SSH and Slinger (Web) through a DSL router
02/08/2013 4:50 PM
post99189
<font face="Default Sans Serif,Verdana,Arial,Helvetica,sans-serif" size="2">I have an Actiontec Q2000 DSL modem, with a
QNX system connected to the internal network. I set up the modem to forward ports 22 & 80 to the IP address of the QNX
system. Neither ssh or web is visible externally when set up this way. I also have a Linux box on the same network, and
if I forward the same ports to that machine, I can do ssh and web externally. On the internal network, I can ssh and do
web to the QNX system. I allow port forwarding in the sshd_config file (which should not matter). I am running QNX 6.4.1
on a custom ARM system. Any help would be appreciated.<div><br></div><div>Thanks,</div><div>Todd Peterson</div><div></
div></font>
