Problems getting USB wireless working (Ralink RT2501USB chipset)
11/14/2008 1:10 AM
post16549
I am trying to get a Linksys WUSB54GC-AS USB Wireless adapter working which I believe should have a Ralink RT2501USB
chipset.
I can start the devnp-rum.so driver successfully using the command:
#io-pkt-v6-hc -v -d rum
The resulting slog is as follows:
Time Sev Major Minor Args
Jan 01 00:21:57 5 14 0 tcpip starting
Jan 01 00:21:57 3 14 0 Unable to attach to pci server: No such file or directory
Jan 01 00:21:57 3 14 0 Using pseudo random generator. See "random" option
Jan 01 00:21:57 5 14 0 initializing IPsec... done
Jan 01 00:21:57 5 14 0 IPsec: Initialized Security Association Processing.
Jan 01 00:21:57 5 14 0 USB device vendor 0x13b1, device 0x20 matched.
Jan 01 00:21:57 5 14 0 rum0 at pci0 dev 0 function 0rum0: MAC/BBP RT2573 (rev 0x2573a), RF RT2528, address 00:
2
1:29:de:ff:9e
Jan 01 00:21:57 5 14 0 ether_ifattach: rum0 null if_stop
Jan 01 00:21:57 5 14 0 rum0: 11b rates: 1Mbps 2Mbps 5.5Mbps 11Mbps
Jan 01 00:21:57 5 14 0 rum0: 11g rates: 1Mbps 2Mbps 5.5Mbps 11Mbps 6Mbps 9Mbps 12Mbps 18Mbps 24Mbps 36Mbps
48Mb
ps 54Mbps
However once I set the interface status to up (using the command: ifconfig rum0 up), I get the following errors in slog:
Nov 08 23:08:25 6 816493 1862 ite MAC register: NOMEM
Mar 22 22:57:57 2 204858 1782 544501614 1953265005 1920409705 543519849 541278541 1768383858 1919251571 1330520122
5
064013 799325 14 1448 812479858 1868767290 543452277 544501614 1953265005 1701978217 1293968481 1914716993 1936287589
980
575604 1297042976 19781 799357 14 1448 812479858 1868767290 543452277 544501614 1953265005 1920409705 543519849
541278541
1768383858 1919251571 1330520122 5064013 799421 14 1448 812479858 1868767290 543452277 544501614 1953265005 1701978217
1
293968481 1914716993 1936287589 980575604 1297042976 19781 799453 14 1448 812479858 1868767290 543452277 544501614
195326
5005 1920409705 543519849 541278541 1768383858 1919251571 1330520122 5064013 799517 14 1448 812479858 1868767290
54345227
7 544501614 1953265005 1701978217 1293968481 1914716993 1936287589 980575604 1297042976 19781 799549 14 1448 812479858
18
68767290 543452277 544501614 1953265005 1920409705 543519849 541278541 1768383858 1919251571 1330520122 5064013 799613
14
Jan 27 06:06:44 1 616293 1846 1297042976 19781 799645 14 1448 812479858 1868767290 543452277 544501614 1953265005
19
20409705 543519849 541278541 1768383858 1919251571 1330520122 5064013 799709 14 1448 812479858 1868767290 543452277
54450
Jan 01 00:24:08 5 14 0 rum0: could not multi write MAC register: NOMEM
Jan 01 00:24:08 5 14 0 rum0: could not multi read MAC register: NOMEM
Jan 01 00:24:10 5 14 0 rum0: timeout waiting for BBP/RF to wakeup
Jan 01 00:24:10 5 14 0 rum0: could not multi read MAC register: NOMEM
Jan 01 00:24:10 5 14 0 rum0: could not multi write MAC register: NOMEM
Running USB, the device is detected as follows:
Device Address : 2
Upstream Host Controller : 0
Upstream Device Address : 1
Upstream Port : 4
Upstream Port Speed : Full
Vendor : 0x13b1 (Cisco-Linksys)
Product : 0x0020 (Compact Wireless-G USB Adapter)
Device Release : r0.01
USB Spec Release : v2.00
Serial Number : N/A
Class : 0x00 (Independent per...
RE: Problems getting USB wireless working (Ralink RT2501USB chipset)
11/14/2008 11:40 AM
post16585
Although the device designation (WUSB-54GC-AS) is different from mine
(WUSB-54GC), the USB vendor and device appear to be the same, so it
should be working (I've tested it here and it works fine).
Is this on x86? Have you already stopped io-pkt-v4-hc which was
launched on boot?
The driver code is here
http://community.qnx.com/integration/viewcvs/viewcvs.cgi/trunk/sys/dev/u
sb/if_rum.c?root=core_networking&rev=562&system=exsy1001&view=markup
Here's where the failure appears to be occuring (in usb_do_request):
http://community.qnx.com/integration/viewcvs/viewcvs.cgi/trunk/sys/lib/l
ibnbdrvr/usb/usb_conv_qnx.c?root=core_networking&rev=411&system=exsy1001
&view=markup
So it looks like usbd_alloc is failing to allocate memory.
Are you operating in a very low memory situation ("pidin in" should
help)?
Robert.
From: Radek Pesina [mailto:community-noreply@qnx.com]
Sent: Friday, November 14, 2008 1:10 AM
To: general-networking
Subject: Problems getting USB wireless working (Ralink RT2501USB
chipset)
which I believe should have a Ralink RT2501USB chipset.
file or directory
"random" option
Processing.
matched.
MAC/BBP RT2573 (rev 0x2573a), RF RT2528, address 00:2
1:29:de:ff:9e
11Mbps
11Mbps 6Mbps 9Mbps 12Mbps 18Mbps 24Mbps 36Mbps 48Mb
ps 54Mbps
5064013 799517 14 1448 812479858 1868767290 54345227
980575604 1297042976 19781 799549 14 1448 812479858 18 68767290
1919251571 1330520122 5064013 799613 14
1293968481
799709 14 1448 812479858 1868767290 543452277 54450
1614 1953265005...
Re: RE: Problems getting USB wireless working (Ralink RT2501USB chipset)
11/16/2008 6:48 PM
post16626
Hi Robert,
Thanks for the quick reply!
The system it is running on is an ARM-le device (Freescale i.MX31 ADS board).
Yes I stopped the instance of io-pkt-v4-hc loaded during bootup first.
In terms of memory, pidin in gives the following output:
CPU:ARM Release:6.4.0 FreeMem:106Mb/128Mb BootTime:Jan 01 00:00:00 UTC 1970
Processor1: 1091023716 arm1136 532MHz FPU
I would assume this is enough memory for the device?
> launched on boot?
> &view=markup
> help)?
> Robert.
