FILE EXISTS error on setting IPV4 address using ioctl
12/05/2018 3:20 AM
post119317
I am getting a File exists error on using the SIOCSIFADDR ioctl command to set IP address ,but the IP address is changed
to the requested value. Why the error occurs?
bool setIpv4Address(std::string interfaceName,std::string ipAddr)
struct sockaddr_in sin;
int sockFd;
std::string Ip;
struct ifreq ifr;
bool retStatus;
memset(&ifr, 0x00, sizeof(ifr));
memset(&sin, 0x00, sizeof(sin));
retStatus = true;
sin.sin_family = AF_INET;
sin.sin_len = sizeof(sin);
/// check valid ip
if (inet_aton(&ipAddr[0], &sin.sin_addr) == 0)
retStatus = false;
else
/// Create socket for INET and update the address information.
strcpy(ifr.ifr_name, &interfaceName[0]);
memcpy(&ifr.ifr_addr, &sin, sizeof(ifr.ifr_addr));
if ((sockFd = socket(AF_INET, SOCK_DGRAM, 0)) != -1)
/// Set IP address using SIOCSIFADDR ioctl flag.
if (ioctl(sockFd, SIOCSIFADDR, &ifr) != -1)
/// Set Interface Up
/// Get ifreq.flags
ioctl(sockFd, SIOCGIFFLAGS, &ifr);
ifr.ifr_flags |= (IFF_UP| IFF_RUNNING);
if(ioctl(sockFd, SIOCSIFFLAGS, &ifr) == -1)
perror("Interface link status change failed");
retStatus = false;
else
perror("setIpv4Address Setting IPV4 address Error :");
retStatus = false;
else
perror("Socket creation failed ");
retStatus = false;
close (sockFd);
return retStatus;
General
http://community.qnx.com/sf/go/post119316
To cancel your subscription to this discussion, please e-mail general-networking-unsubscribe@community.qnx.com
