6.5 M9 network stop working
07/13/2010 1:58 PM
post59331
Driver is e1000, at some point in time networking stops working, TCP and QNET. The only think that I see which is weird
is nicinfo will report 1 Memory Allocation Failure on transmit.
In nicinfo number of TX packet isn`t increasing but RX is. If I rmdir /net I can see new names showing up so it`s
definitely receiving stuff.
Tx and Rx descriptors are set at 2048.
Re: 6.5 M9 network stop working
07/14/2010 1:45 AM
post59374
I dont know much about e1000 but network drivers normally create a buffer
pool from which buffer is picked for transmission. On successful transmit,
tx_done callback is called which should return this buffer to back to pool.
Similarly, if tx fails at driver, it should return the buffer to pool or
free it.
In your case, it seems that buffer used for transmission has not been
cleaned up or returned to pool properly. So, after sometime driver runs out
of buffers from transmission.
In simple words, it looks like a memory leak!!
HTH
VG
On Tue, Jul 13, 2010 at 11:28 PM, Mario Charest
> QNET. The only think that I see which is weird is nicinfo will report 1
> I can see new names showing up so it`s definitely receiving stuff.
> http://community.qnx.com/sf/go/post59331
07/14/2010 8:51 AM
post59394
Does this happen regularly? Does 'pidin mem' show the memory usage
increasing or does it remain static?
> The only think that I see which is weird is nicinfo will report 1 Memory
Hugh Brown (613) 591-0931 ext. 2209 (voice)
QNX Software Systems Ltd. (613) 591-3579 (fax)
175 Terence Matthews Cres. email: hsbrown@qnx.com
Kanata, Ontario, Canada.
K2M 1W8
07/14/2010 8:55 AM
post59395
mbuf memory usage can be monitored using 'netstat -m' as well.
/P
RE: 6.5 M9 network stop working
07/14/2010 9:21 AM
post59405
When our application starts doing some TCP stuff it happens within 5 minutes. The machine has 8 Gig when the problem
occurs there is still 7.7Gig left.
We start io-pkt-v4 like this:
io-pkt-v4 -t4 -de1000 transmit=2048,receive=2048 -pqnet
Network is 100Mbits, cpu dual core 1.8Gig. 6.5.0 is setup to use APIC.
Before starting the application io-pkt-v4 is using 5.3 Meg.
When application is running and network is ok netstat -m reports:
2105 mbufs in use
2094 mbufs allocated to data
11 mbufs allocated to packet header
0 calls to protocol drain runtimes
When crashed it says
4596 mbufs in use
3379 mbufs allocated for data
1167 mbuf allocated to packet header
0 calls to prodotoc drain runtimes
Io-pkt-v4 is using 7.1 Meg
Just in case it matters we are setting the kernel nmbclusters to 32000
-----Message d'origine-----
De : Hugh Brown [mailto:community-noreply@qnx.com]
Envoyé : 14 juillet 2010 08:51
À : general-networking
Objet : Re: 6.5 M9 network stop working
Does this happen regularly? Does 'pidin mem' show the memory usage increasing or does it remain static?
> /net I can see new names showing up so it`s definitely receiving stuff.
K2M 1W8
General
http://community.qnx.com/sf/go/post59394
07/14/2010 9:30 AM
post59408
If you slay pci-bios and restart it as 'pci-bios-v2 -M', then restart the
network and your application, does the problem still occur?
> The machine has 8 Gig when the problem occurs there is still 7.7Gig left.
> 2105 mbufs in use
> 4596 mbufs in use
>> QNET.
>> General
K2M 1W8
07/14/2010 10:33 AM
post59421
No change in behaviour aside pidin irq showing interrupts were all assigned to interrupts below 0x17
Envoyé : 14 juillet 2010 09:30
If you slay pci-bios and restart it as 'pci-bios-v2 -M', then restart the network and your application, does the problem
still occur?
> 2105 mbufs in use
> 4596 mbufs in use
>> and QNET.
>> rmdir /net I can see new names showing up so it`s definitely receiving stuff.
