Forum Topic - devc-serpci - problem:
I am running the devc-serpci driver with a Kontron card (CP346)  vid=0x1415, did=0x9501 which is presumably compatible
with this driver. When reading there is no problem but when I am sending data the only way to get the data trough is to
write 16 bytes at the time and flush the output. As you can imagine this is slower than sucking melasa through  a straw.
Can anyone give me some hints I found this problem was reported before but none one addresses it.
(http://community.qnx.com/sf/discussion/do/listPosts/projects.bsp/discussion.bsp.topc7626).
Running QNX version 6.5.
Thank you,
Javier
Settings:
    handle_ = ::open(config_.modem_device_.c_str(), O_RDWR | O_NOCTTY | O_NONBLOCK, 0);
    memset(&options, 0x00, sizeof(options));
    options.c_cflag |= (CLOCAL | CREAD);
    options.c_cflag &= ~PARENB;
    options.c_cflag &= ~CSTOPB;
    options.c_lflag &= ~(ICANON | ECHO | ECHOE | ISIG);
    options.c_oflag &= ~OPOST;
    options.c_iflag &= ~(IXON | IXOFF | IXANY);
    options.c_cc[VMIN]   = 0;
    options.c_cc[VTIME]  = 0;
