dll/npm-tcpip.so -> npm-tcpip-v4.so
# ls -l /lib/dll/npm-tcpip-v4.so
-rwxrwxr-x 1 root root 299788 Jun 05 2006 /lib/dll/npm-tcpip-v4.so
# cksum /lib/dll/npm-tcpip-v4.so
945232789 299788 /lib/dll/npm-tcpip-v4.so
# ls -l /lib/dll/npm-qnet.so
lrwxrwxrwx 1 root root 19 Jan 27 01:16 /lib/dll/npm-qnet.so -> npm-qnet-l4_lite.so
# ls -l /lib/dll/npm-qnet-l4_lite.so
-rwxrwxr-x 1 root root 175620 Jun 21 2006 /lib/dll/npm-qnet-l4_lite.so
# cksum /lib/dll/npm-qnet-l4_lite.so
283215240 175620 /lib/dll/npm-qnet-l4_lite.so
# ls -l /lib/dll/devn-i82544.so
-rwxrwxr-x 1 root root 39420 Aug 30 2007 /lib/dll/devn-i82544.so
# cksum /lib/dll/devn-i82544.so
3741020423 39420 /lib/dll/devn-i82544.so
I would be grateful for any suggestions.
> drops offline (not actually offline, but loses all communications) while EN0
> process. Is there a way to tell for sure what's happening there (if it's a
> info on Monday if necessary. Here's something to start with.
> . EN0 is still active and functioning. I was able to grab the following info
> for you:
> Current Operation Rate ..................... 100.00 Mb/s...
RE: How to find out if that's a HW fault?
05/04/2009 9:06 AM
post28597
After considerable effort on Hugh Brown's part, intel
discovered that some i82544 variants have a hardware
bug where they can lose interrupts during certain
race conditions. Oops.
Later versions of the i82544 drivers (both io-net
and io-pkt variants) have fixes to work around this
bug.
What is your DID?
aboyd
05/04/2009 9:08 AM
post28598
> From: Andrew Boyd [mailto:community-noreply@qnx.com]
> Sent: May-04-09 9:07 AM
> To: general-networking
> Subject: RE: How to find out if that's a HW fault?
> bug.
Please define later version.
> What is your DID?
> aboyd
> http://community.qnx.com/sf/go/post28597
05/04/2009 9:11 AM
post28600
For io-pkt, see r746 on 2009-01-16
aboyd
05/04/2009 9:16 AM
post28601
I was told a while ago that the e1000 driver would be available on 6.4.? Now in M4 I noticed there is a devn-i82544.so
and a devnp-i82544.so. Why the two flavour?
> Sent: May-04-09 9:12 AM
> aboyd
> http://community.qnx.com/sf/go/post28600
05/04/2009 9:19 AM
post28604
The 2 drivers are there for users still using the i82544 driver.
Eventually the i82544 driver will be dropped and the just the e1000
driver included.
Sent: Monday, May 04, 2009 9:17 AM
Now in M4 I noticed there is a devn-i82544.so and a devnp-i82544.so.
> aboyd
General
http://community.qnx.com/sf/go/post28601
05/04/2009 9:23 AM
post28607
> From: Hugh Brown [mailto:community-noreply@qnx.com]
> Sent: May-04-09 9:19 AM
> driver included.
Are you saying devnp-i82544 is e1000? Because I don't see any e1000 driver in M4.
> 6.4.?
> > aboyd
> > General
> http://community.qnx.com/sf/go/post28604
05/04/2009 9:28 AM
post28609
No. devnp-i82544.so and devnp-e1000.so are two
very different io-pkt drivers.
Oops. Hugh, is devnp-e1000.so shipping with 6.4.1?
aboyd
05/04/2009 9:32 AM
post28613
Yes, the devnp-e1000.so driver is being shipped with 6.4.1.
