QNX does not detect the third network card
08/07/2009 10:49 AM
post35468
Hi all,
I added a new network card which is "Intel 82572EI_COPPER 0x107D devnp-e1000.so ARM, MIPS, PPC, SH4, X86
driver support for Intel gigabit " to my target PC (x86) which has already one built in network card and one intel PRO
1000 GT network card.
Unfortunately QNX does not detect the new network card and I see just two devices in TCP/IP configuration. what should I
do to solve this problem?
Mohammad
RE: QNX does not detect the third network card
08/07/2009 10:55 AM
post35470
What version of the O/S are you running? The devnp-* drivers only work
with io-pkt.
From: Mohammad Dadashzadeh [mailto:community-noreply@qnx.com]
Sent: Friday, August 07, 2009 10:49 AM
To: drivers-networking
Subject: QNX does not detect the third network card
Hi all,
already one built in network card and one intel PRO 1000 GT network
card.
two devices in TCP/IP configuration. what should I do to solve this
problem?
Mohammad
Networking Drivers
http://community.qnx.com/sf/go/post35468
Re: RE: QNX does not detect the third network card
08/07/2009 10:57 AM
post35471
QNX 6.4.1 and io-pkt-v4-hc
RE: RE: QNX does not detect the third network card
08/07/2009 11:02 AM
post35472
If you do the following, does the driver work?
slay io-pkt-v4-hc
io-pkt-v4-hc -de1000
nicinfo
Does nicinfo show a device or are there any error messages when you
start io-pkt?
Sent: Friday, August 07, 2009 10:57 AM
Subject: Re: RE: QNX does not detect the third network card
Networking Drivers
http://community.qnx.com/sf/go/post35471
Re: RE: RE: QNX does not detect the third network card
08/07/2009 11:07 AM
post35474
I did it, no error. but it does not recognize any network card anymore.
Mohammad
RE: RE: RE: QNX does not detect the third network card
08/07/2009 11:12 AM
post35475
Please do the following:
sloginfo -c
slay io-pkt-v4-hc
io-pkt-v4-hc -de1000 verbose
Please can you post the output from 'pci -v' as well as the output from
'sloginfo'.
Sent: Friday, August 07, 2009 11:08 AM
Subject: Re: RE: RE: QNX does not detect the third network card
Mohammad
Networking Drivers
http://community.qnx.com/sf/go/post35474
Re: RE: RE: RE: QNX does not detect the third network card
08/07/2009 11:33 AM
post35479
Sloginfo -c results
Time Sev Major Minor Args
Aug 07 11:26:22 2 12 0 ps2 - Device Timeout (0x5e)
Aug 07 11:26:22 2 12 0 ps2 - Device Timeout (0x54)
Aug 07 11:26:22 2 12 0 ps2 - Device Timeout (0x56)
Aug 07 11:26:22 2 12 0 ps2 - Device Timeout (0x52)
Aug 07 11:26:23 2 19 1500 devb-ahci 1.00A (Oct 20 2008 23:23:51)
Aug 07 11:26:23 2 5 0 libcam.so (Oct 20 2008 23:22:34) bver 6040001
Aug 07 11:26:23 2 5 0 xpt_configure: ahci SIM attach failure
Aug 07 11:26:23 2 19 0 devb-eide 1.00A (Oct 20 2008 23:27:28)
Aug 07 11:26:23 2 19 0 eide_identify_devices: Intel 82801FB vid 8086, did 266f, class 1018a rev 3,
busno 0, dfunc f9
Aug 07 11:26:23 2 19 0 eide_identify_devices: cmd_addr 1f0, cntl_addr 3f4, irq e, chnl 0, udma 5, m
dma 2, sdma 0, pio 4
Aug 07 11:26:23 2 19 0 eide_identify_devices: probing dev 0 status 50, error 0
Aug 07 11:26:23 2 19 0 eide_identify_devices: probing dev 1 status 0, error 0
Aug 07 11:26:23 2 19 0 eide_identify: chk 4 cmd ec, tid 0, status 51, astatus 51, error 4