RE: RE: Problems getting USB wireless working (Ralink RT2501USB chipset)
11/17/2008 4:56 PM
post16701
That should be plenty.... Hmmmm.... I seem to remember that ARM is
somewhat strange when it comes to how much memory a process can use at
one time, but I seem to remember that we have had people using the
Linksys dongle on an ARM platform...
What does "pidin -p io-pkt-v4-hc mem" report with the rum driver
running?
Robert.
Sent: Sunday, November 16, 2008 6:48 PM
Subject: Re: RE: Problems getting USB wireless working (Ralink RT2501USB
chipset)
Hi Robert,
board).
1970
> launched on boot?
> /u
> /l
> 01
> &view=markup
> help)?
> Robert.
General
http://community.qnx.com/sf/go/post16626
Re: Problems getting USB wireless working (Ralink RT2501USB chipset)
11/17/2008 4:58 PM
post16702
Which procnto are you running? I think the imx31 can run procnto-v6 which would eliminate the 32Mb problem..
> running?
> Robert.
> chipset)
> Hi Robert,
> board).
> 1970
>> launched on boot?
>> /u
>> /l
>> 01
>> &view=markup
>> help)?
>> Robert.
> http://community.qnx.com/sf/go/post16701
cburgess@qnx.com
11/17/2008 5:11 PM
post16705
Hi Robert and Colin,
In terms of procnto, currently I am running procnto-v6.
Pidin reports the following with the rum driver running:
# pidin -p io-pkt-v4-hc mem
pid tid name prio STATE code data stack
12303 1 /boot/io-pkt-v4-hc 21r SIGWAITINFO 944K 500K 4096(132K)*
12303 2 /boot/io-pkt-v4-hc 21r RECEIVE 944K 500K 8192(132K)
12303 3 /boot/io-pkt-v4-hc 21r REPLY 944K 500K 4096(20K)
libc.so.3 @ 1000000 448K 12K
devnp-rum.so @78000000 64K 8192
> > running?
> > Robert.
11/17/2008 5:13 PM
post16706
So that all looks fine (I would have been worried if networking were
taking 32 MB!)
Do other USB devices work on the platform (e.g. mass storage devices)?
Can you post the output from
pidin ar
R.
Sent: Monday, November 17, 2008 5:11 PM
Subject: Re: Problems getting USB wireless working (Ralink RT2501USB
chipset)
stack
4096(132K)*
8192(132K)
4096(20K)
> > at one time, but I seem to remember that we have had people using
> > the Linksys dongle on an ARM platform...
> > running?
> > Robert.
General
http://community.qnx.com/sf/go/post16705
11/17/2008 5:21 PM
post16707
Yes other USB devices work fine on the platform, so far USB hubs, memory card readers and USB flash drives work without
a problem.
Pidin output is as follows:
# pidin ar
pid Arguments
1 proc/boot/procnto-v6
2 devc-sermx1 -e -F -c66500000 0x43F90000,45 0x43F94000,32 -u5 0x43fb4000,47
3 slogger
4 pipe
5 fs-etfs-imx31ads_512 -r 1024
6 devf-mx31ads
7 io-usb -d ehci-mx31 ioport=0x43f88300,irq=35
8 spi-master -d mx31 base=0x50010000,irq=13,waitstate=2
4105 io-audio -v -d imx31ads
4106 io-display -v -dvid=0,did=0 -c/etc/system/config/display.conf
4107 i2c-imx31ads
4108 devb-umass cam pnp blk cache=2m,auto=partition,automount=hd0t14:/fs/usb0 dos exe=all
4109 qconn port=8000
4110 ksh
12303 io-pkt-v4-hc -v -d rum
49168 pidin ar
> taking 32 MB!)
> pidin ar
> R.
11/18/2008 11:21 AM
post16801
I'm really not sure what's happening with this one. I've confirmed that
the driver has been used extensively with an i.MX35 platform without any
problems.
Is devb-umass always running? How about slaying that and trying again?
Sent: Monday, November 17, 2008 5:22 PM
chipset)
card readers and USB flash drives work without a problem.
# pidin ar
pid Arguments
0x43fb4000,47
3 slogger
4 pipe
6 devf-mx31ads
4107 i2c-imx31ads
4110 ksh
49168 pidin ar
> taking 32 MB!)
> pidin ar
> R.
General
http://community.qnx.com/sf/go/post16707
Re: RE: RE: Problems getting USB wireless working (Ralink RT2501USB chipset)
11/18/2008 6:17 PM
post16842
Okay I tried changing startup so devb-umass is not started and now after running "ifconfig rum0 up", slog reads a little
differently (and I can see the LED on the adapter flash a couple times during):
Jan 01 00:01:14 5 14 0 tcpip starting
Jan 01 00:01:14 3 14 0 Unable to attach to pci server: No such file or directory
Jan 01 00:01:14 3 14 0 Using pseudo random generator. See "random" option
Jan 01 00:01:14 5 14 0 initializing IPsec... done
Jan 01 00:01:14 5 14 0 IPsec: Initialized Security Association Processing.
Jan 01 00:01:14 5 14 0 USB device vendor 0x13b1, device 0x20 matched.
Jan 01 00:01:15 5 14 0 rum0 at pci0 dev 0 function 0rum0: MAC/BBP RT2573 (rev 0x2573a), RF RT2528, address 00:
2
1:29:de:ff:9e
Jan 01 00:01:15 5 14 0 ether_ifattach: rum0 null if_stop
Jan 01 00:01:15 5 14 0 rum0: 11b rates: 1Mbps 2Mbps 5.5Mbps 11Mbps
Jan 01 00:01:15 5 14 0 rum0: 11g rates: 1Mbps 2Mbps 5.5Mbps 11Mbps 6Mbps 9Mbps 12Mbps 18Mbps 24Mbps 36Mbps
48Mb
ps 54Mbps
Jan 01 00:05:50 5 14 0 rum0: could not multi read MAC register: NOMEM
Jan 01 00:05:50 5 14 0 USB error 0x02000005 encountered in io-pkt.
Jan 01 00:05:50 5 14 0 USB error 0x0a000000 encountered in io-pkt.
Jan 01 00:05:55 5 14 0 rum0: device timeout
Jan 01 00:05:57 5 14 0 USB error 0x0a000000 encountered in io-pkt.
Jan 01 00:06:01 5 14 0 USB error 0x02000005 encountered in io-pkt.
Jan 01 00:06:01 5 14 0 USB error 0x0a000000 encountered in io-pkt.
Jan 01 00:06:06 5 14 0 rum0: device timeout
Jan 01 00:06:08 5 14 0 USB error 0x0a000000 encountered in io-pkt.
Jan 01 00:06:12 5 14 0 USB error 0x02000005 encountered in io-pkt.