Sent: Monday, May 04, 2009 9:28 AM
aboyd
General
http://community.qnx.com/sf/go/post28609
05/04/2009 9:29 AM
post28610
No, I don't think that the e1000 driver made M4. It is in M5.
devnp-e1000.so is a port of the devn-e1000.so driver to io-pkt.
Sent: Monday, May 04, 2009 9:23 AM
> driver included.
driver in M4.
> 6.4.?
> > aboyd
> > General
General
http://community.qnx.com/sf/go/post28607
05/04/2009 9:20 AM
post28605
In the past, people have whined (with some merit) that
there weren't enough drivers for QNX.
At least with respect to intel i82544, this is no longer
the case. Off the top of my head there chronologically are:
devn-i82544.so (io-net and under shim for io-pkt)
devnp-i82544.so (native io-pkt)
devnp-wm.so (BSD io-pkt_
devn-e1000.so (io-net port of intel source)
devnp-e1000.so (native io-pkt port of intel source)
I probably have forgotten some.
Going forward, we hope that the e1000 driver
variants can provide the performance, reliability
and efficiency that people need. They should work
with all hardware variants - which is a very big
deal with i82544.
aboyd
05/04/2009 9:22 AM
post28606
> Sent: May-04-09 9:21 AM
I hope too because this is killing us (over dramatic).
If only there was another 1G alternative.
> deal with i82544.
> aboyd
> http://community.qnx.com/sf/go/post28605
Re: RE: How to find out if that's a HW fault?
05/04/2009 9:18 AM
post28603
> bug.
Hm... Were there any updates to network drivers in 6.3.0 after SP3? I thought I had the latest ones available. I'll
check downloads.
> What is your DID?
Class = Network (Ethernet)
Device ID = 109ah, 82573L Gigabit Ethernet Controller
RE: RE: How to find out if that's a HW fault?
05/04/2009 9:32 AM
post28612
The devn-e1000.so driver supersedes the i82544 driver. I have attached
an experimental copy.
From: Oleh Derevenko [mailto:community-noreply@qnx.com]
Sent: Monday, May 04, 2009 9:19 AM
Subject: Re: RE: How to find out if that's a HW fault?
> bug.
thought I had the latest ones available. I'll check downloads.
> What is your DID?
General
http://community.qnx.com/sf/go/post28603
Re: RE: RE: How to find out if that's a HW fault?
05/05/2009 6:56 AM
post28674
Hi Hugh,
Sorry, but the driver did not solve the problem. :( Here is what our support person at client site reports.
Installed the patched network drivers and restarted the server this morning:
# ls -la /etc/system/enum/devices/net && ls -la /lib/dll/devn-e1000.so
-rw-rw-r-- 1 root root 15941 May 04 07:01 /etc/system/enum/devices/net
-rwxrwxr-x 1 root root 211989 May 04 06:58 /lib/dll/devn-e1000.so
About an hour later, however, en1 stopped working again.
When I connected to en0 and tried to telnet in, the telnet session ran really slow. It wasn't slow to respond (as I
would type characters I would see them echoed back quickly), but it was very slow to process (when I hit return at the
end command it would take 1-2 minutes to act on the command). I tried using a keyboard and mouse locally and found it
responding in the same slow way.
I was wondering if it was a specific process using all available CPU time, but after spending 20 minutes figuring out
the right ps command, the node process lag went away. EN1 was still non-functional.
