05/17/2010 6:13 AM
post54828
I'm testing an example application of the library "udt". The code of this example works with Linux and Windows.
Under QNX6.4.1 I got the following error message:
> bind: Connection setup failure: unable to create/configure UDP socket:
> No buffer space available.
Is UDP not supported ??
The code sequence is:
int main(int argc, char* argv[])
if ((1 != argc) && ((2 != argc) || (0 == atoi(argv[1]))))
cout << "usage: appserver [server_port]" << endl;
return 0;
// use this function to initialize the UDT library
UDT::startup();
addrinfo hints;
addrinfo* res;
memset(&hints, 0, sizeof(struct addrinfo));
hints.ai_flags = AI_PASSIVE;
hints.ai_family = AF_INET;
hints.ai_socktype = SOCK_STREAM;
//hints.ai_socktype = SOCK_DGRAM;
string service("9000");
if (2 == argc)
service = argv[1];
if (0 != getaddrinfo(NULL, service.c_str(), &hints, &res))
cout << "illegal port number or port is busy.\n" << endl;
return 0;
UDTSOCKET serv = UDT::socket(res->ai_family, res->ai_socktype, res->ai_protocol);
// UDT Options
//UDT::setsockopt(serv, 0, UDT_CC, new CCCFactory<CUDPBlast>, sizeof(CCCFactory<CUDPBlast>));
//UDT::setsockopt(serv, 0, UDT_MSS, new int(9000), sizeof(int));
//UDT::setsockopt(serv, 0, UDT_RCVBUF, new int(10000000), sizeof(int));
//UDT::setsockopt(serv, 0, UDP_RCVBUF, new int(10000000), sizeof(int));
if (UDT::ERROR == UDT::bind(serv, res->ai_addr, res->ai_addrlen))
cout << "bind: " << UDT::getlasterror().getErrorMessage() << endl;
return 0;
freeaddrinfo(res);
..... a.s.o
--Armin
05/17/2010 9:28 AM
post54843
Yes, UDP is supported :-)
I am not familiar with this library and since the source code only has
the calls into what I assume is the library (and doesn't contain the
socket API calls) I'm afraid I can't point you at what is going on. I
have to assume therefore that it's doing some Linux-ism or something
else which won't fly on BSD style systems. Have you tried this on BSD?
/P
This is probably not the error coming from the QNX socket library,
sounds like something internal to UDT.
> UDT::startup();
I have no idea what goes on inside ::startup, ::socket, ::bind methods
so cant' really say what (may) have gone wrong...
05/17/2010 9:30 AM
post54844
I`m using the Poco library that implement UPD objects and it worked right out of the box.
> From: Patrik Lahti [mailto:community-noreply@qnx.com]
> Sent: Monday, May 17, 2010 9:29 AM
> To: general-networking
> Subject: Re: UDT communication
> /P
> socket:
> > UDT::startup();
> res->ai_protocol);
> http://community.qnx.com/sf/go/post54843
Re: RE: UDT communication
05/17/2010 3:57 PM
post54893
> of the box.
Also the UDT library works out of the box ... but only for Linux and Windows.
The UDT lib is C++ based. What about the Poco lib ?
The ported code of the UDT lib is available at:
http://community.qnx.com/sf/sfmain/do/downloadAttachment/projects.toolchain/discussion.core_development_tools.topc13742
/post54800?id=atch7679
It compiles as out of the box ... but doesn't work as out of the box.
-Armin
RE: RE: UDT communication
05/18/2010 9:15 AM
post54946
> From: Armin Steinhoff [mailto:community-noreply@qnx.com]
> Sent: Monday, May 17, 2010 3:58 PM
> Subject: Re: RE: UDT communication
> right out
> > of the box.
> Windows.
Yes it`s a C++ library very nice, it contains a lot more then UDP, it has TCP, HTTPD, XML and lots of other goodies:
http://pocoproject.org/. I rarely stumble upon code that I look on and say I which I could program like this. Poco is
one of them. I don`t understand why it`s not as popular.
I compiles and works fine ;-) I`m using 4 of the 5 freely available module, Foundation, Net, XML, Zip.
> hain/discussion.core_development_tools.topc13742/post54800?id=atch7679
> -Armin
> http://community.qnx.com/sf/go/post54893
05/18/2010 3:37 AM
post54919
Patrik,
just a statement to the "-ism".