Jan 01 00:06:12 5 14 0 rum0: could not transmit buffer: 24
Jan 01 00:06:14 5 14 0 USB error 0x0a000000 encountered in io-pkt.
Jan 01 00:06:17 5 14 0 rum0: device timeout
Jan 01 00:06:19 5 14 0 USB error 0x0a000000 encountered in io-pkt.
Strange considering there is not that much difference between the i.MX31 and i.MX35.
> problems.
RE: RE: RE: Problems getting USB wireless working (Ralink RT2501USB chipset)
11/19/2008 1:51 PM
post16914
Hmmm... As soon as I see a single NOMEM then that's an error condition
that's problematic. All the errors are indicative of something being
wrong at the USB layer.
02000005 = URB status 0200 => CMP_ERR and USB Status 0005 = CRC_ERR +
STALL
0a000000 = URB status 0a00 = CMP_ERR + ABORTED (aborted because of the
initial CMP_ERR).
You can see where this message is generated in usb_handle_error in
usb_conv_qnx.c in
ibnbdrvr/usb/usb_conv_qnx.c?root=core_networking&rev=583&system=exsy1001
&view=markup
How about a "pidin -p io-usb mem" to see what io-usb is doing with
memory?
R.
Sent: Tuesday, November 18, 2008 6:17 PM
Subject: Re: RE: RE: Problems getting USB wireless working (Ralink
RT2501USB chipset)
running "ifconfig rum0 up", slog reads a little differently (and I can
file or directory
"random" option
Processing.
matched.
1:29:de:ff:9e
11Mbps
ps 54Mbps
register: NOMEM
io-pkt.
io-pkt.
io-pkt.
io-pkt.
io-pkt.
io-pkt.
io-pkt.
io-pkt.
io-pkt.
and i.MX35.
> that the driver has been used extensively with an i.MX35 platform
> without any problems.
again?
General
http://community.qnx.com/sf/go/post16842
11/19/2008 1:51 PM
post16915
STALL
initial CMP_ERR).
usb_conv_qnx.c in
&view=markup
memory?
R.
RT2501USB chipset)
file or directory
"random" option
Processing.
matched.
1:29:de:ff:9e
11Mbps
ps 54Mbps
register: NOMEM
io-pkt.
io-pkt.
io-pkt.
io-pkt.
io-pkt.
io-pkt.
io-pkt.
io-pkt.
io-pkt.
and i.MX35.
again?
General
11/19/2008 5:58 PM
post16939
Thanks for not giving up on the problem yet!
Below is the output after I ran "ifconfig rum0 up" on the device (it seemed to increase in memory usage a little after
doing so).
# pidin -p io-usb mem
7 1 proc/boot/io-usb 10r SIGWAITINFO 92K 364K 8192(132K)*
7 2 proc/boot/io-usb 21r RECEIVE 92K 364K 4096(20K)
7 3 proc/boot/io-usb 21r RECEIVE 92K 364K 4096(20K)
7 4 proc/boot/io-usb 21r RECEIVE 92K 364K 4096(20K)
7 5 proc/boot/io-usb 10r NANOSLEEP 92K 364K 4096(20K)
7 6 proc/boot/io-usb 21r RECEIVE 92K 364K 4096(20K)
7 7 proc/boot/io-usb 21r RECEIVE 92K 364K 4096(20K)
devu-ehci-mx31.so @78000000 28K 4096
/dev/mem @28000000 ( 0) 8192
Radek.
> STALL
> initial CMP_ERR).
> usb_conv_qnx.c in
> &view=markup
> memory?
> R.
11/20/2008 4:53 PM
post17013
Nothin obvious there either.
Someone mentioned that there may be a conflict with audio and USB on
that platform. I'm not sure of the details and I would have thought
that it would have shown up with devb-umass, but it's worthwhile not
starting audio (and, just to make sure, anything else that you don't
really need...) and see if that changes the behaviour at all.
I'll have to try and dig up a platform somewhere and try for myself...
R.
Sent: Wednesday, November 19, 2008 5:59 PM
Subject: RE: Problems getting USB wireless working (Ralink RT2501USB
chipset)
seemed to increase in memory usage a little after doing so).
stack
8192(132K)*
4096(20K)
4096(20K)
4096(20K)
4096(20K)
4096(20K)
4096(20K)
Radek.
> condition that's problematic. All the errors are indicative of
> something being wrong at the USB layer.
> STALL 0a000000 = URB status 0a00 = CMP_ERR + ABORTED (aborted because
> of the initial CMP_ERR).
> usb_conv_qnx.c in
> /l
> 01
> &view=markup
> memory?
> R.
General
http://community.qnx.com/sf/go/post16939
11/20/2008 5:44 PM
post17018
Okay I changed the startup script so only the bare minimum is started.
pid Arguments:
3 slogger
4 pipe
5 io-usb -d ehci-mx31 ioport=0x43f88300,irq=35
6 ksh
7 io-pkt-v4-hc -v -d rum
Unfortunately I'm still getting the same USB error.
Radek.
11/20/2008 5:50 PM
post17019
That's the initial NOMEM plus subsequent USB errors?
Looks like it's time to go hunting for hardware... I'm running out of
ideas.
R.
Sent: Thursday, November 20, 2008 5:44 PM
chipset)
pid Arguments:
0x43fb4000,47
3 slogger
4 pipe
6 ksh
Radek.
General
http://community.qnx.com/sf/go/post17018
11/20/2008 5:55 PM
post17020
Yes that's correct (I should have clarified that...), here's the slog:
Jan 01 00:00:02 5 14 0 initializing IPsec... done
Jan 01 00:00:02 5 14 0 IPsec: Initialized Security Association Processing.javascript:if%
20(validateCreatePost(document.createPost))%20{%20submitForm(document.createPost,%20'submit');%20}%20else%20{%20void(0)%
20}
Jan 01 00:00:02 5 14 0 USB device vendor 0x13b1, device 0x20 matched.
Jan 01 00:00:02 5 14 0 rum0 at pci0 dev 0 function 0rum0: MAC/BBP RT2573 (rev 0x2573a), RF RT2528, address 00:
2
1:29:de:ff:9e
Jan 01 00:00:02 5 14 0 ether_ifattach: rum0 null if_stop
Jan 01 00:00:02 5 14 0 rum0: 11b rates: 1Mbps 2Mbps 5.5Mbps 11Mbps
Jan 01 00:00:02 5 14 0 rum0: 11g rates: 1Mbps 2Mbps 5.5Mbps 11Mbps 6Mbps 9Mbps 12Mbps 18Mbps 24Mbps 36Mbps
48Mb
ps 54Mbps
Jan 01 00:00:12 5 14 0 rum0: could not multi read MAC register: NOMEM
Jan 01 00:00:12 5 14 0 USB error 0x02000005 encountered in io-pkt.
