09/03/2010 5:22 PM
post66007
When I use option io-pkt-v4 -de1000 -pqnet -tcpip mclbytes=8192,pagesize=8192 qnet will not work. I can see the other
machines in /net, the other machines can see them machine. Any operation like pidin or ls will never return (even after
5 minutes)
Even weirder is that the program that is block on the other machine, being ls or pidin is not in a REPLY stated but in a
RUNNING stated ???
If I get rid of the mclbytwes options everything is fine. All this time tcpip works ok.
- Mario
RE: qnet 6.5.0 and mclbytes
09/04/2010 7:36 AM
post66018
Try manually specifying the correct MTU to qnet
on the command line. I suspect it is trying to
guess it, and is getting it wrong.
aboyd
Sent: Fri 9/3/2010 2:22 PM
To: general-networking
Subject: qnet 6.5.0 and mclbytes
5 minutes)
RUNNING stated ???
- Mario
General
http://community.qnx.com/sf/go/post66007
09/07/2010 12:06 PM
post66149
I already tried that, (mtu_en=1500) and that didn`t help. Further more /proc/qnetstat shows mtu to be 1496.
What I do not understand is that this problem showed up with a new computer model we are evaluating, but the image we
are using is the same as with our other model. Maybe I'm looking at bad hardware. Will keep you posted.
Thank you.
-----Message d'origine-----
De : Andrew Boyd [mailto:community-noreply@qnx.com]
Envoyé : 4 septembre 2010 07:36
À : general-networking
Objet : RE: qnet 6.5.0 and mclbytes
Try manually specifying the correct MTU to qnet on the command line. I suspect it is trying to guess it, and is getting
it wrong.
aboyd
5 minutes)
RUNNING stated ???
- Mario
General
General
http://community.qnx.com/sf/go/post66018
09/07/2010 12:08 PM
post66151
Qnet logs from both sides would help.
aboyd
09/07/2010 3:05 PM
post66181
I have some other information. The motherboard has two build in NIC and we add another card with two NIC. The addon
card has vendor id 10c9 and internal is 10a7 (all intel).
With both devices, to get tcpip to work I have to disable all capabilities; checksum sand tso4. These are enabled by
default in our boot procedure if the capabilities are supported.
With the build-in NIC we can set mclbytes at 9016 and it works but on the external card it fails.
In the zip file you will find attached four files:
- Pci.txt output of pci -v
- Other.txt content of /proc/qnetstats on an older and "reliable" machine ( the one I'm trying to access
- Ok.txt content of /proc/qnetstats on the bad machine without setting mclbytes
io-pkt-v4 -t4 -de1000 transmit=2048,receive=2048,priority=100 -pqnet bind=wm0,no_slog=1,periodic_ticks=100,tx_retries=50
- Bad.txt content of /proc/qnetstats on the bad machine with setting mclbytes and pagesize to 9016
-ptcpip mclbytes=9016,pagesize=9016
That being said Andrew so far we really like this machine aside from that issue. It's long life ( 7 years) so we would
be willing to invest some money and have QNX look into this. In the short term we can live with the situation by using
use the internal NIC for qnet and disabling all of the NICs capabilities.
This is with 6.5.0.
Cheers,
Envoyé : 7 septembre 2010 12:09
aboyd
General
http://community.qnx.com/sf/go/post66151
09/07/2010 3:13 PM
post66186
I have forwarded this to Hugh to look at when he
gets back from vacation. Sounds like another e1000
variation!
Sent: Tuesday, September 07, 2010 3:05 PM
Subject: RE: qnet 6.5.0 and mclbytes
This is with 6.5.0.
Cheers,
aboyd
General
General
http://community.qnx.com/sf/go/post66181
09/07/2010 4:45 PM
post66208
Much appreciated!
Envoyé : 7 septembre 2010 15:14
I have forwarded this to Hugh to look at when he gets back from vacation. Sounds like another e1000 variation!
This is with 6.5.0.
Cheers,
aboyd
General
General
General
http://community.qnx.com/sf/go/post66186
Re: qnet 6.5.0 and mclbytes
09/13/2010 9:03 AM
post66919
Do you specify the MTU size with ifconfig? Unfortunately I don't have one of
these adapters to try and reproduce the problem.
> add another card with two NIC. The addon card has vendor id 10c9 and internal
> checksum sand tso4. These are enabled by default in our boot procedure if the
> mclbytes
> bind=wm0,no_slog=1,periodic_ticks=100,tx_retries=50 -ptcpip
> issue. It's long life ( 7 years) so we would be willing to invest some money
> by using use the internal NIC for qnet and disabling all of the NICs
> capabilities.
> This is with 6.5.0.
> Cheers,
> aboyd
General
http://community.
Hugh Brown (613) 591-0931 ext. 2209 (voice)
QNX Software Systems Ltd. (613) 591-3579 (fax)
175 Terence Matthews Cres. email: hsbrown@qnx.com
Kanata, Ontario, Canada.
K2M 1W8
09/13/2010 9:42 AM
post66933
Yes the MTU size is specify with ifconfig
We could send you the machine if you'd like ;-) We also have trouble with startup-apic/pci-bios-v2 that make the
computer reboot as soon as the image starts.
De : Hugh Brown [mailto:community-noreply@qnx.com]
Envoyé : 13 septembre 2010 09:04
Objet : Re: qnet 6.5.0 and mclbytes
Do you specify the MTU size with ifconfig? Unfortunately I don't have one of these adapters to try and reproduce the
problem.
> and we add another card with two NIC. The addon card has vendor id
> capabilities; checksum sand tso4. These are enabled by default in our
> mclbytes
> that issue. It's long life ( 7 years) so we would be willing to invest
> with the situation by using use the internal NIC for qnet and
> This is with 6.5.0.
> Cheers,
> aboyd
General
http://community.
K2M 1W8
General
http://community.qnx.com/sf/go/post66919
09/13/2010 9:45 AM
post66934
Yes, if you could send me the machine, that would help.
Thanks, Hugh.
> startup-apic/pci-bios-v2 that make the computer reboot as soon as the image
> starts.
>> mclbytes
>> This is with 6.5.0.
>> Cheers,
>> aboyd
>> General
> http://community.
K2M 1W8
09/13/2010 9:57 AM
post66937
Awesome, we'll send it to you next week as we only have one machine and still need it for further testing/validation ,
we will receive the others Friday.
Mario
Envoyé : 13 septembre 2010 09:46
Thanks, Hugh.
> with
> image starts.
> one of these adapters to try and reproduce the problem.
>> setting mclbytes
>> can live with the situation by using use the internal NIC for qnet
>> This is with 6.5.0.
>> Cheers,
>> aboyd
>> General
> http://community.
K2M 1W8