Below is some info I was able to grab off the node:
INTEL PRO/1000 Gigabit (Copper) Ethernet Controller
Physical Node ID ........................... 003048 B0CC4F
Current Physical Node ID ................... 003048 B0CC4F
Active PHY address ....................... 1
Maximum Receivable data Unit ............... 1514
Packets Transmitted OK ..................... 700269
Bytes Transmitted OK ....................... 80221003
Broadcast Packets Transmitted OK ........... 3610
Packets Received OK ........................ 688414
Bytes Received OK .......................... 74367203
Broadcast Packets Received OK .............. 11976
Deferred Transmits ......................... 0
Packets Dropped on receive ................. 7481
77835 1 sbin/io-net 10o SIGWAITINFO 64K 5108K 8192(516K)*
77835 2 sbin/io-net 10o RECEIVE 64K 5108K 4096(132K)
77835 3 sbin/io-net 10o RECEIVE 64K 5108K 4096(68K)
77835 4 sbin/io-net 10o RECEIVE 64K 5108K 4096(68K)
77835 5 sbin/io-net 10o RECEIVE 64K 5108K 4096(68K)
77835 6 sbin/io-net 21o RECEIVE 64K 5108K 4096(132K)
77835 7 sbin/io-net 21o RECEIVE 64K 5108K 4096(132K)
77835 8 sbin/io-net 20o RECEIVE 64K 5108K 4096(132K)
77835 9 sbin/io-net 20o RECEIVE 64K 5108K 4096(132K)
77835 10 sbin/io-net 10o RECEIVE 64K 5108K 4096(68K)
devn-e1000.so ...
RE: RE: RE: How to find out if that's a HW fault?
05/05/2009 7:58 AM
post28678
Please can you supply me with the 'pci -v' output as well as how to
reproduce the problem.
Thanks, Hugh.
Sent: Tuesday, May 05, 2009 6:56 AM
Subject: Re: RE: RE: How to find out if that's a HW fault?
Hi Hugh,
morning:
really slow. It wasn't slow to respond (as I would type characters I
(when I hit return at the end command it would take 1-2 minutes to act
it responding in the same slow way.
time, but after spending 20 minutes figuring out the right ps command,
stack
8192(516K)*
4096(132K)
4096(68K)
4096(68K)
4096(68K)
4096(132K)
4096(132K)
77835 8 sbin/io-net 20o RECEIVE 64K...
Re: RE: RE: RE: How to find out if that's a HW fault?
05/06/2009 5:58 AM
post28769
I do not have "pci -v" output yet, but this is what I've been told.
For 1 month the machine was running fine while en0 was used for network (QNet + TCP). We also used exactly the same
computer configuration in previous installations. Then we had to add a driver that needs to communicate with hardware by
UDP broadcasts and we had to make dedicated connection to it. However there were configuration limitations in the
driver and we could not put it on en1. Instead we have moved main network to en1 and configured hardware device on en0.
First of all, there was a problem that when the hardware-dedicated ethernet (EN0) was not plugged in the network started
to return "no buffer space available" on broadcast attempts. As soon as we have plugged in a cable and inserted it into
an empty switch those errors were gone.
But also, since the time of employing en1, it started to go offline every few hours. Well, I suspect it was that way
ever, we just never used and never checked if it was alive.
The last few days machine was running with our hardware driver disabled and EN0 unplugged (so that there was no traffic
on it), but still there problem with EN1 dropping offline did not go away. Even more, we have moved main network back
to en0 and just connected a cable to en1 now and then to see if it still functioning, but the problem remained.
The new driver did not solve it and what's a little bit strange, even after restoring original /etc/system/enum/devices/
net back to have i82544 loaded for device again, the connection was slow after fault again, as if the server was
overloaded. However this was just one test and I can't be sure that there was not some mistake and that the information
about slowdown remaining after rollback to old driver is correct.
That's all I can tell about how the problem can be reproduced. There are no specific actions we could do to make it
fault.
