Forum Topic - Multiple Ethernet cause io-net freeze the console:
I have 3 of RTL8139C+ on one PCI bus. The PCI number are line up with 0x0, 0x1, and 0x2. Each card can load properly
with:
io-net -d rtl pci=0xX -p tcpip
But I can't make all three cards working at the same time. The console freezes when I load more than 1 card at the same
time. Is this a driver issue? or NIC EEPROM issue?
Re: Multiple Ethernet cause io-net freeze the console
If you specify pci=0xX, the driver will only start on one interface. If you
remove the pci=0xX from the command line, all interfaces will be started.
> 0x1, and 0x2. Each card can load properly with:
> when I load more than 1 card at the same time. Is this a driver issue? or NIC
> EEPROM issue?
> http://community.qnx.com/sf/go/post84213
Kanata, Ontario, Canada.
K2M 1W8