Jan 01 00:00:12 5 14 0 USB error 0x0a000000 encountered in io-pkt.
Jan 01 00:00:16 5 14 0 rum0: device timeout
Jan 01 00:00:19 5 14 0 USB error 0x0a000000 encountered in io-pkt.
Jan 01 00:00:26 5 14 0 USB error 0x0a000000 encountered in io-pkt.
Jan 01 00:00:27 5 14 0 rum0: device timeout
11/25/2008 10:10 PM
post17324
Hi Robert,
Just giving you a quick update. Since the i.MX31 PDK BSP is now available, I have downloaded the BSP and tried using
the wireless adapter on the PDK board. To my surprise the wireless adapter works fine on the PDK. I thought that maybe
libstartup or the USB driver itself may be different between the two, however they are identical.
Still no luck on the ADS board however.
Cheers,
Radek.
11/26/2008 11:00 AM
post17387
Hi Radek:
Well THAT'S good news. I still don't have any idea why it won't
work on the ADS board... It'll probably have a bit of a lower priority
on my front now that you've shown it to be working on a similar
platform.
Oh... I just had a thought. One thing about some of these platforms is
that the USB ports don't provide enough power to drive the WiFi chips.
Can you plug the dongle into a powered USB hub and see if that changes
things at all?
Robert.
Sent: Tuesday, November 25, 2008 10:11 PM
chipset)
Hi Robert,
available, I have downloaded the BSP and tried using the wireless
fine on the PDK. I thought that maybe libstartup or the USB driver
Cheers,
Radek.
General
http://community.qnx.com/sf/go/post17324
11/26/2008 4:38 PM
post17426
Hi Robert,
And we have success! - you were spot on the money there, the ADS board doesn't seem to have enough power on the USB port
to run the Wifi adapter.
Thanks alot for your help.
> Hi Radek:
> platform.
> things at all?
> Robert.
11/26/2008 4:40 PM
post17427
I should have thought of that one earlier. We hit it once before. At
least now it's indelibly etched in my mind :->>
Robert.
Sent: Wednesday, November 26, 2008 4:39 PM
chipset)
Hi Robert,
doesn't seem to have enough power on the USB port to run the Wifi
adapter.
> Hi Radek:
work
> on the ADS board... It'll probably have a bit of a lower priority on
> my front now that you've shown it to be working on a similar platform.
> is that the USB ports don't provide enough power to drive the WiFi
chips.
> things at all?
> Robert.
General
http://community.qnx.com/sf/go/post17426
11/26/2008 4:47 PM
post17429
... and that's a lesson learnt for me too. It didn't cross my mind that it would not have sufficient power for a
wireless adapter - a portable harddrive or multiple devices yes, but not for a single adapter so thanks.
Now before I go chasing a wild goose with one of my intended uses for the wireless adapter, is it possible to do
ethernet-based debugging over wireless (i.e. qconn)? Reason being once we have our target hardware we will no longer
have the luxury of an ethernet connection.
Cheers,
Radek.
> Robert.
11/26/2008 4:52 PM
post17430
That one had us scratching our heads for a while too. I'm actually
surprised that a hard drive works for you (as opposed to a flash based
drive...).
In any case, you should have no problems at all debugging over wireless.
From an app point of view, it's all Ethernet / IP at the end of the day
so once you get connected, the rest is good. Our QNET protocol works
over WiFi links as well.
Robert.
Sent: Wednesday, November 26, 2008 4:47 PM
chipset)
it would not have sufficient power for a wireless adapter - a portable
thanks.
the wireless adapter, is it possible to do ethernet-based debugging over
will no longer have the luxury of an ethernet connection.
Cheers,
Radek.
> Robert.
General
http://community.qnx.com/sf/go/post17429
11/26/2008 5:01 PM
post17432
That's the answer I was hoping to hear, at least we will have an affordable debugging solution on our target hardware.
As for the hard drive, I haven't tried it yet, it was more a comment that I would expect a portable hdd to require a
powered hub and hence I would click to try powering it to fix the problem, but not a wireless adapter. It is on the
list of things to try though so if it does work I will let you know.
> drive...).
> Robert.
01/08/2009 4:20 PM
post19690
I'm having similar problems get rum0 to work on an x86 PC. I've followed this thread as best as I could (even so far as
trying the wireless dongle in a powered USB hub).
When I power up the target, I get one of the following behaviors:
1 The USB device doesn't seem to be detected at all.
2 The USB device is detected but I get a boat load of the "" messages displayed by slogger.
3 The rum0 interface appears to come up (ifconfig shows it with a DHCP address) but I can't connect to the target via
the wireless interface.
Sometimes if the device isn't detected during power up, if I remove it and insert it in a different USB port it will be
detected (at least to the point where ifconfig shows the rum0 interface).
Gordon Molek
Zebra Technologies Corporation
01/08/2009 4:22 PM
post19691
Hi Gordon:
This is really sounding like a problem with the USB side of
things. What type of interface is it (EHCI, UHCI, OHCI)? Does the
dongle work OK on a different x86 platform?
When you say "" messages displayed, does it mean exactly that (empty
messages or "" messages)?
Robert.
From: Gordon Molek [mailto:community-noreply@qnx.com]
Sent: Thursday, January 08, 2009 4:20 PM
chipset)
followed this thread as best as I could (even so far as trying the
address) but I can't connect to the target via the wireless interface.
and insert it in a different USB port it will be detected (at least to
Gordon Molek
General
http://community.qnx.com/sf/go/post19690
01/08/2009 4:43 PM
post19693
Robert,
Sorry, that was a placeholder and then I forgot to go dig up the error
message and fill it in before hitting "Submit."
The error I usually get is the "rum0: could not multi read MAC register:
NOMEM".
The dongle was working on this particular target with io-net as the base
networking with a separate start-up of io-pkt. It seems we started
getting into trouble when Mike Cranston created an image to run io-pkt
"natively."
How do I determine EHCI/UHCI/OHCI? I'm not particularly knowledgeable
of USB.
Gordon
From: Robert Craig [mailto:community-noreply@qnx.com]
Sent: Thursday, January 08, 2009 3:23 PM
Subject: RE: RE: Problems getting USB wireless working (Ralink RT2501USB
chipset)
Hi Gordon:
Robert.
chipset)
Gordon Molek
General
General
http://community.qnx.com/sf/go/post19691
- CONFIDENTIAL-
This email and any files transmitted with it are confidential, and may also be legally privileged. If you are not the
intended recipient, you may not review, use, copy, or distribute this message. If you receive this email in error,
please notify the sender immediately by reply email and then delete this email.