Aug 07 11:26:23 2 19 0 eide_display_devices: mdl HL-DT-ST DVDRAM GSA-4163B sn K3151CI1252 fw A102 t
id 0, cable 40, max udma 2, cur udma 2, max mdma 2, cur mdma 0, max sdma -1, cur sdma -1, pio 4, mblk 0
Aug 07 11:26:23 2 19 0 eide_init_devices: HL-DT-ST DVDRAM GSA-4163B path 0, tid 0, udma 2, mdma 2,
busno 0, dfunc f9
Aug 07 11:26:23 2 19 0 eide_identify_devices: cmd_addr 170, cntl_addr 374, irq f, chnl 1, udma 5, m
Aug 07 11:26:23 2 19 0 eide_identify_devices: probing dev 0 status 7f, error 7f
Aug 07 11:26:23 2 19 0 eide_identify_devices: probing dev 1 status 7f, error 7f
Aug 07 11:26:23 2 19 0 eide_identify_devices: Intel 82801FB/W SATA vid 8086, did 2651, class 1018f
rev 3, busno 0, dfunc fa
Aug 07 11:26:23 2 19 0 eide_identify_devices: cmd_addr e800, cntl_addr e400, irq a, chnl 0, udma 5,
mdma 2, sdma 0, pio 4
Aug 07 11:26:23 2 19 0 eide_parse_identify: IDENTIFY DRIVE CMD cksum failure 192
Aug 07 11:26:23 2 19 0 eide_display_devices: mdl WDC WD1600JD-22HBB0 sn WD-WCAL9266037 fw 08.02D08
tid 0, cable 40, max udma 6, cur udma 5, max mdma 2, cur mdma 0, max sdma -1, cur sdma -1, pio 4, mblk 16
Aug 07 11:26:23 2 19 0 eide_init_devices: WDC WD1600JD-22HBB0 path 1, tid 0, udma 5, mdma 2, sdma -
1, pio 4, mblk 16
Aug 07 11:26:23 2 19 0 eide_identify_devices: cmd_addr e000, cntl_addr dc00, irq a, chnl 1, udma 5,
Aug 07 11:26:23 2 19 0 eide_init_devices: WDC WD1600JD-22HBB0...
RE: RE: RE: RE: QNX does not detect the third network card
08/07/2009 11:40 AM
post35482
I don't want the sloginfo -c results. I want you to do the following:
slay io-pkt-v4-hc
sloginfo > file
Post the output 'file'.
Thanks.
Sent: Friday, August 07, 2009 11:33 AM
Subject: Re: RE: RE: RE: QNX does not detect the third network card
Sloginfo -c results
6040001
6040001
busno 0, dfunc f9
status 50, error 0
status 0, error 0
busno 0, dfunc f9
status 7f, error 7f
status 7f, error 7f
status 50, error 0
status 0, error 0
1, pio 4, mblk 16
status 50, error 0
Aug 07 11:26:23 2 19 0...
Re: RE: RE: RE: RE: QNX does not detect the third network card
08/07/2009 12:02 PM
post35488
I figure out there is no devnp-e1000.so in x86\lib\dll so I copied from Momentics machine to target machine after that I
run
slay io-pkt-v4-hc
sloginfo > file
and below is the result. Now my target machine recognizes new network card but it removed the built in network card. I
guess there is a limitation of two network cards somewhere?
Aug 07 11:55:29 2 12 0 ps2 - Device Timeout (0x5e)
Aug 07 11:55:29 2 12 0 ps2 - Device Timeout (0x54)
Aug 07 11:55:29 2 12 0 ps2 - Device Timeout (0x56)
Aug 07 11:55:29 2 12 0 ps2 - Device Timeout (0x52)
Aug 07 11:55:30 2 12 0 ps2 - Device Timeout (0x56)
Aug 07 11:55:30 2 19 1500 devb-ahci 1.00A (Oct 20 2008 23:23:51)
Aug 07 11:55:30 2 5 0 libcam.so (Oct 20 2008 23:22:34) bver 6040001
Aug 07 11:55:30 2 5 0 xpt_configure: ahci SIM attach failure
Aug 07 11:55:30 2 19 0 devb-eide 1.00A (Oct 20 2008 23:27:28)
Aug 07 11:55:30 2 19 0 eide_identify_devices: Intel 82801FB vid 8086, did 266f, class 1018a rev 3, busno 0,
dfunc f9
Aug 07 11:55:30 2 19 0 eide_identify_devices: cmd_addr 1f0, cntl_addr 3f4, irq e, chnl 0, udma 5, mdma 2, sdma
0, pio 4