>> General
K2M 1W8
General
http://community.qnx.com/sf/go/post59408
07/14/2010 10:41 AM
post59424
Please post the output from 'pci -vv' as well as an explanation of what your
TCP application is doing.
>> 2105 mbufs in use
>> 4596 mbufs in use
>>> and QNET.
>>> stuff.
>>> General
K2M 1W8
07/14/2010 11:20 AM
post59435
The application is rather simple and is used on other system ( 6.4.1 although we have noted problem when there is a high
throughput ). However under 6.4.1 we have no clue to provide aside networking dies.
The application is multi-thread. The main process wait for a connections, upon detection a new connection a thread is
started to handle the connection. The pseudo-code for the thread look like this:
- Set receive timeout to 0
- Wait for one byte
- Set receive timeout to 5 seconds
- Until receive buffer is empty
- Call ioctl(FIONREAD, result) to get number of byte in receive buffer
- Call recv with number of byte to read
- The buffer should contain information about the number of bytes to expect (in the first 4 bytes)
- Until receive all data
Recv
- SendMsg data to QNX app
- Take the reply data and do a send() on the socket
- start from the top
This is program acts as a bridge between windows and the QNX applications.
Envoyé : 14 juillet 2010 10:41
Please post the output from 'pci -vv' as well as an explanation of what your TCP application is doing.
> the network and your application, does the problem still occur?
>> 2105 mbufs in use
>> 4596 mbufs in use
>> 32000
>>> and QNET.
>>> receiving stuff.
>>> Tx and Rx descriptors are set at...
07/14/2010 11:22 AM
post59436
Woops forgot the pci -vv output
PCI version = 3.00
Class = Bridge (Host/PCI)
Vendor ID = 8086h, Intel Corporation
Device ID = 2990h, 82Q963/Q965 Memory Controller Hub
PCI index = 0h
Class Codes = 060000h
Revision ID = 2h
Bus number = 0
Device number = 0
Function num = 0
Status Reg = 2090h
Command Reg = 106h
I/O space access disabled
Memory space access enabled
Bus Master enabled
Special Cycle operations ignored
Memory Write and Invalidate disabled
Palette Snooping disabled
Parity Error Response disabled
Data/Address stepping disabled
SERR# driver enabled
Fast back-to-back transactions to different agents disabled
PCI INTx enabled
Latency Timer = 0h
Cache Line Size= 0h
Subsystem Vendor ID = 17aah
Subsystem ID = 1011h
Max Lat = 0ns
Min Gnt = 0ns
PCI Int Pin = NC
Interrupt line = 0
CPU Interrupt = 0h
Capabilities Pointer = e0h
Capability ID = 9h - Vendor Specific
Capabilities = 5109h - 4800036eh
Device Dependent Registers:
0x040: 0190 f1fe 0000 0000 0040 d1fe 0000 0000
0x050: 0000 3000 0900 0000 0000 0000 0000 0000
0x060: 0100 00e0 0000 0000 0180 d1fe 0000 0000
0x070: 0000 0000 0000 0000 0000 0000 0000 0000
0x090: 1011 1100 0011 1100 8000 8c00 001a 3900
0x0a0: 8000 4023 0000 80bf 0000 0000 0000 70bf
0x0b0: 00c0 0000 0000 0000 0000 0000 0000 0000
0x0c0: 0000 0000 0000 0000 0000 0000 0000 0000
0x0d0: 0000 0000 0000 0000 4900 0000 0005 0213
0x0e0: 0900 0951 6e03 0048 060c 0000 0000 0000
0x0f0: 0200 0000 0000 0000 900f 0400 0000 0000
Class = Display (VGA)
Device ID = 2992h, 82Q963/Q965 Integrated Graphics Controller
PCI index = 0h
Class Codes = 030000h
Revision ID = 2h
Bus number = 0
Device number = 2
Function num = 0
Status Reg = 90h
Command Reg = 7h
I/O space access enabled
Bus Master enabled