01/08/2009 4:50 PM
post19695
Weirder and weirder. So with io-net up and running and (presumably)
connected to a PCI NIC, you could start up io-pkt separately and
everything ran OK. But take io-net out of the picture and things no
longer work? That's very odd.
What does "created an image" mean? Did it include everything from
before but just no longer starts io-net or were major alterations made
to the contents of the image?
Can you try other USB devices (e.g. a USB flash drive) and see if they
work?
Have you also removed the NIC that io-net was using from the machine?
How has the interrupt allocation been changed by the removal of io-net?
(pidin irq will tell you which sub-systems are using which interrupts).
Were any BIOS changes made after the new image was used?
If the same hardware worked with io-net in the picture, then I won't
worry about which flavour of usb is being used (although the USB utility
should let you know what type of bus a device is plugged into if the
device is detected).
Lots of questions... :>
Robert.
Sent: Thursday, January 08, 2009 4:43 PM
chipset)
Robert,
NOMEM".
"natively."
of USB.
Gordon
chipset)
Hi Gordon:
Robert.
chipset)
Gordon Molek
General
General
- CONFIDENTIAL-
also be legally privileged. If you are not the intended recipient, you
this email in error, please notify the sender immediately by reply email
and then delete this...
01/09/2009 9:04 AM
post19724
Robert,
OK, here we go, lot's of answers.
Here's the output of "usb -vvv" with the Linksys inserted:
USB 0 (UHCI) v1.10, v1.01 DDK, v1.01 HCD
Control, Interrupt, Bulk(SG), Isoch(Stream), Low speed, Full speed
USB 1 (UHCI) v1.10, v1.01 DDK, v1.01 HCD
Device Address : 1
Upstream Host Controller : 1
Upstream Device Address : 0
Upstream Port : 0
Upstream Port Speed : Low
Vendor : 0x413c (Dell)
Product : 0x2003 (Dell USB Keyboard)
Device Release : r3.06
USB Spec Release : v1.10
Serial Number : N/A
Class : 0x00 (Independent per interface)
Max PacketSize0 : 8
Languages : 0x0409 (English)
Current Frame : 505 (1024 bytes)
Configurations : 1
Configuration : 1
Attributes : 0xa0 (Bus-powered, Remote-wakeup)
Max Power : 70 mA
Interfaces : 1
Interface : 0 / 0
Class : 0x03 (HID)
Subclass : 0x01 (Boot interface)
Protocol : 0x01 (Keyboard)
Endpoints : Control + 1
Endpoint : 0
Attributes : Control
Max Packet Size: 8
Endpoint : 1
Attributes : Interrupt/IN
Max Packet Size: 8
Interval : 24 ms
Device Address : 2
Upstream Port : 1
Product : 0x3012 (Dell USB Optical Mouse)
Device Release : r43.01
Serial Number : N/A
Max PacketSize0 : 8
Current Frame : 541 (1024 bytes)
Configurations : 1
Configuration : 1
Max Power : 100 mA
Interfaces : 1
Interface : 0 / 0
Class : 0x03 (HID)
Protocol : 0x02 (Mouse)
Endpoint : 0
Max Packet Size: 8
Endpoint : 1
Max Packet Size: 5
Interval : 10 ms
USB 2 (UHCI) v1.10, v1.01 DDK, v1.01 HCD
USB 3 (UHCI) v1.10, v1.01 DDK, v1.01 HCD
USB 4 (EHCI) v1.10, v1.01 DDK, v1.01 HCD
Control, Interrupt, Bulk(SG), Isoch(Stream), Full speed, High speed
Device Address : 1
Upstream Host Controller : 4
Upstream Port : 7
Upstream Port Speed : High
Serial Number : N/A
Max PacketSize0 : 64
Current Frame : 5313 (1024 bytes)
Configurations : 1
Configuration : 1
Attributes : 0x80 (Bus-powered)
Max Power : 300 mA
Interfaces : 1
Interface : 0 / 0
Class : 0xff (Vendor-specific)
Subclass ...
01/09/2009 3:16 PM
post19788
And nothing obvious sticks out there either. You're plugged into the
high speed EHCI controller (which is good), there aren't any interrupts
being shared between USB and networking (good). It looks like the
enumerator found and started a network driver for a card in the system
since networking does have a real IRQ assigned to it.
Let's try something a bit more drastic... As root
slay io-pkt
slay io-usb
sloginfo -c
io-usb -dehci -dohci -duhci
usb -vvv
(Make sure that the device shows up)
io-pkt-v4-hc -drum
And send the output from sloginfo
Robert.
Sent: Friday, January 09, 2009 9:05 AM
chipset)
Robert,
Device Address : 1
Upstream Port : 0
Serial Number : N/A
Max PacketSize0 : 8
Configurations : 1
Configuration : 1
Max Power : 70 mA
Interfaces : 1
Interface : 0 / 0
Class : 0x03 (HID)
Endpoint : 0
Max Packet Size: 8
Endpoint : 1
Max Packet Size: 8
Interval : 24 ms
Device Address : 2
Upstream Port : 1
Serial Number : N/A
Max PacketSize0 : 8
Configurations : 1
Configuration : 1
Max Power : 100 mA
Interfaces : 1
Interface : 0 / 0
Class : 0x03 (HID)
Endpoint : 0
Max Packet Size: 8
Endpoint : 1
Max Packet Size: 5
Interval : 10 ms
Device Address : 1
Upstream...
01/12/2009 10:59 AM
post19853
Robert,
I'm having no luck getting your requested output. My target PC does not
have PS/2 keyboard and mouse ports, so I lose my keyboard as soon as I
slay io-usb. I've tried writing a script to perform the steps you
outline but it seems to either hang or the USB Wi-Fi adapter is not
detected. I've also tried unsuccessfully to get phindows to run over
the serial port, but it simply states that it is waiting for phrelay on
com1 and I have been unable to figure out what needs to be configured on
the target.
Any suggestions?
Gordon
Sent: Friday, January 09, 2009 2:16 PM
chipset)
slay io-pkt
slay io-usb
sloginfo -c
usb -vvv
io-pkt-v4-hc -drum
Robert.
chipset)
Robert,
Device Address : 1
Upstream Port : 0
Serial Number : N/A
Max PacketSize0 : 8
Configurations : 1
Configuration : 1
Max Power : 70 mA
Interfaces : 1
Interface : 0 / 0
Class : 0x03 (HID)
Endpoint : 0
Max Packet Size: 8
Endpoint : 1
Max Packet Size: 8
Interval : 24 ms
Device Address : 2
Upstream Port : 1
Serial Number : N/A
Max PacketSize0 : 8
Configurations : 1
Configuration : 1
Max Power : 100 mA
Interfaces : 1
Interface : 0 / 0
Class ...
