Forum Topic - how to send packets over ethernet?:
hi,
i looked around, read the most postings, but doesn't get my problem solved.
i just want to send (periodicaly) packets using the lan-port of my board (i.mx31). just to get it work and understand
how ;)
could somebody please help me? i really didn't find a way for me in understanding that topic. i havn't done something
with networks before.
maybe somebody can give some simple samplecode that helps me to understand what i have to do and how it works.
it would be great!
thanks a lot!
RE: how to send packets over ethernet?
What kind of packets do you want to tx?  ie are
they IP or non-IP?  What is the ethertype?
aboyd
Re: RE: how to send packets over ethernet?
type is normal ipv4
and it should be IP-packets
ie realize a simple ping
RE: RE: how to send packets over ethernet?
The source to ping is under trunk/utils/p/ping
on the foundry.
Maybe also look at the source to ttcp?  It has
options for both tcp and udp.
You might want to look at some of these links:
http://www.google.ca/search?hl=en&q=socket+programming&meta=
aboyd
Hi Hannes:
	I think you have a bit of a steep learning curve ahead.  There
are two ways that are likely to be useful for you to use Ethernet.  One
is through Internet sockets.
(see http://en.wikipedia.org/wiki/Berkeley_sockets)
The other is through our proprietary QNET protocol.
(http://www.qnx.com/developers/docs/6.3.0SP3/neutrino/sys_arch/qnet.html
	Robert.
From: Hannes Bock [mailto:community-noreply@qnx.com]
Sent: Thursday, August 07, 2008 5:23 AM
To: general-networking
Subject: how to send packets over ethernet?
hi,
solved.
(i.mx31). just to get it work and understand how ;)
understanding that topic. i havn't done something with networks before.
it would be great!
thanks a lot!
General
http://community.qnx.com/sf/go/post11514
thanks for the links!
i think qnet is a little bit to powerfull for my purposes.
i'll try the udp "hello world"-example from wikipedia, this should be completely sufficiently.
is there anything to consider or to adapt for qnx?
thanks a lot for the help!
hi,
i tried the "hello world"-udp example and it works fine ... but not for long :o(
after sending about 3000 packtets the bord hangs.
if I put a sleep(1) after sending the first packet i become the only packet which is send.
any idea what's the problem? maybe something with the buffers?
here ist the code:
void  myNetwork_thread ()
    int sock;
    struct sockaddr_in sa;
    int bytes_sent, buffer_length;
    char buffer[200];
    int pongcount=1;
    sprintf(buffer, "pingpong");
    buffer_length = strlen(buffer) + 1;
    sock = socket(PF_INET, SOCK_DGRAM, IPPROTO_UDP);
    if(-1 == sock) /* if socket failed to initialize, exit */
      printf("Error Creating Socket");
      /*return 0;*/
    sa.sin_family = PF_INET;
    sa.sin_addr.s_addr = htonl(0xC0A81E86);
    sa.sin_port = htons(7654);
    printf("ping");
    while(1)
       bytes_sent = sendto(sock, buffer, buffer_length, 0,(struct sockaddr*) &sa, sizeof(struct sockaddr_in) );
       if(bytes_sent < 0)
         printf("Error sending packet: %s\n", strerror(errno) );
       printf("pong %i\n", pongcount++);
    close(sock); /* close the socket */
   return 0;
What network card / driver are you running?  What
is the nicinfo output?  Esp if you start the driver
with the verbose option, what is the sloginfo output?
Aboyd
Re: RE: RE: how to send packets over ethernet?
i only used the bsp for my bord (i.mx31) and then tryed to build my application. i didn't start the driver specialy "by
hand".
the output from nicinfo and sloginfo is attached
Attachment: Text nicinfo.txt 1 KB
RE: RE: RE: how to send packets over ethernet?
That appears to be truncated - I don't see any
sloginfo output, and even the nicinfo output is
not complete.
But I do see that you are running the crys 8900
nic.  That driver has had numerous fixes over the
years, but I don't think was ever released.
Would you be interested in a test binary of a newer
version?  What cpu (x86, ppcbe, etc) are you running
on?
aboyd
Re: RE: RE: RE: how to send packets over ethernet?
it's an i.mx31 with an arm9 cpu
here the complete output:
nicinfo
Crystal 89xx Ethernet Controller
  Physical Node ID ........................... 00049F 00396B
  Current Physical Node ID ................... 00049F 00396B
  Current Operation Rate ..................... 10.00 Mb/s half-duplex
  Active Interface Type ...................... UTP
  Maximum Transmittable data Unit ............ 1514
  Maximum Receivable data Unit ............... 1514
  Hardware Interrupt ......................... 0xa8
  I/O Aperture ............................... 0xb4020300 - 0xb402031f
  Packets Transmitted OK ..................... 90
  Bytes Transmitted OK ....................... 11155
  Memory Allocation Failures on Transmit ..... 0
  Packets Received OK ........................ 91
  Bytes Received OK .......................... 5752
  Memory Allocation Failures on Receive ...... 0
  Single Collisions on Transmit .............. 0
  Transmits aborted (excessnicinfo
  Packets Transmitted OK ..................... 36
  Bytes Transmitted OK ....................... 3730
  Packets Received OK ........................ 34
  Bytes Received OK .......................... 2149
  Transmits aborted (excessive collisions) ... 0
  No Carrier on Transmit ..................... 0
  Receive Alignment errors ................... 0
  Received packets with CRC errors ........... 0
  Oversized Packets received ................. 0
  Short packets .............................. 0
  Squelch Test errors ........................ 0
# sloginfo
Jan 01 00:00:00    5    14     0 tcpip starting
Jan 01 00:00:00    3    14     0 Using pseudo random generator.  See "random" option
RE: RE: RE: RE: how to send packets over ethernet?
Is the driver devn-crys8900-mx31ads.so?
The output of "pidin -p io-net mem"
will tell the story ....
aboyd
Re: RE: RE: RE: RE: how to send packets over ethernet?
it's rys8900-mx31ads.so
Attachment: Text pidin.txt 823 bytes
Hmmm... You're probably filling the socket buffers, erroring out in the
sendto and putting yourself into a constant loop.  Add a sleep (or exit)
in to let the buffer drain (as below)
       if(bytes_sent < 0) {
         sleep(2);
  Robert.
Sent: Thursday, August 21, 2008 6:54 AM
Subject: Re: RE: how to send packets over ethernet?
hi,
long :o(
here ist the code:
    int sock;
    char buffer[200];
    int pongcount=1;
      /*return 0;*/
    printf("ping");
    while(1)
       if(bytes_sent < 0)
   return 0;
General
http://community.qnx.com/sf/go/post12167
i allready tried it with a sleep at this point.
but then only one packet is send before the system hangs.
I'm curious as to what you mean by "hangs".  I strongly suspect that
what you are actually seeing is your application spinning in a loop that
prevents anything else from working.
What happens if you move the sleep(1) into the main body of the loop
(i.e. only sending one packet per second).  It's also possible that the
driver has a bug that results in it locking up if you hit it too hard...
	Robert.
Sent: Thursday, August 21, 2008 10:43 AM
Subject: Re: RE: RE: how to send packets over ethernet?
General
http://community.qnx.com/sf/go/post12199
i tried the sleep in the loop but after one packet nothing will work anymore.
even the IDE lost the connection to the board. that's why i think the bord hangs.
maybe it's an problem with the driver as andrew suspected.
Re: how to send packets over ethernet?
solved!!!
it was my failure!
by chaning my main one bracket slipped on a wrong position.
now it works fine!
thanks for all the help!!!
"the error was between the headphones!" ;o)