SERR# driver disabled
PCI INTx enabled
Latency Timer = 0h
Cache Line Size= 0h
BAR - 0 [Mem] = d0000000h 32bit length 1048576 enabled
BAR - 2 [Mem] = c0000000h prefetchable 64bit length 268435456 enabled
BAR - 4 [I/O] = 3400h length 8 enabled
Max Lat = 0ns
Min Gnt = 0ns
PCI Int Pin = INT A
Interrupt line = 11
CPU Interrupt = bh
Capabilities Pointer = 90h
Capability ID = 5h - Message Signaled Interrupts
Capabilities = 0h - 0h
Capability ID = 1h - Power Management
Capabilities = 22h - 0h
0x040: 0000 0000 e000 0000 0900 0951 6e03 0048
0x050: 060c 3000 0900 0000 0000 0000 0000 80bf
0x060: 0000 0200 0000 0000 0000 0000 0000 0000
0x090: 05d0 0000 0000 0000 0000 0000 0000 0000
0x0a0: 1111 0000 0000 0000 0000 0000 0000 0000
0x0b0: 0000 0000 0000 0000 0000 0000 0000 0000
0x0c0: 0000 0000 0f0f 071e 8000 1008 bc01 0000
0x0d0: 0100 2200 0000 0000 0000 0000 0001 0200
0x0e0: 0000 0000 0000 0000 0000 0000 0000 0000
0x0f0: 3400 0300 0000 0000 900f 0400 fcb6 6cbf
Class = Serial Bus (Universal Serial Bus)
Device ID = 2834h, 82801H (ICH8 Family) USB UHCI Controller #4
PCI index ...
07/14/2010 11:33 AM
post59438
Does this problem occur if you run 6.4.1?
> PCI version = 3.00
> PCI index = 0h
> Revision ID = 2h
> Bus number = 0
> Device number = 0
> Function num = 0
> Status Reg = 2090h
> Command Reg = 106h
> Bus Master enabled
> PCI INTx enabled
> Latency Timer = 0h
> Cache Line Size= 0h
> Max Lat = 0ns
> Min Gnt = 0ns
> PCI Int Pin = NC
> Interrupt line = 0
> CPU Interrupt = 0h
> PCI index = 0h
> Revision ID = 2h
> Bus number = 0
> Device number = 2
> Function num = 0
> Status Reg = 90h
> Command Reg = 7h
> Bus Master enabled
> PCI INTx enabled
> Latency Timer = 0h
> Cache Line Size= 0h
> Max Lat = 0ns
> Min Gnt = 0ns
> PCI Int Pin = INT A
> Interrupt line = 11
> CPU Interrupt = bh
> 0x060: 0000 0200...
07/14/2010 1:12 PM
post59449
Yes it does. We changed network card in case it was somehow hardware related no change. We have limited the TCP multi-
thread application to one thread only. The Windows software was also modify to change rate of polling, which is now .5
secondes. About 120K of data is send to the Windows machine every .5 sec. Networking stopped after transferring a total
of 10Meg. During the first 30 sec netstat -m showed a steady count then after a while is start climbing from 2M to 4M
until is stopped.
Envoyé : 14 juillet 2010 11:34
> PCI version = 3.00
> PCI index = 0h
> Revision ID = 2h
> Bus number = 0
> Device number = 0
> Function num = 0
> Status Reg = 2090h
> Command Reg = 106h
> Bus Master enabled
> PCI INTx enabled
> Latency Timer = 0h
> Cache Line Size= 0h
> Max Lat = 0ns
> Min Gnt = 0ns
> PCI Int Pin = NC
> Interrupt line = 0
> CPU Interrupt = 0h
> PCI index = 0h
> Revision ID = 2h
> Bus number = 0
> Device number = 2
> Function num = 0
> Status Reg = 90h
> Command Reg = 7h
> Bus Master enabled
> PCI INTx enabled
> Latency Timer = 0h
> Cache Line Size= 0h
> BAR - 0 [Mem] = d0000000h 32bit length 1048576 enabled BAR - 2 [Mem]
> = c0000000h...
07/15/2010 7:59 AM
post59505
Well I don't know! I've had this driver running on 2 machines all night,
performing an 'ls -lR' between each other using qnet, together with an ftp
script and no hangups. The one machine also has the same 0x107c adapter that
you have. Have you tried another machine and/or Ethernet adapter?
