Forum Topic - No network statistics available:
I managed to setup networking with a self build core networking. Both Intel e1000 cards in my machine are recognized and
 it's possible to set up IP addresses and ping other machines.
The following problems arose:
* no information can be set/read via sysctl:
# sysctl -w net.inet.ip.forwarding=1
sysctl: top level name 'net' in 'net.inet.ip.forwarding' is invalid
# sysctl -a
* netstat and sockstat return with errors:
# netstat
netstat: sysctlnametomib: net.inet.tcp.pcblist: Invalid argument
# sockstat
sockstat: sysctlnametomib: net.inet.tcp.pcblist: Invalid argument
* ifconfig spits out various errors/warnings:
# ifconfig -a
lo0: flags=8009<UP,LOOPBACK,MULTICAST> mtu 33212
        capabilities=7<IP4CSUM,TCP4CSUM,UDP4CSUM>
        enabled=0
ifconfig: SIOCGIFADDRPREF: Invalid argument
en0: flags=8c43<UP,BROADCAST,RUNNING,OACTIVE,SIMPLEX,MULTICAST> mtu 1500
        enabled=0
        address: 00:04:23:c3:91:0a
ifconfig: SIOCGIFADDRPREF: Operation not supported
        inet 192.168.1.100 netmask 0xffffff00 broadcast 192.168.1.255
en1: flags=8c43<UP,BROADCAST,RUNNING,OACTIVE,SIMPLEX,MULTICAST> mtu 1500
        enabled=0
        address: 00:19:d1:29:f6:9c
        inet 192.168.2.100 netmask 0xffffff00 broadcast 192.168.2.255
Am I missing something important? The following tasks are running:
# pidin
     pid tid name               prio STATE       Blocked
       1   1 proc/boot/procnto    0f READY
       1   2 proc/boot/procnto  255r RECEIVE     1
       1   3 proc/boot/procnto  255r RECEIVE     1
       1   4 proc/boot/procnto   10r RUNNING
       1   5 proc/boot/procnto  255r RECEIVE     1
       1   6 proc/boot/procnto   10r RECEIVE     1
       1   7 proc/boot/procnto   10r RECEIVE     1
       1   8 proc/boot/procnto   10r RECEIVE     1
       1   9 proc/boot/procnto   10r RECEIVE     1
       1  10 proc/boot/procnto   10r RECEIVE     1
       1  11 proc/boot/procnto   10r RECEIVE     1
       2   1 /boot/devc-ser8250  10r RECEIVE     1
       3   1 proc/boot/pci-bios  10r RECEIVE     1
       4   1 roc/boot/devb-eide  10r SIGWAITINFO
       4   2 roc/boot/devb-eide  21r RECEIVE     1
       4   3 roc/boot/devb-eide  10r RECEIVE     7
       4   4 roc/boot/devb-eide  10r RECEIVE     4
       4   5 roc/boot/devb-eide  10r RECEIVE     4
       4   6 roc/boot/devb-eide  10r RECEIVE     4
       4   7 roc/boot/devb-eide  10r RECEIVE     4
       4   8 roc/boot/devb-eide  10r RECEIVE     4
   16389   1 proc/boot/io-net    10r SIGWAITINFO
   16389   2 proc/boot/io-net    21r RECEIVE     5
   16389   3 proc/boot/io-net    10r RECEIVE     1
   16389   4 proc/boot/io-net    10r RECEIVE     1
   16389   5 proc/boot/io-net    10r RECEIVE     1
   16389   6 proc/boot/io-net    21r RECEIVE     9
   16389   7 proc/boot/io-net    20r RECEIVE     13
   28678   1 proc/boot/pipe      10r SIGWAITINFO
   28678   2 proc/boot/pipe      10r RECEIVE     1
   28678   3 proc/boot/pipe      10r RECEIVE     1
   28679   1 proc/boot/mqueue    10r RECEIVE     1
   28680   1 proc/boot/devc-pty  10r RECEIVE     1
   28681   1 proc/boot/esh       10r REPLY       1
  204810   1...
Re: No network statistics available
On Fri, Nov 30, 2007 at 07:01:22AM -0500, Alexander Senier wrote:
> Intel e1000 cards in my machine are recognized and it's possible to set
> # sysctl -a
> # netstat
> # sockstat
> # ifconfig -a
>         enabled=0
>         enabled=0
>         enabled=0
> # pidin
<snip>
You need to run the new utilities against the new stack: io-pkt-*.
RE: No network statistics available
You can also take a look here for more information on how to use the new
stack:
http://community.qnx.com/sf/wiki/do/viewPage/projects.networking/wiki/Source
_Guide
(note the comments about setting the LD_LIBRARY_PATH and PATH vars at the
bottom)
	Robert.
Sent: Friday, November 30, 2007 9:45 AM
To: general-networking
Subject: Re: No network statistics available
> # sysctl -a
> # netstat
> # sockstat
> # ifconfig -a
>         enabled=0
>         enabled=0
>         enabled=0
> # pidin
<snip>
General
http://community.qnx.com/sf/go/post3157