01/12/2009 11:04 AM
post19856
Hmmm... Hadn't thought about that one. I can think of a convoluted way
involving running two stacks (one with the wired adapter) and using
telnet....
Let's start off with just
slay io-pkt
sloginfo -c
usb -vvv
io-pkt-v4-hc -drum
Robert.
Sent: Monday, January 12, 2009 10:59 AM
chipset)
Robert,
the target.
Any suggestions?
Gordon
chipset)
slay io-pkt
slay io-usb
sloginfo -c
usb -vvv
io-pkt-v4-hc -drum
Robert.
chipset)
Robert,
Device Address : 1
Upstream Port : 0
Serial Number : N/A
Max PacketSize0 : 8
Configurations : 1
Configuration : 1
Max Power : 70 mA
Interfaces : 1
Interface : 0 / 0
Class : 0x03 (HID)
Endpoint : 0
Max Packet Size: 8
Endpoint : 1
Max Packet Size: 8
Interval : 24 ms
Device Address : 2
Upstream Port : 1
Device...
01/12/2009 11:56 AM
post19879
Robert,
It's very inconsistent whether or not the USB Wi-Fi adapter is detected
on boot-up, or when I remove and re-insert it, but for what it is worth,
here's the sloginfo:
Jan 12 10:48:22 5 14 0 tcpip starting
Jan 12 10:48:22 3 14 0 Using pseudo random generator. See
"random" option
Jan 12 10:48:22 5 14 0 if_attach: lo0 null if_stop
Jan 12 10:48:22 5 14 0 if_attach: lo0 null if_init
Jan 12 10:48:22 5 14 0 initializing IPsec... done
Jan 12 10:48:22 5 14 0 IPsec: Initialized Security Association
Processing.
Jan 12 10:48:22 2 14 0 Unable to init devnp-rum.so: No such
device or address
Sent: Monday, January 12, 2009 10:05 AM
chipset)
telnet....
slay io-pkt
sloginfo -c
usb -vvv
io-pkt-v4-hc -drum
Robert.
chipset)
Robert,
the target.
Any suggestions?
Gordon
chipset)
slay io-pkt
slay io-usb
sloginfo -c
usb -vvv
io-pkt-v4-hc -drum
Robert.
chipset)
Robert,
Device Address : 1
Upstream Port : 0
Serial Number : N/A
Max PacketSize0 : 8
Current Frame : 505...
01/12/2009 12:01 PM
post19880
All of this is pointing to "something" going wrong with USB on that
platform. The fact that it worked with 6.3.2 and doesn't work on 6.4.0
is concerning me. Is there anyway that you can try out a different
platform and see if that works? Do you happen to have some sort of
USB-Ethernet dongle (e.g. SMC-2209) that one of our drivers might work
with to try out? What are the specs on the hardware?
This is another one of those "weird ones".
Robert.
Sent: Monday, January 12, 2009 11:57 AM
chipset)
Robert,
"random" option
Processing.
device or address
chipset)
telnet....
slay io-pkt
sloginfo -c
usb -vvv
io-pkt-v4-hc -drum
Robert.
chipset)
Robert,
the target.
Any suggestions?
Gordon
chipset)
slay io-pkt
slay io-usb
sloginfo -c
usb -vvv
io-pkt-v4-hc -drum
Robert.
chipset)
Robert,
Control, Interrupt, Bulk(SG),...
01/12/2009 3:10 PM
post19902
Robert,
OK, it seems to be pointing to the USB Wi-Fi adapter itself. I used a
different LinkSys dongle on my Dell Optiplex GX620 target and the
problem appears to have gone away. I moved the original LinkSys dongle
to another target (Dell Optiplex 745) and the problem moved with the
dongle.
Gordon
Sent: Monday, January 12, 2009 11:01 AM
chipset)
Robert.
chipset)
Robert,
"random" option
Processing.
device or address
chipset)
telnet....
slay io-pkt
sloginfo -c
usb -vvv
io-pkt-v4-hc -drum
Robert.
chipset)
Robert,
the target.
Any suggestions?
Gordon
chipset)
slay io-pkt
slay io-usb
sloginfo -c
io-usb -dehci...
01/12/2009 3:12 PM
post19903
Whew! (I think). Sounds very strange, but I'm glad to hear that things
are working again. Funny how I never even thought to question the
dongle, but I guess that I should have. USB on x86 is usually solid, so
to have it fail would be unusual.
Robert.
Sent: Monday, January 12, 2009 3:10 PM
chipset)
Robert,
dongle.
Gordon
chipset)
Robert.
chipset)
Robert,
"random" option
Processing.
device or address
chipset)
telnet....
slay io-pkt
sloginfo -c
usb -vvv
io-pkt-v4-hc -drum
Robert.
chipset)
Robert,
the target.
Any suggestions?
Gordon
Subject: RE: RE: Problems getting USB...
01/15/2009 8:55 AM
post20107
Robert,
OK, now that we've got THAT out of the way, on to the issue that first
started this investigation. :-)
Sometimes when we boot up our target with the USB WiFi adapter inserted
the system hangs during startup. I modified /etc/system/sysinit to
automatically set VERBOSE.
The output that shows up on the console during boot up is:
QNX v1.2a Boot Loader: qnxbasesmp.ifs .....
Press the space bar to input boot options or D to disable DMA...
Trying SATA ahci. Scanning for devices...
xpt_configure: ahci SIM attach failure
Trying EIDE. Scanning for devices...
...found 2 devices
Detected USB. Scanning for devices...
Trying SATA mvSata. Scanning for devices...
xpt_configure: No mvSata interfaces found
BOOTSRC=disk
SAFEMODE=
VERBOSE=1
ROOTDEV=/dev/hd0t179
NO_ETC=
Typically, the next output would be:
Starting extra run commands
Which indicates that /etc/rc.d/rc.local is being executed, but we don't
see that during a hang.
Is there any other debugging/tracing we could enable to further isolate
what is going wrong?
Secondly, we have seen several instances where the system does not
shutdown and reboot properly (we invoke system("shutdown -q") to bring
the system down).
Photon exits (we get back to the console output screen) but the system
doesn't reboot, and the power button doesn't shut the PC off until it's
been held for more than 5 seconds.
Gordon
Sent: Monday, January 12, 2009 2:12 PM
chipset)
Robert.
chipset)
Robert,
dongle.
Gordon
chipset)
Robert.
chipset)
Robert,
"random" option
Jan 12...
