Forum Topic - unable to create more than 995 sockets filedescriptors:
hi
my program creates a number of active sockets transmitting data to a server at periodic intervals. I get the error
socket error : Too many open files // errno 24 EMFILE
( this happens at the 996th socket call )
when i try to create about a 1000 connections at the client side.
well i did check out the the ulimit which was set to 1000.
so i increased it up to 2000 using the ulimit -n 2000 command.
apart form that i also used the call setrlimit(RLIMIT_NOFILE, &curr_limits) where curr_limits contains  2000 for both
soft n hard limit.
the next call getrlimit returns 2000 for both.
but still in the next run i get the same error at the 996th socket call again.
i tried the getconf _SC_OPEN_MAX  it still showed 1000 as the o/p despite the ulimit showing 2000 as the limit.
any of u guys have a  idea as to what may be wrong or how to increase the fd limit.
regards,
Rosen.
Re: unable to create more than 995 sockets filedescriptors
On Wed, Oct 15, 2008 at 08:19:47AM -0400, Rosen Rosen wrote:
> hi
> apart form that i also used the call setrlimit(RLIMIT_NOFILE, &curr_limits) where curr_limits contains  2000 for both soft n hard limit.
> regards,
> Rosen.
Try the -F option to procnto.
Hi Sean,
i did try that out ..
i did  not find that utility so i proceeded to the  /proc/boot directory.
there was jus one executable procnto-instr
# procnto-instr -F 2000
sh: procnto-instr: Invalid argument
this is what i get ..
in case u wanna know abt the kernel ver n stuff here is the o/p for uname -a
 # uname -a
QNX EA2c74b9 6.3.2 2006/03/16-14:19:50EST x86pc x86
On Wed, Oct 15, 2008 at 08:46:52AM -0400, Rosen Rosen wrote:
> Hi Sean,
>  # uname -a
You need to rebuild you image.  See the following in the
helpviewer:
  QNX Neutrino RTOS
    Building Embedded Systems
      Making an OS Image
# cd /boot/build
# vi qnxbasedma.build
  < add -F 2000>
# cp /.boot /.altboot
# mkifs -v qnxbasedma.build /.boot
oh cool rebuild the stuff ( last time i crashed the system doing that LOL :)
thanks a lot Sean.