132,000,000 messages and counting! :-)
> no change. We have limited the TCP multi-thread application to one thread
> is now .5 secondes. About 120K of data is send to the Windows machine every .5
> sec. Networking stopped after transferring a total of 10Meg. During the
> climbing from 2M to 4M until is stopped.
>> PCI version = 3.00
>> PCI index = 0h
>> Revision ID = 2h
>> Bus number = 0
>> Device number = 0
>> Function num = 0
>> Status Reg = 2090h
>> Command Reg = 106h
>> Bus Master enabled
>> PCI INTx enabled
>> Latency Timer = 0h
>> Cache Line Size= 0h
>> Max Lat = 0ns
>> Min Gnt = 0ns
>> PCI Int Pin = NC
>> Interrupt line = 0
>> CPU Interrupt = 0h
>> PCI index = 0h
>> Revision ID = 2h
>> Bus number = 0
>> Device number = 2
>> Function num =...
07/14/2010 1:13 PM
post59451
I tried doing a cp -V /dev/hd0 /net/.../dev/null (both ways), it was happening close to wire speed and no problem.
> PCI version = 3.00
> PCI index = 0h
> Revision ID = 2h
> Bus number = 0
> Device number = 0
> Function num = 0
> Status Reg = 2090h
> Command Reg = 106h
> Bus Master enabled
> PCI INTx enabled
> Latency Timer = 0h
> Cache Line Size= 0h
> Max Lat = 0ns
> Min Gnt = 0ns
> PCI Int Pin = NC
> Interrupt line = 0
> CPU Interrupt = 0h
> PCI index = 0h
> Revision ID = 2h
> Bus number = 0
> Device number = 2
> Function num = 0
> Status Reg = 90h
> Command Reg = 7h
> Bus Master enabled
> PCI INTx enabled
> Latency Timer = 0h
> Cache Line Size= 0h
> = c0000000h prefetchable 64bit length 268435456 enabled BAR - 4 [I/O]
> = 3400h length 8 enabled Subsystem Vendor ID = 17aah
> Max Lat = 0ns
> Min Gnt = 0ns
> PCI Int Pin = INT A
> Interrupt line = 11
> CPU Interrupt = bh
07/14/2010 1:29 PM
post59455
Don't use /dev/null for testing. It won't actually transfer the data.
aboyd "Going for the deck at corner"
07/14/2010 1:57 PM
post59458
As far as I can tell transferring from local to remote /dev/null works (cp /dev/hd0 /net/XXX/dev/null ). I just made
a test by using /net/XXX/dev/shmem/file and I get the same speed +- 2%.
I believe what you are saying is true if using local /dev/null ?
De : Andrew Boyd [mailto:community-noreply@qnx.com]
Envoyé : 14 juillet 2010 13:30
Objet : RE: 6.5 M9 network stop working
General
http://community.qnx.com/sf/go/post59455
07/14/2010 11:35 AM
post59439
I should also have asked if the problem occurs in a non-apic version of
6.5.0?
> PCI version = 3.00
> PCI index = 0h
> Revision ID = 2h
> Bus number = 0
> Device number = 0
> Function num = 0
> Status Reg = 2090h
> Command Reg = 106h
> Bus Master enabled
> PCI INTx enabled
> Latency Timer = 0h
> Cache Line Size= 0h
> Max Lat = 0ns
> Min Gnt = 0ns
> PCI Int Pin = NC
> Interrupt line = 0
> CPU Interrupt = 0h
> PCI index = 0h
> Revision ID = 2h
> Bus number = 0
> Device number = 2
> Function num = 0
> Status Reg = 90h
> Command Reg = 7h
> Bus Master enabled
> PCI INTx enabled
> Latency Timer = 0h
> Cache Line Size= 0h
> Max Lat = 0ns
> Min Gnt = 0ns
> PCI Int Pin = INT A
> Interrupt line = 11
> CPU Interrupt = bh
> 0x050: 060c 3000 0900 0000 0000...
