Forum Topic - sigsegv:
sigsegv
6.4.0 on a machine with custom image when doing a shutdown from a telnet session I can see on the machine that io-pkt-v4
 crashes.
Crash at main+734 ip 80856b5.  If you need more info just ask.  I'm not sure I can get a core dump though because the
machine seems to freeze.
RE: sigsegv
Hi Mario:
	What driver is being used?  I take it that this is a "stock"
6.4.0 install?
	Robert.
Sent: Tuesday, February 03, 2009 3:07 PM
To: general-networking
Subject: sigsegv
session I can see on the machine that io-pkt-v4 crashes.
sure I can get a core dump though because the machine seems to freeze.
General
http://community.qnx.com/sf/go/post21346
RE: sigsegv
Hello Robert,
No it's a custom image created with 6.4.0 binaires (use -i on all involved files indicate version 6.4.0 stable).  The
driver is devnp-i82544.so.  Note that devn-pcnet.so (and shim) is also loaded but there is hardware for it.
> From: Robert Craig [mailto:community-noreply@qnx.com]
> Sent: February-03-09 3:23 PM
> Subject: RE: sigsegv
> Hi Mario:
> 6.4.0 install?
> 	Robert.
> Subject: sigsegv
> telnet
> http://community.qnx.com/sf/go/post21347
RE: sigsegv
Hmmm... No core dump in /var/dumps on reboot?
Sent: Tuesday, February 03, 2009 4:01 PM
Hello Robert,
involved files indicate version 6.4.0 stable).  The driver is
> Hi Mario:
> 6.4.0 install?
> 	Robert.
> Subject: sigsegv
> telnet session I can see on the machine that io-pkt-v4 crashes.
> not sure I can get a core dump though because the machine seems to
freeze.
General
http://community.qnx.com/sf/go/post21352
RE: sigsegv
No because the machine freezes.  I'll see if I can somehow manage to get one. (maybe just send a SIGPWR to io-pkt).
> Sent: February-03-09 4:29 PM
> Hello Robert,
> > Hi Mario:
> > 6.4.0 install?
> > 	Robert.
> > Subject: sigsegv
> freeze.
> > General
> > General
> http://community.qnx.com/sf/go/post21359
RE: sigsegv
I'm back on this issue. No core dump, it seems the machine freeze before it has a chance to save the dump.  Seems the
crash only occurs on heavy load and when using 1G.
Suggestion?
> Hello Robert,
> > Hi Mario:
> > 6.4.0 install?
> > 	Robert.
> > Subject: sigsegv
> freeze.
> > General
> > General
