Forum Topic - 6.5.0 SP1 io-pkt is not binary compatible for filter modules (ALTQ):
we just loose hours searching a problem in our ethercat filter (lsm-ecat.so) with following result:
6.5.0 io-pkt is complied without "ALTQ".
6.5.0SP1  io-pkt is complied with "ALTQ".
Why is ALTQ not defined per default in SP1?
If so, recompiling an  lsm  under 6.5.0 SPI would show up the changes at once.
Following release note
"The io-pkt* manager now supports the ALTQ feature. You can use pfctl to manage it. (Ref# 107832, 142280) "
does not tell you: "Recompile your LSM's with -DALTQ. We have changed the binary Interface!"
Regards
Michael