Aug 07 11:55:30 2 19 0 eide_identify_devices: probing dev 0 status 50, error 0
Aug 07 11:55:30 2 19 0 eide_identify_devices: probing dev 1 status 0, error 0
Aug 07 11:55:30 2 19 0 eide_identify: chk 4 cmd ec, tid 0, status 51, astatus 51, error 4
Aug 07 11:55:30 2 19 0 eide_display_devices: mdl HL-DT-ST DVDRAM GSA-4163B sn K3151CI1252 fw A102 tid 0, cable
Aug 07 11:55:30 2 19 0 eide_init_devices: HL-DT-ST DVDRAM GSA-4163B path 0, tid 0, udma 2, mdma 2, sdma -1,
pio 4, mblk 0
dfunc f9
Aug 07 11:55:30 2 19 0 eide_identify_devices: cmd_addr 170, cntl_addr 374, irq f, chnl 1, udma 5, mdma 2, sdma
0, pio 4
Aug 07 11:55:30 2 19 0 eide_identify_devices: probing dev 0 status 7f, error 7f
Aug 07 11:55:30 2 19 0 eide_identify_devices: probing dev 1 status 7f, error 7f
Aug 07 11:55:30 2 19 0 eide_identify_devices: Intel 82801FB/W SATA vid 8086, did 2651, class 1018f rev 3,
busno 0, dfunc fa
Aug 07 11:55:30 2 19 0 eide_identify_devices: cmd_addr e800, cntl_addr e400, irq a, chnl 0, udma 5, mdma 2,
sdma 0, pio 4
Aug 07 11:55:30 2 19 0 eide_parse_identify: IDENTIFY DRIVE CMD cksum failure 192
Aug 07 11:55:30 2 19 0 eide_display_devices: mdl WDC WD1600JD-22HBB0 sn WD-WCAL9266037 fw 08.02D08 tid 0,
Aug 07 11:55:30 2 19 0 eide_init_devices: WDC WD1600JD-22HBB0 path 1, tid 0, udma 5, mdma 2, sdma -1, pio 4,
mblk 16
busno 0, dfunc fa
Aug 07 11:55:30 2 19 0 eide_identify_devices: cmd_addr e000, cntl_addr dc00, irq a, chnl 1, udma 5, mdma 2,
sdma 0, pio 4
Aug 07 11:55:30 2 19 0 eide_identify_devices: probing dev 0 status 7f, error ff
Aug 07 11:55:30 2 19 0 eide_identify_devices: probing dev 1 status 7f, error ff
Aug 07 11:55:30 2 5 ...
RE: RE: RE: RE: RE: QNX does not detect the third network card
08/07/2009 1:01 PM
post35494
No, there is no limitation of 2 network cards. If you reboot your
machine, now that you have the driver in /lib/dll, you should see all 3
interfaces.
Sent: Friday, August 07, 2009 12:02 PM
Subject: Re: RE: RE: RE: RE: QNX does not detect the third network card
Momentics machine to target machine after that I run
slay io-pkt-v4-hc
sloginfo > file
card but it removed the built in network card. I guess there is a
6040001
6040001
vid 8086, did 266f, class 1018a rev 3, busno 0, dfunc f9
cntl_addr 3f4, irq e, chnl 0, udma 5, mdma 2, sdma 0, pio 4
status 50, error 0
status 0, error 0
DVDRAM GSA-4163B sn K3151CI1252 fw A102 tid 0, cable 40, max udma 2, cur
GSA-4163B path 0, tid 0, udma 2, mdma 2, sdma -1, pio 4, mblk 0
cntl_addr 374, irq f, chnl 1, udma 5, mdma 2, sdma 0, pio 4
status 7f, error 7f
status 7f, error 7f
SATA vid 8086, did 2651, class 1018f rev 3, busno 0, dfunc fa
cntl_addr e400, irq a, chnl 0, udma 5, mdma 2, sdma 0, pio 4
status 50, error 0
status 0, error 0
WD1600JD-22HBB0 sn WD-WCAL9266037 fw 08.02D08 tid 0, cable 40, max udma
mblk 16
path 1, tid 0, udma 5, mdma 2, sdma -1, pio 4, mblk 16
Aug 07 11:55:30 2 19 0 eide_identify_devices: Intel...
08/07/2009 1:03 PM
post35495
I had four i82544 interfaces up yesterday
with a single driver.
aboyd
Re: RE: RE: RE: RE: RE: QNX does not detect the third network card
08/10/2009 8:32 AM
post35537
I reboot my system. Now it recognizes just the two network cards (Intel Pro 100 and intel Pro 1000 GT) same as before.