05/12/2009 8:10 AM
post29239
Hi Hugh,
At last, they've sent me the 'pci -v' output. Here it is
PCI version = 3.00
Class = Bridge (Host/PCI)
Device ID = 2970h, Memory Controller Hub
PCI index = 0h
Class Codes = 060000h
Revision ID = 2h
Bus number = 0
Device number = 0
Function num = 0
Status Reg = 2090h
Command Reg = 106h
Latency Timer = 0h
Cache Line Size= 0h
Subsystem Vendor ID = 15d9h
Subsystem ID = b580h
Max Lat = 0ns
Min Gnt = 0ns
PCI Int Pin = NC
Interrupt line = 0
CPU Interrupt = 0h
Capabilities Pointer = e0h
Capability ID = 9h - Vendor Specific
Capabilities = 9109h - cb000368h
PCI index = 0h
Class Codes = 030000h
Revision ID = 2h
Bus number = 0
Device number = 2
Function num = 0
Status Reg = 90h
Command Reg = 7h
Latency Timer = 0h
Cache Line Size= 0h
PCI Mem Address = d0000000h 32bit length 1048576 enabled
PCI Mem Address = c0000000h prefetchable 64bit length 268435456 enabled
PCI IO Address = 30c0h length 8 enabled
Max Lat = 0ns
Min Gnt = 0ns
PCI Int Pin = INT A
Interrupt line = 10
CPU Interrupt = ah
Capabilities Pointer = 90h
Capability ID = 5h - Message Signaled Interrupts
Capabilities = 0h - 0h
Capability ID = 1h - Power Management
Capabilities = 22h - 0h
Class = Bridge (PCI/PCI)
Device ID = 27d0h, 82801G (ICH7 Family) PCI Express Port 1
PCI index = 0h
Class Codes = 060400h
Revision ID = 1h
Bus number = 0
Device number = 28
Function num = 0
Status Reg = 10h
Command Reg = 4h
Header type = 1h Multi-function
Latency Timer = 0h
Cache Line Size= 8h un-cacheable
Primary Bus Number = 0h
Secondary Bus Number = 2h
Subordinate Bus Number = 2h
Secondary Latency Timer = 0h
I/O Base = f0h
I/O Limit = 0h
Secondary Status = 2000h
Memory Base = fff0h
Memory Limit = 0h
Prefetchable Memory Base = fff1h
Prefetchable Memory Limit= 1h
Prefetchable Base Upper 32 Bits = 0h
Prefetchable Limit Upper 32 Bits = 0h
I/O Base Upper 16 Bits = 0h
I/O Limit Upper 16 Bits = 0h
Bridge Control = 0h
PCI Int Pin = INT A
Interrupt line = 10
CPU Interrupt = ah
Capabilities Pointer = 40h
Capability ID = 10h - PCI Express
Capabilities = 141h - fc0h
Capability ID = dh - PCI Bridge Subsystem Vendor ID
Capabilities = 0h - b58015d9h
Capabilities = c802h - 0h
Device ID = 27e0h, 82801GR/GH/GHM (ICH7 Family) PCI Express Port 5
PCI index = 0h
Revision ID = 1h
Bus number = 0
Device number = 28
Function num = 4
Status Reg = 10h
Command Reg = 7h
Latency Timer = 0h
Secondary Bus Number = 6h
Subordinate Bus Number = 6h
I/O Base = 40h
I/O Limit = 40h
Memory Base ...
RE: RE: RE: RE: How to find out if that's a HW fault?
05/12/2009 8:32 AM
post29244
Hi Oleh,
Unfortunately we don't have this device ID here. Is this Ethernet on the
motherboard or is it a plug-in adapter? If it is a plug-in adapter, I
need to know the make and model, and if it is on the motherboard, I need
to know the motherboard make and model.
I have a dual Intel gigabit adapter in one of my machines here and it
has been running for weeks without a problem. Is there heavy activity on
the customer's network when this problem occurs?
Thanks, Hugh.
Sent: Tuesday, May 12, 2009 8:10 AM
Subject: Re: RE: RE: RE: How to find out if that's a HW fault?