01/15/2009 10:02 AM
post20120
OK, I turned on verbose in enum-devices and got the following debug
output:
Starting: io-display
Starting: mount -Tio-display vid=0x1002,did=0x5b62,deviceindex=0
Starting: io-pkt-v4-hc -ptcpip
Starting: mount -Tio-pkt -opci=0,vid=0x14e4,did=0x1677
/lib/dll/devn-tigon3.so
Starting: netmanager
Starting: io-pkt-v4-hc -ptcpip (skipped: already running)
Starting: mount -Tio-pkt devnp-rum.so
Starting enumerator: legacy'
(neednet,,chkser,ioport=3f8+7,irq=4,nopar,nokb,nonet) => 155672
Starting: devb-fdc cam quiet blk auto=partition,cache=100k
Gordon
- CONFIDENTIAL-
01/15/2009 10:39 AM
post20129
So it LOOKS like you're about to mount another network device and it
never gets to it... You've got a BCM57xx, the Linksys dongle and some
other NIC in there (?) Wouldn't happen to be an Intel 10/100 card would
it?
Robert.
Sent: Thursday, January 15, 2009 10:03 AM
chipset)
output:
Gordon
- CONFIDENTIAL-
General
http://community.qnx.com/sf/go/post20120
01/15/2009 1:27 PM
post20155
There's only the on-board NIC and the Linksys dongle. No separate Intel
10/100 card.
Perhaps something is being mis-identified?
Sent: Thursday, January 15, 2009 9:39 AM
chipset)
it?
Robert.
chipset)
output:
Gordon
- CONFIDENTIAL-
General
General
http://community.qnx.com/sf/go/post20129
01/15/2009 1:39 PM
post20156
Hmmm... I wonder why it looks like it's trying to bring up another
io-pkt session. You'd really only expect it to do so if there were
another interface recognized. Where did you add in the info for the rum
driver? Can you post your net configuration file for me to take a look
at?
I guess the other thing to make sure of is that this is
something to do with networking and not another subsystem. If you don't
have the dongle plugged in, does it still fail to come up?
Robert.
Sent: Thursday, January 15, 2009 1:27 PM
chipset)
10/100 card.
chipset)
it?
Robert.
chipset)
output:
Gordon
- CONFIDENTIAL-
General
General
General
http://community.qnx.com/sf/go/post20155
01/15/2009 1:47 PM
post20159
Robert,
I was unable to reproduce this boot-up hang without the Linksys dongle
inserted. The power-down hang occurs regardless of whether or not the
Linksys dongle is inserted or not.
The contents of my /etc/netconfig file is:
udp6 tpi_clts v inet6 udp - -
tcp6 tpi_cots_ord v inet6 tcp - -
udp tpi_clts v inet udp - -
tcp tpi_cots_ord v inet tcp - -
rawip tpi_raw - inet - - -
local tpi_cots_ord - loopback - - -
The contents of my /etc/system/enum/devices/net file is (see the
"gemhack" comments below to see what I added):
# Definitions for net devices
# Make sure ionet starts even if there is no network card (for 127.1)
device(none, .type=$(ISA_TYPE_NETWORK))
requires($(IOPKT_CMD),)
waitfor (/dev/socket)
# ne1000/ne2000 devices
device(isa, .type=$(ISA_TYPE_NETWORK), .subtype=$(ISA_NETWORK_ETHER),
.progif=00)
tag(devn)
append(legacy, ",nonet")
uniq(netnum, devn-en, 0)
mount(-Tio-pkt "-oioport=0x$(ioport)" /lib/dll/devn-ne2000.so,
"/dev/io-net/en$(netnum)")
use(symbolic=netmgr)
device(pci, ven=$(PCI_VEND_REALTEK), dev=8029)
device(pci, ven=$(PCI_VEND_WINBOND), dev=0940) #89C940
device(pci, ven=$(PCI_VEND_POWERMATIC), dev=1401) #Compex RL2000
device(pci, ven=$(PCI_VEND_KTI), dev=3000) #ET32P2
device(pci, ven=$(PCI_VEND_NETVIN), dev=5000) #NV5000SC
device(pci, ven=$(PCI_VEND_VIA), dev=0926) #82C926
tag(devn)
mount(-Tio-pkt "-opci=$(index),vid=0x$(ven),did=0x$(dev)"
/lib/dll/devn-ne2000.so, "/dev/io-net/en$(netnum)")
device(pcmcia, ven=$(PCCARD_VEND_DLINK), dev=021b)
device(pcmcia, ven=$(PCCARD_VEND_SOCKET), dev=000d) #PCMCIA LPE
device(pcmcia, ven=$(PCCARD_VEND_SOCKET), dev=0075) #CF+ LPE
device(pcmcia, .type=$(PCCARD_TYPE_NETWORK)
.subtype=$(PCCARD_NETWORK_ETHER),
.progif=$(PCCARD_NETWORK_ETHER_NE2000))
tag(devn)
# assume pcmcia only have one ethernet card for now so en0 is always
used
# mount(-Tio-pkt "-oioport=0x$(ioport),irq=$(irq)"
/lib/dll/devn-ne2000.so, "/dev/io-net/en0")
device(cardbus, ven=10b7, dev=5157)
device(cardbus, ven=10b7, dev=5257)
device(cardbus, ven=10b7, dev=6560)
device(cardbus, ven=10b7, dev=6562)
device(cardbus, ven=10b7, dev=6564)
tag(devn)
# assume cardbus only have one ethernet card for now so en0 is always
used
/lib/dll/devn-el900.so, "/dev/io-net/en$(netnum)")
device(cardbus, ven=8086, dev=1229)
tag(devn)
used
/lib/dll/devn-speedo.so, "/dev/io-net/en$(netnum)")
device(cardbus, ven=1011, dev=0019)
device(cardbus, ven=$(PCI_VEND_ABOCOM), dev=ab02) # Abocom FE2500
tag(devn)
used
/lib/dll/devn-tulip.so, "/dev/io-net/en$(netnum)")
device(cardbus, ven=10b8, dev=0006)
tag(devn)
waitfor...
01/15/2009 2:03 PM
post20160
OK... Tried that out and everything worked for me on my system. Can
you try commenting out the "start(netmanager)" line and see what
happens? Do you have a /etc/net.cfg file present?
In terms of ths power-down hang, you might have to ask in another forum.
What happens if you try a "shutdown -f" from the commmand line?
Robert.
Sent: Thursday, January 15, 2009 1:48 PM
chipset)
Robert,
.progif=00)
tag(devn)
tag(devn)
tag(devn)
used
tag(devn)
used
tag(devn)
used
/lib/dll/devn-speedo.so,...
01/16/2009 7:31 AM
post20193
Robert,
Well, it doesn't fail to boot every time. It's probably hanging 1 in
every 30 attempts.
