Forum Topic - connect() retry returning EINVAL:
I'm porting a program to QNX that communicates via TCP. It tries to connect() to a server,  and retries connect() calls
until it is finally found. This program runs on Linux, even Windows, and others, but not on Neutrino. Here, only the
first connect() call fails with the expected ECONNREFUSED, but retries using the identical parameter list yield EINVAL,
even if the server has become available in the meantime.
I tried to find documentation about the differences in behaviour, but to no avail. Momentics help does not even mention
EINVAL to be a possible errno return code. Can somebody tell me why connect() behaves differently, and what to do about
it?
TIA
Christoph Nemmaier
RE: connect() retry returning EINVAL
Without the source, I can only guess the sockaddr you passed in, have a
wrong sa_len. The sockaddr MUST initilized like this:
	struct sockaddr_in sin;
	memset(&sin, 0, sizeof(sin));
	sin.sin_len = sizeof(sin);
	sin.sin_family = AF_FAMILY;
	sin.sin_port = ...
	sin.sin_addr = ...
-xtang
> From: Christoph Nemmaier [mailto:community-noreply@qnx.com]
> Sent: Wednesday, October 22, 2008 9:40 AM
> To: general-networking
> Subject: connect() retry returning EINVAL
> Hello,
> mention EINVAL to be a possible errno return code. Can
> to do about it?
> TIA
> Christoph Nemmaier
> http://community.qnx.com/sf/go/post15399
Re: connect() retry returning EINVAL
On Wed, Oct 22, 2008 at 09:40:22AM -0400, Christoph Nemmaier wrote:
> Hello,
calls until it is finally found. This program runs on Linux, even Windows, and others, but not on Neutrino. Here, only
the first connect() call fails with the expected ECONNREFUSED, but retries using the identical parameter list yield
EINVAL, even if the server has become available in the meantime.
mention EINVAL to be a possible errno return code. Can somebody tell me why connect() behaves differently, and what to
do about it?
> TIA
> Christoph Nemmaier
That's non standard behaviour.  The BSD's (and QNX) don't support it.
You have to close() and get a new socket.  See the following links.
http://mail-index.netbsd.org/tech-net/2003/06/17/0002.html
http://mail-index.netbsd.org/tech-net/2003/06/17/0003.html
> > Hello,
> ) to a server,  and retries connect() calls until it is finally found. This
> only the first connect() call fails with the expected ECONNREFUSED, but
> retries using the identical parameter list yield EINVAL, even if the server
> avail. Momentics help does not even mention EINVAL to be a possible errno
> to do about it?
> > TIA
> > Christoph Nemmaier
> Regards,
> -seanb
Thanks for the links. I now understand what the problem is, and of course, that (qouted from http://mail-index.netbsd.
org/tech-net/2003/06/17/0003.html):
> *BSD is the reference for socket behaviour, not Linux.
Thanks for your replies,
Christoph
