Forum Topic - Qnet not working with 6.5.0 APIC Image:
We have two ‘new’ computers running the 6.5.0 APIC image. These two machines are connected together through a simple
Linksys (Cisco) switch. Unfortunately, from a Qnet standpoint, each machine is an island and can’t detect its peer. I’
ve attached the Qnet troubleshooting information for the two machines. Any insights into why these two machines can’t
see each other? The network adapters seem to be working; I collected the troubleshooting information using a PuTTY
session from my laptop. Thanks.
Mark
P.S. At the request of our FAE, I tried connecting the two machines together using a crossover cable, same problem.
Attachment: Text mcc210.log 6.47 KB Text mcc212.log 6.44 KB
Re: Qnet not working with 6.5.0 APIC Image
Does an Œls /net¹ show anything on either of the machines? It appears that
the network adapters are working fine from the output that you sent.
On 10-10-26 2:05 PM, "Mark Dowdy" <community-noreply@qnx.com> wrote:
> We have two Œnew¹ computers running the 6.5.0 APIC image. These two machines
> are connected together through a simple Linksys (Cisco) switch. Unfortunately,
> from a Qnet standpoint, each machine is an island and can¹t detect its peer.
> I¹ve attached the Qnet troubleshooting information for the two machines. Any
> insights into why these two machines can¹t see each other? The network
> a PuTTY session from my laptop. Thanks.
> Mark
> http://community.qnx.com/sf/go/post72486
Kanata, Ontario, Canada.
K2M 1W8
There's only one entry in the /net directory of each machine, the local machine name.
Mark
Are you running with regular MTU sizes ­ ie 1514? Can you ping each machine
from the other?
> machine name.
> Mark
> http://community.qnx.com/sf/go/post72490
K2M 1W8
As far as I know we're running with regular MTU sizes; I didn't do anything to change them. nicinfo for wm0 on both
machines lists the maximum transmit and receive data units as 1500.
There does appear to be connectivity between the machines. Each machine can successfully ping the other and I can telnet
 from one to the other.
Mark
Do you have more than one network interface on each machine? If so, how many
and how are you starting qnet?
> change them. nicinfo for wm0 on both machines lists the maximum transmit and
> successfully ping the other and I can telnet from one to the other.
> Mark
> http://community.qnx.com/sf/go/post72499
K2M 1W8
There are four network interfaces on each machine but only one of the four has been configured with an IP address.
To start Qnet, we touched /etc/system/config/useqnet so we're picking up 'mount -Tio-pkt lsm-qnet.so' from /etc/system/
sysinit.
Mark
OK, please try the following on each machine:
slay io-pkt-v4-hc
io-pkt-v4-hc ­de1000
mount ­Tio-pkt ­obind=wm0 lsm-qnet.so
This will start the Ethernet driver and mount qnet on just the first
interface on each machine. You should now be able to see the other machine
under /net.
> 'mount -Tio-pkt lsm-qnet.so' from /etc/system/sysinit.
> Mark
> http://community.qnx.com/sf/go/post72510
K2M 1W8
That did it, thanks for your help.
Out of curiosity, why is there a problem starting Qnet on all interfaces?
Mark
AFAIK, qnet defaults to a maximum of 2 interfaces and it was most probably
starting on the incorrect 2 interfaces. Glad its working.
> Mark
> http://community.qnx.com/sf/go/post72535
K2M 1W8
What does this mean from /proc/qnetstats
00210534  l4_driver_init_en_iopkt(): can't find interfaces (12) (Server fault on msg pass)
00210534  l4_init(): l4_driver_init() failed
Anytime something fails, that can't be good.
Mark