Your approach of thinking is "QNX is right ... the rest of the world has
a failure".
No ... the problem are QNX-ism.
It's still a pain to port a piece of C++ based software to QNX.
As a reality check ... try to recompile the ROOT system. (
http://root.cern.ch )
And then ask why they are not using QNX ...
> or something
Why should it work with BSD?
On QNX you can recompile just 3000 of 9000 BSD packages. The reasons are
BSD-ism ??
Cheers
--Armin
05/18/2010 7:50 AM
post54933
But QNX *is* right :-)
Just kidding...
/P
05/18/2010 10:45 AM
post54962
Can you give a compiling example using this
library?
05/18/2010 11:39 AM
post54972
Sean,
the ported lib is available at:
http://community.qnx.com/sf/sfmain/do/downloadAttachment/projects.toolchain/discussion.core_development_tools.topc13742/
post54800?id=atch7679.
There is still for linking the libstdc++ to remove ...
Regards
--Armin
> library?
> Thanks,
> -seanb
> http://community.qnx.com/sf/go/post54962
05/18/2010 11:44 AM
post54974
On Tue, May 18, 2010 at 11:39:24AM -0400, Armin Steinhoff wrote:
> Sean,
topc13742/post54800?id=atch7679.
I downloaded it, and built it. Now how do I reproduce your issue?
05/18/2010 4:02 PM
post55015
>> Sean,
In the directory app is located the "appserver". This example terminates
with an strange error message.
Regards
--Armin
05/18/2010 4:48 PM
post55024
Please see the attached diff. You might want to go
through the other ifdefs.
| Attachment: |
diff
521 bytes
05/18/2010 4:54 PM
post55026
And please send them back to the UDT people.
| Attachment: |
diff
521 bytes
05/19/2010 9:16 AM
post55124
Sean,
I have checked all other idefs. The os spec in the Makefiles was also
not fully correct ... I changed it to UNIX.
After recompiling and linking against the shared lib of udt ...
"appserver" terminaties with the same problem as before.
But the applications "appserver" and "appclients" are working after
linking against the _static_ library of udt!
IMHO ... this is a QNX-ism of QCC. Should I send this problem back to
the compiler/linker guys ?
Regards
--Armin
> -seanb
> http://community.qnx.com/sf/go/post55026
05/19/2010 10:06 AM
post55144
On Wed, May 19, 2010 at 09:16:02AM -0400, Armin Steinhoff wrote:
> Sean,
Did you get rid of the -lstdc++ ? With that change appserver
is working for me against the shared lib.
# pidin -p appserver me
pid tid name prio STATE code data stack
909350 1 ./appserver 10o CONDVAR 24K 168K 24K(516K)*
909350 2 ./appserver 10o CONDVAR 24K 168K 4096(132K)
909350 3 ./appserver 10o CONDVAR 24K 168K 4096(132K)
909350 4 ./appserver 10o REPLY 24K 168K 4096(132K)
libc.so.3 @b0300000 488K 16K
libudt.so @b8200000 236K 8192
libcpp.so.4 @b823d000 376K 36K
libm.so.2 @b82a4000 180K 24K
libsocket.so.3 @b82d7000 164K 28K
05/19/2010 10:50 AM
post55156
Sean,
I removed -lstdc++, -lcpp and -lcxa because all compilation was done
with QCC.
I'm using qnx 6.4.1 ...
--Armin
>> Sean,
> http://community.qnx.com/sf/go/post55144
05/19/2010 12:28 PM
post55175
> Sean,
> with QCC.
and compile /link natively ...
--Armin
> --Armin
> >> Sean,
> stack
> > General
05/19/2010 12:30 PM
post55176
On Wed, May 19, 2010 at 12:28:14PM -0400, Armin Steinhoff wrote:
> > Sean,
> > with QCC.
Of course, like all packet pushers should :)
I'm on 6.5 but I can't think why that should matter...
05/20/2010 3:40 AM
post55207
>>> Sean,
>>> with QCC.
Different binaries of compiler/linker ... different
environments/libraries on QNX6, Linux, Windows ?
I will repeat the test on 6.5 ...
--Armin