I tried commenting out the line you suggested and the failure still
occurred. I do not have an "/etc/net.cfg" file.
When I'm not running one of these reset tests, I usually use "shutdown
-f" to reboot the system and have never noticed the hang, but then
again, during my testing it happens approximatetly 1 in 100 cycles.
Sent: Thursday, January 15, 2009 1:03 PM
chipset)
Robert.
chipset)
Robert,
.progif=00)
tag(devn)
tag(devn)
tag(devn)
used
device(cardbus, ven=10b7,...
01/16/2009 12:36 PM
post20230
Well THAT certainly makes things harder to track down. No netmanager or
net.cfg file means that the interface isn't getting brought up so it's
something to do with the attach. The problem with tracking down any of
these boot problems is that, without a shell, you really can't figure
out what the system is doing while it's "not booting" so it's divide and
conquer.
Can you try increasing the verbosity on enum-devices to get more output
and post the log when it fails? I'll try to see if by machine survives
multiple re-boots.
Come to think of it, by re-boot, do you mean a re-start after "shutdown
-f" or a full power cycle?
Robert.
Sent: Friday, January 16, 2009 7:31 AM
chipset)
Robert,
every 30 attempts.
chipset)
Robert.
chipset)
Robert,
.progif=00)
tag(devn)
tag(devn)
/lib/dll/devn-ne2000.so,...
01/16/2009 1:41 PM
post20242
My tests perform a "soft" reset, not a power-cycle.
Sent: Friday, January 16, 2009 11:37 AM
chipset)
conquer.
multiple re-boots.
Robert.
chipset)
Robert,
every 30 attempts.
chipset)
Robert.
chipset)
Robert,
.progif=00)
tag(devn)
device(pci,...
01/16/2009 1:49 PM
post20245
Ahhh... That means that the hardware is in a potentially "indeterminate"
state... Nothing like making a problem a little more challenging :>.
Increasing the verbosity of enum-devices would still be useful...
Robert.
Sent: Friday, January 16, 2009 1:41 PM
chipset)
chipset)
conquer.
multiple re-boots.
Robert.
chipset)
Robert,
every 30 attempts.
chipset)
Robert.
chipset)
Robert,
.progif=00)
tag(devn)
waitfor...
01/16/2009 3:04 PM
post20252
Robert,
OK, setting VERRBOSE to 9 yielded the following:
- this is the point where it would normally hang, but we got the
following 3 lines.
uset verbose
test -r /etc/system/config/useqnet -a -d /dev/socket
mount -Tio-pkt lsm-qnet.so
Sent: Friday, January 16, 2009 12:50 PM
chipset)
Robert.
chipset)
chipset)
conquer.
multiple re-boots.
Robert.
chipset)
Robert,
every 30 attempts.
chipset)
Robert.
chipset)
Robert,
tcp tpi_cots_ord v inet tcp - ...
01/16/2009 4:07 PM
post20267
Do I read that right and it appears to hang after mounting qnet?
Robert.
Sent: Friday, January 16, 2009 3:04 PM
chipset)
Robert,
following 3 lines.
uset verbose
chipset)
Robert.
chipset)
chipset)
conquer.
multiple re-boots.
Robert.
chipset)
Robert,
every 30 attempts.
chipset)
Robert.
chipset)
Robert,
inserted. The power-down hang occurs regardless of whether or not...
01/19/2009 8:36 AM
post20295
Yes, I have confirmed it a second time. That is the last output shown
on the console.
Sent: Friday, January 16, 2009 3:08 PM
chipset)
Robert.
chipset)
Robert,
following 3 lines.
uset verbose
chipset)
Robert.
chipset)
chipset)
conquer.
multiple re-boots.
Robert.
chipset)
Robert,
every 30 attempts.
chipset)
Robert.
01/19/2009 9:17 AM
post20298
> confirmed it a second time ...
Remember that qnet will call the _init routine for
any devices that it discovers.
Depending upon how you intend to use qnet, you can
either use the "bind=" option to tell it to only use
specific interfaces, or perhaps just:
# rm /etc/system/config/useqnet
file during your initialization debugging, to simplify
things as much as possible.
aboyd
01/19/2009 1:10 PM
post20329
OK, binding qnet to en0 only seems like it resolved the issue. Although
we're not planning on shipping a product with qnet enabled, it would be
good to know what's going on when qnet is enabled for the Linksys
dongle.
From: Andrew Boyd [mailto:community-noreply@qnx.com]
Sent: Monday, January 19, 2009 8:18 AM
chipset)
Remember that qnet will call the _init routine for any devices that it
discovers.
Depending upon how you intend to use qnet, you can either use the
"bind=" option to tell it to only use specific interfaces, or perhaps
just:
file during your initialization debugging, to simplify things as much as
possible.
aboyd
General
http://community.qnx.com/sf/go/post20298
- CONFIDENTIAL-
01/19/2009 1:22 PM
post20331
> it would be good to know what's going on when qnet is
> enabled for the Linksys dongle.
As I said before, when qnet is discovering interfaces,
it makes a call to the driver "init" function to bring
the interface up. This is because you don't need to
configure TCP/IP on the interface, to make it work.
When you have more than one network interface, it is
a good idea to use the "bind=" command line option to
qnet, so that it only transmits and recieves qnet
packets on the interface(s) that you want.
What I suspect is happening in your case, is some
timing problem, related to the initialization of
the USB wifi dongle. I suspect that if you delayed
the mounting of qnet a few seconds, that would also
fix the (timing related hardware) problem.
But six of one, half a dozen of the other.
aboyd www.PoweredByQNX.com
01/19/2009 1:29 PM
post20333
Hi Gordon:
My current guess is that when you do the soft re-boot, either
the USB hardware or the dongle is left in a state which is... ummmm...
less than optimal. QNET comes up, tries to initialize the dongle and
things end up getting stuck for whatever reason. We can continue on
with debugging if you'd like. At this stage we might want to look at
getting a shell out of the serial port. The problem is getting
visibility of what's happening under during the boot sequence...
Robert.
Sent: Monday, January 19, 2009 1:11 PM
chipset)
dongle.
chipset)
discovers.
just:
possible.
aboyd
General
- CONFIDENTIAL-
General
http://community.qnx.com/sf/go/post20329
01/19/2009 1:54 PM
post20341
We'll let this sleeping dog lie for now, and revisit it (if necessary)
if in the future we decide to ship a product with qnet enabled.
Thanks for all the help.
Sent: Monday, January 19, 2009 12:29 PM
chipset)
Hi Gordon:
Robert.
chipset)
dongle.
chipset)
discovers.
just:
possible.
aboyd
General
- CONFIDENTIAL-
General
General
http://community.qnx.com/sf/go/post20333