It does not recognize the third network card (Intel Pro 1000 PT) which is connected to PCI express slot. if I run below
code, it removes the first network card from the list and adds the third network card to the list. If I reboot the
system I will get back to the default configuration with the first and second network cards.
slay io-pkt-v4-hc
Mohammad
RE: RE: RE: RE: RE: RE: QNX does not detect the third network card
08/10/2009 8:47 AM
post35540
Please look at you /etc/system/enum/devices/net file and see if both of
the device IDs for your gigabit adapters are in the file. If not, you
can copy one of the lines and add the device ID. Then reboot your
system.
Sent: Monday, August 10, 2009 8:32 AM
Subject: Re: RE: RE: RE: RE: RE: QNX does not detect the third network
card
Pro 100 and intel Pro 1000 GT) same as before. It does not recognize the
slot. if I run below code, it removes the first network card from the
list and adds the third network card to the list. If I reboot the system
network cards.
slay io-pkt-v4-hc
Mohammad
Networking Drivers
http://community.qnx.com/sf/go/post35537
Re: RE: RE: RE: RE: RE: RE: QNX does not detect the third network card
08/10/2009 9:01 AM
post35542
Hi Hugh,
Thanks a lot. It solved the problem.
Mohammad
08/10/2009 9:23 AM
post35546
QNX recognizes the third network card also I can set the IP address. However, when I ping another PC in the same network
or vise versa , ping does not work. Should I do something else after adding the device ID to the net file and rebooting
. I am sure that I have set the IP address correctly as the other network cards work perfectly.
Mohammad
RE: RE: RE: RE: RE: RE: RE: QNX does not detect the third network card
08/10/2009 9:33 AM
post35549
Have you configured the network addresses using the Photon network setup
or are you doing it manually? If you are doing it manually, make sure
that you slay dhcp.client and netmanager before configuring the
interfaces.
Sent: Monday, August 10, 2009 9:23 AM
Subject: Re: RE: RE: RE: RE: RE: RE: QNX does not detect the third
network card
However, when I ping another PC in the same network or vise versa , ping
the net file and rebooting. I am sure that I have set the IP address
Mohammad
Networking Drivers
http://community.qnx.com/sf/go/post35546
08/10/2009 9:49 AM
post35556
>> ping does not work
A simple way to check to see if the driver is
functioning with the nic is with the
# nicinfo -r enX
utility, where X is a small positive integer.
Ensure that for each interface, it has negotiated
to a valid link speed and duplex, and check the
"Packets Received Ok" count - it should be non-zero
on almost any network, which indicates that the nic
interrupt is functioning.
Once you think the hardware and driver are functioning
then you can go on to the protocols.
aboyd
Re: RE: RE: RE: RE: RE: RE: RE: QNX does not detect the third network card
08/10/2009 10:04 AM
post35565
Packet Received is non-zero however packet transmit is zero even though I pinged its IP address from the other computer
in the network. I think this is the reason ping does not work.
Mohammad
RE: RE: RE: RE: RE: RE: RE: RE: QNX does not detect the third network card
08/10/2009 10:11 AM
post35571
What is the output from 'netstat -in' after the interfaces have been
configured?
Sent: Monday, August 10, 2009 10:04 AM
Subject: Re: RE: RE: RE: RE: RE: RE: RE: QNX does not detect the third
network card
I pinged its IP address from the other computer in the network. I think
Mohammad
Networking Drivers
http://community.qnx.com/sf/go/post35565
Re: RE: RE: RE: RE: RE: RE: RE: RE: QNX does not detect the third network card
08/10/2009 10:14 AM
post35574
# netstat -in
Name Mtu Network Address Ipkts Ierrs Opkts Oerrs Colls
lo0 33192 <Link> 18 0 18 0 0
lo0 33192 127/8 127.0.0.1 18 0 18 0 0
fxp0 1500 <Link> 00:11:11:6e:07:2e 1259 0 348 0 0
fxp0 1500 129.100.227/2 129.100.227.188 1259 0 348 0 0
wm0 1500 <Link> 00:15:17:b9:5f:13 584 0 520 0 0
wm0 1500 192.168.1/24 192.168.1.5 584 0 520 0 0
wm1 1500 <Link> 00:1b:21:3b:59:42 75 0 1 0 0
wm1 1500 192.168.1/24 192.168.1.6 75 0 1 0 0
network card
08/10/2009 10:18 AM
post35575
network card
On Mon, Aug 10, 2009 at 10:14:24AM -0400, Mohammad Dadashzadeh wrote:
> # netstat -in
wm0 and wm1 are on the same subnet. All packets
routed to 192.168.1/24 will go out one or the other
(check your routing table). In your case it seems
to be wm0.
