Forum Topic - problem routing udp traffic out a specific interface:
We have a strange problem that we're hoping to get some help with.  We have the following scenario:
# route show
Routing tables
Internet:
Destination                  Gateway                     Flags
default                        192.168.99.1              UG
10.0.0.1                       10.68.0.89                  UH
localhost.localdom      127.0.0.1                    UH
192.168.99.0/24          link#2                         U
192.168.99.1               00:1a:e2:06:9b:f9       UHL
Our network interfaces are as follows:
# ifconfig -a
mos0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> mtu 1500
        address: 00:18:5a:81:06:0c
        media: Ethernet autoselect (100baseTX full-duplex)
        status: active
        inet 192.168.99.166 netmask 0xffffff00 broadcast 192.168.99.255
ppp0: flags=8051<UP,POINTOPOINT,RUNNING,MULTICAST> mtu 1600
        inet 10.68.0.89 -> 10.0.0.1 netmask 0xff000000
We have a UDP socket that we want to send/recv on, but we only want that traffic to go over the ppp0 interface.  We're
using SO_BINDTODEVICE, and have also called bind() on the socket to bind it to only the ppp0 ip addr.
However, when we try to call sendto() on the socket, we get no route to host.  Specifically, we're sending to an ip
address that is not on either of the directly attached networks.
From my read on the docs though, this should work; the udp packets should be sent out the ppp0 interface, because of the
 binding and the use of the SO_BINDTODEVICE socket option.
What am I missing?
-garyf
Re: problem routing udp traffic out a specific interface
IIRC routing is still consulted.  Where are you trying to send
to?  It could be the route points out the mos0 iface or no
route at all.  You could also try the SO_DONTROUTE option.
> # route show
> Routing tables
> Internet:
> # ifconfig -a
>         status: active
the binding and the use of the SO_BINDTODEVICE socket option.
> What am I missing?
> -garyf
> http://community.qnx.com/sf/go/post18533
Thanks for the quick reply, Sean!
So, here's the deal:
mos0 is our onboard ethernet interface.  The ppp0 interface is for a GPRS modem.  If we loose general connectivity over
ethernet, we will fall back to ppp0.
However, we want to be able to continually send a periodic "heartbeat" over GPRS (to indicate that the device is still
alive).
So, the ip address in sendto might be something like 172.17.99.147.
We did try the SO_DONTROUTE, but then sendto gives us a ENETUNREACH.
So, my follow-on question is if the routing table is still consulted, then what does SO_BINDTODEVICE really buy us?
Thanks again, Sean!
-garyf
over ethernet, we will fall back to ppp0.
 alive).
> Thanks again, Sean!
It might not do what you want here.  It's been found useful to
direct broadcasts out a specific iface before BPF.  It also
filters on input.  This page I just created may be useful for
setting up a route on the ppp iface ('ifp' or 'iface' option
to the route utility).
http://community.qnx.com/sf/wiki/do/viewPage/projects.networking/wiki/UnnumberedInterfaces
