Forum Topic - NIC INFO for multiple instances of tcp/ip stack:
Hi
I am slaying the default tcp/ip stack and intiating three tcp/ip stacks. I am able to send data and receive data but
when i want to see how many packets are transfered or received i can't.
I am using
SOCK=/prefix nicinfo
it's giving only
en0:
 please give me some idea so  i can view how many packets transfered or received.
RE: NIC INFO for multiple instances of tcp/ip stack
  # ifconfig -v
oughta do it for you (with SOCK set for each stack).
It's true that nicinfo does have some exotic counters
that "ifconfig -v" doesn't (eg out of window collisions)
but with 6.4, ifconfig has some features that nicinfo doesn't.
For example, ifconfig shows flow control status, nicinfo doesn't.
ifconfig and nicinfo show the link speed and duplex, but only
ifconfig allows you to change it on the fly from the command line.
I'm hoping that most of the time, "ifconfig -v" will
do what 99% of the people need.
aboyd