RE: RE: RE: RE: RE: RE: RE: RE: RE: QNX does not detect the third network card
08/10/2009 10:18 AM
post35576
You have 2 links on the same subnet. You can't do that!
Wm0 and wm1 have the same subnet.
Sent: Monday, August 10, 2009 10:14 AM
Subject: Re: RE: RE: RE: RE: RE: RE: RE: RE: QNX does not detect the
third network card
# netstat -in
Oerrs Colls
0 0
0 0
0 0
0 0
0 0
0 0
0 0
0 0
Networking Drivers
http://community.qnx.com/sf/go/post35574
Re: RE: RE: RE: RE: RE: RE: RE: RE: RE: QNX does not detect the third network card
08/10/2009 10:26 AM
post35579
Is this the case in QNX since in my windows machine I have two network cards with
the same subnet mask.
Windows IP Configuration
Ethernet adapter Local Area Connection 5:
Connection-specific DNS Suffix . :
IP Address. . . . . . . . . . . . : 192.168.1.3
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . :
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . : uwo.ca
IP Address. . . . . . . . . . . . : 129.100.227.15
Default Gateway . . . . . . . . . : 129.100.227.1
Mohammad
third network card
08/10/2009 10:30 AM
post35581
third network card
Those have the same subnet masks but when applied
against the ip addresses they result in different
subnets. On your QNX box they're the same:
On windows:
(192.168.1.3 & 255.255.255.0) = 192.168.1.0
(129.100.227.15 & 255.255.255.0) = 129.100.227.0
On QNX:
(192.168.1.5 & 255.255.255.0) = 192.168.1.0
(192.168.1.6 & 255.255.255.0) = 192.168.1.0
08/10/2009 10:49 AM
post35584
You are right I even checked it in windows, the same problem. I guess I have a conceptual problem. I have a private
network with the ip addresses 192.168.1.1-254 and subnet mask 255.255.255.0. Is it possible to have multiple network
cards in one PC connected to the same network. If I want that I have to set all the network cards IP address in this
range 192.168.1.1-254 and subnet 255.255.255.255. It seems that it is impossible. I am totally confused.
Mohammad
08/10/2009 11:44 AM
post35593
I made a small mistake when I was using windows I forgot to connect the second network card to the same network. I did
this and it worked. I would be able to ping both the interfaces from other machine. why is not possible to do the same
thing in QNX?
Mohammad
IP Address. . . . . . . . . . . . : 192.168.1.8
third network card
08/10/2009 3:07 PM
post35611
third network card
thing in QNX?
Is there anything in the sloginfo of the QNX box after
you've tried to ping both its addrs?
08/11/2009 9:26 AM
post35680
Below is the result of sloginfo command. By the way I was able to send packets through all the network card using pcap.h
. I was wondering why ping still does not work. My understanding is that netmask defines the range of available IPs in a
network. therefore it is realizable to have to acceptable ip address like 192.168.1.5 and 192.168.1.8 with the same
subnet mask 255.255.255.0. If I disable the network card (192.168.1.5) which I can ping it from another computer from
the network configuration I wont still be able to ping the network card with 192.168.1.8 IP address from another PC.
Mohammad
Aug 11 09:11:11 5 14 0 00:11:11:6e:07:f2 on wm1 tried to write arp info 192.168.1.7 on wm0
Aug 11 09:11:12 5 14 0 00:02:b3:1c:d5:33 on wm1 tried to write arp info 192.168.1.3 on wm0
Aug 11 09:11:25 5 14 0 00:02:b3:1c:d5:33 on wm1 tried to write arp info 192.168.1.3 on wm0
Aug 11 09:11:26 5 14 0 00:02:b3:1c:d5:33 on wm1 tried to write arp info 192.168.1.3 on wm0
Aug 11 09:11:34 5 14 0 00:02:b3:1c:d5:33 on wm1 tried to write arp info 192.168.1.3 on wm0
Aug 11 09:11:35 5 14 0 00:02:b3:1c:d5:33 on wm1 tried to write arp info 192.168.1.3 on wm0
08/11/2009 9:36 AM
post35682
.h. I was wondering why ping still does not work. My understanding is that netmask defines the range of available IPs in
a network. therefore it is realizable to have to acceptable ip address like 192.168.1.5 and 192.168.1.8 with the same
> Regards,
> Mohammad
This looks to be a side effect of a previous fix for
another customer. If you seed the arp cache on the
client doing the pinging it'll probably work with
the caveat that the QNX box will always send on the
interface that the route points to which is correct
(you may ping 192.168.1.X but the stack will send
the packet out 192.168.1.Y).
