02/04/2010 10:37 AM
post46547
On 04/02/10 08:53 AM, Mario Charest wrote:
> The repository seems broken. All I can see is tunk/lib/io-pkt and trunk/lib/socket.
> In fact when I tried to update my local version it said something was not matching
Hi Mario,
I just did a fresh checkout and didn't have any problems. Could it be
possible that you run into problems if you have an old repository you
created a long time ago (~3 months ago), before some maintenance work
was done which updated the structure of the repository?
You can see the old structure in core_networking_snapshot and the new
structure in core_networking:
http://community.qnx.com/sf/scm/do/listRepositories/projects.networking/scm
It used to be that the trunk root contained the entire io-pkt source
directly and all the libs including socket were together. But now the
socket library has been separated out, so now trunk just has a lib
directory with socket and io-pkt in subdirs beneath it.
I suggest you start with a fresh work space and see if that works.
Cheers!
/P
02/04/2010 10:59 AM
post46549
But now I see the build is broken:
/opt/qnx641/host/linux/x86/usr/bin/qcc -Vgcc_ntox86 -c -Wc,-Wall
-Wc,-Wno-parentheses -g -O -Wno-pointer-sign -Wp,-includeqnx.h
-fno-builtin-log -fno-builtin-printf -D_KERNEL -D_KERNEL_OPT -DLKM
-DSIMPLE_MALLOC_BSD -DRANDOM_BSD -DMAXUSERS=32 -DKMEMSTATS
-Wpointer-arith -Wmissing-prototypes -Werror -Wall -Wno-uninitialized
-I. -I/home/plahti/src/corenet/trunk/lib/io-pkt/sys
-I/home/plahti/src/corenet/trunk/lib/io-pkt/sys/sys-nto
-I/home/plahti/src/corenet/trunk/lib/io-pkt/sys/target/x86
-I/home/plahti/src/corenet/trunk/lib/io-pkt/sys/../lib/socket/public
-I/home/plahti/src/corenet/trunk/lib/io-pkt/sys/../lib/socket/inc
-I/home/plahti/src/corenet/stage/usr/include
-I/opt/qnx641/target/qnx6/usr/include -g -DVARIANT_v4
-DBUILDENV_qss -O0 /home/plahti/src/corenet/trunk/lib/io-pkt/sys/net/bpf.c
/home/plahti/src/corenet/trunk/lib/io-pkt/sys/net/bpf.c: In function
'bpf_getptrembed':
/home/plahti/src/corenet/trunk/lib/io-pkt/sys/net/bpf.c:959: error:
'DCMD_MISC_GETPTREMBED' undeclared (first use in this function)
(Each undeclared identifier is reported only once
/home/plahti/src/corenet/trunk/lib/io-pkt/sys/net/bpf.c:959: error: for
each function it appears in.)
/home/plahti/src/corenet/trunk/lib/io-pkt/sys/net/bpf.c:969: error:
invalid use of undefined type 'struct __ioctl_getptrembed'
dereferencing pointer to incomplete type
/home/plahti/src/corenet/trunk/lib/io-pkt/sys/net/bpf.c:970: error:
/home/plahti/src/corenet/trunk/lib/io-pkt/sys/net/bpf.c:995: error:
'bpf_ioctl':
/home/plahti/src/corenet/trunk/lib/io-pkt/sys/net/bpf.c:1292: error:
cc:
/opt/qnx641/host/linux/x86/usr/lib/gcc/i386-pc-nto-qnx6.4.0/4.3.3/cc1
error 1
make[4]: *** [bpf.o] Error 1
make[4]: Leaving directory
`/home/plahti/src/corenet/trunk/lib/io-pkt/sys/target/x86/o.v4'
make[3]: *** [install] Error 2
make[3]: Leaving directory
`/home/plahti/src/corenet/trunk/lib/io-pkt/sys/target/x86'
make[2]: *** [install] Error 2
make[2]: Leaving directory
`/home/plahti/src/corenet/trunk/lib/io-pkt/sys/target'
make[1]: *** [install] Error 2
make[1]: Leaving directory `/home/plahti/src/corenet/trunk/lib/io-pkt/sys'
make: *** [install] Error 2
Compilation exited abnormally with code 2 at Thu Feb 4 10:48:36
DCMD_MISC_GETPTREMBED is from libc's sys/dcmd_misc.h header file. You
can get it from the CoreOS repository (lib/c/public/sys/dcmd_misc.h):
http://community.qnx.com/sf/scm/do/listRepositories/projects.core_os/scm
I'll check with Sean if we can synchronize this better...
/P
02/04/2010 11:06 AM
post46550
You'll also need sys/iomsg.h from the same place.
Sorry about this. It's just the consequence of being on the bleeding
edge :-)
/P
02/04/2010 11:23 AM
post46554
FYI, I just posted a note about how to build things as of today in the
build forum: http://community.qnx.com/sf/go/topc11935
/P
04/19/2010 9:30 AM
post52022
I was able to checkout the SVN about 2 months ago, but now I'm having problems. It seems I'm no longer authorized to
download the source(?!).
[code]svn checkout --username my.mailbox@mailserver.com http://community.qnx.com/svn/repos/core_networking/trunk/
svn: Not authorized to open root of edit operation
[/code]
I tried downloading branches and tags, providing password, using "https://", downloading one specific directory in the
repository, using --force. I also tried running SVN on root account.
Nothing seems to make difference.
Do I have to request access to the repository? or am I making something wrong?