Hi Hugh,
PCI version = 3.00
PCI index = 0h
Revision ID = 2h
Bus number = 0
Device number = 0
Function num = 0
Status Reg = 2090h
Command Reg = 106h
Latency Timer = 0h
Cache Line Size= 0h
Max Lat = 0ns
Min Gnt = 0ns
PCI Int Pin = NC
Interrupt line = 0
CPU Interrupt = 0h
PCI index = 0h
Revision ID = 2h
Bus number = 0
Device number = 2
Function num = 0
Status Reg = 90h
Command Reg = 7h
Latency Timer = 0h
Cache Line Size= 0h
Max Lat = 0ns
Min Gnt = 0ns
PCI Int Pin = INT A
Interrupt line = 10
CPU Interrupt = ah
PCI index = 0h
Revision ID = 1h
Bus number = 0
Device number = 28
Function num = 0
Status Reg = 10h
Command Reg = 4h
Latency Timer = 0h
I/O Base = f0h
I/O Limit = 0h
Memory Base = fff0h
Memory Limit = 0h
Bridge Control = 0h
PCI Int Pin = INT A
Interrupt line = 10
CPU Interrupt = ah
Class ...
Re: RE: RE: RE: RE: How to find out if that's a HW fault?
05/12/2009 9:05 AM
post29246
> Unfortunately we don't have this device ID here. Is this Ethernet on the motherboard or is it a plug-in adapter?
As far as I know it's Ethernet integrated on motherboard.
> If it is a plug-in adapter, I need to know the make and model, and if it is on the motherboard, I need to know the
This is what we use http://www.abmx.com/1u-short-depth-server
> I have a dual Intel gigabit adapter in one of my machines here and it has been running for weeks without a problem. Is
there heavy activity on the customer's network when this problem occurs?
Well, I do not have statistics from this particular installation, but I've been watching few previous places. Of course
the network conditions are different everywhere but average network utilization was never above 5-10% there. So,
generally the network should not be loaded very much even though there could be short bursts.
After all, as I already mentioned in previous posts, EN1 dies even if it is not plugged in at all. They just attach the
cable after some time and find that EN1 is not operational any more.
RE: RE: RE: RE: RE: How to find out if that's a HW fault?
05/12/2009 10:35 AM
post29265
I have managed to locate a machine with one 0x109a Intel device on it. I
will runs some tests and let you know. As a matter of interest, this
machine is from our test lab, and has just passed all tests!
Hugh.
Sent: Tuesday, May 12, 2009 9:05 AM
Subject: Re: RE: RE: RE: RE: How to find out if that's a HW fault?
it is on the motherboard, I need to know the motherboard make and model.
I've been watching few previous places. Of course the network conditions
5-10% there. So, generally the network should not be loaded very much
is not plugged in at all. They just attach the cable after some time and
General
http://community.qnx.com/sf/go/post29246
05/12/2009 11:19 AM
post29273
Oleh,
Please can you find out what the customer means by "dropping offline"?
Does nicinfo still show activity on the link and is the link still up? I
have setup a machine on my desk and am running some tests, but would
like to know more about how to reproduce the problem.
Thanks, Hugh.
General
Re: RE: RE: RE: RE: RE: How to find out if that's a HW fault?
05/12/2009 11:45 AM
post29277
It means "If trying 'ls /net' it returns the own node name only. An attempt to ping any other node on the network
results in "Host
is down" error." That is, the driver is running but all network communications are unavailable both over QNet and TCP/IP
I've posted nicinfo output after the fault earlier in this thread for both i82544 and e1000.
Here it is again for i82544
# /sbin/ifconfig
enabled=0<>
enabled=0<>
enabled=0<>
Here en1 is reported to be UP (<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST>).
And here it is once again for e1000
RE: RE: RE: RE: RE: RE: How to find out if that's a HW fault?
05/12/2009 11:47 AM
post29278
If this could help, we have had strange behaviour (we didn't get to the bottom of it) when USB and Networking shared the
same interrupt.
> Sent: May-12-09 11:45 AM
> Subject: Re: RE: RE: RE: RE: RE: How to find out if that's a HW fault?
> offline"?
> attempt to ping any other node on the network results in "Host
> communications are unavailable both over QNet and TCP/IP.
> up?
> # /sbin/ifconfig
> enabled=0<>
> 1500
> enabled=0<>
> enabled=0<>
> Physical Node ID...