08/10/2009 9:52 AM
post35559
Yes I am using photon to set the IP addresses. When I run nicinfo the title showing for my third network card was wrong
so I went into the net file and figured out that I added the device ID which 107d after 107c as follows. It
device(pci, ven=$(PCI_VEND_INTEL), dev=1008) # Intel 82544EI Gigabit
device(pci, ven=$(PCI_VEND_INTEL), dev=1009) # Intel 82544EI Gigabit
device(pci, ven=$(PCI_VEND_INTEL), dev=100c) # Intel 82544GC Gigabit
device(pci, ven=$(PCI_VEND_INTEL), dev=100d) # Intel 82544GC Gigabit
device(pci, ven=$(PCI_VEND_INTEL), dev=100e) # Intel 82540EM Gigabit
device(pci, ven=$(PCI_VEND_INTEL), dev=100f) # Intel 82545EM Gigabit
device(pci, ven=$(PCI_VEND_INTEL), dev=1010) # Intel 82546EB Gigabit
device(pci, ven=$(PCI_VEND_INTEL), dev=1011) # Intel 82545EM Gigabit
device(pci, ven=$(PCI_VEND_INTEL), dev=1012) # Intel 82546EB Gigabit
device(pci, ven=$(PCI_VEND_INTEL), dev=1013) # Intel 82541EI Gigabit
device(pci, ven=$(PCI_VEND_INTEL), dev=1015) # Intel 82540EM Gigabit
device(pci, ven=$(PCI_VEND_INTEL), dev=1016) # Intel 82540EP Gigabit
device(pci, ven=$(PCI_VEND_INTEL), dev=1017) # Intel 82540EP Gigabit
device(pci, ven=$(PCI_VEND_INTEL), dev=1018) # Intel 82541EI Gigabit
device(pci, ven=$(PCI_VEND_INTEL), dev=1019) # Intel 82541EI Gigabit
device(pci, ven=$(PCI_VEND_INTEL), dev=101d) # Intel 82546EB Gigabit
device(pci, ven=$(PCI_VEND_INTEL), dev=101e) # Intel 82540EP Gigabit
device(pci, ven=$(PCI_VEND_INTEL), dev=1026) # Intel 82545GM Gigabit
device(pci, ven=$(PCI_VEND_INTEL), dev=1027) # Intel 82545GM Gigabit
device(pci, ven=$(PCI_VEND_INTEL), dev=1028) # Intel 82545GM Gigabit
device(pci, ven=$(PCI_VEND_INTEL), dev=104a) # Intel 82566DM Gigabit
device(pci, ven=$(PCI_VEND_INTEL), dev=104b) # Intel 82566DC Gigabit
device(pci, ven=$(PCI_VEND_INTEL), dev=104d) # Intel 82566MC Gigabit
device(pci, ven=$(PCI_VEND_INTEL), dev=105e) # Intel 82571EB Gigabit
device(pci, ven=$(PCI_VEND_INTEL), dev=105f) # Intel 82571EB_1 Gigabit
device(pci, ven=$(PCI_VEND_INTEL), dev=1060) # Intel 82571EB_2 Gigabit
device(pci, ven=$(PCI_VEND_INTEL), dev=1075) # Intel 82541GI Gigabit
device(pci, ven=$(PCI_VEND_INTEL), dev=1076) # Intel 82541GI Gigabit
device(pci, ven=$(PCI_VEND_INTEL), dev=1077) # Intel 82541GI Gigabit
device(pci, ven=$(PCI_VEND_INTEL), dev=1078) # Intel 82541ER Gigabit
device(pci, ven=$(PCI_VEND_INTEL), dev=1079) # Intel 82546GB Gigabit
device(pci, ven=$(PCI_VEND_INTEL), dev=107a) # Intel 82546GB Gigabit
device(pci, ven=$(PCI_VEND_INTEL), dev=107b) # Intel 82546GB Gigabit
device(pci, ven=$(PCI_VEND_INTEL), dev=107c) # Intel 82541PI Gigabit
device(pci, ven=$(PCI_VEND_INTEL), dev=107d) # Intel 82572EI Gigabit
device(pci, ven=$(PCI_VEND_INTEL), dev=108a) # Intel 82546EB Gigabit
device(pci, ven=$(PCI_VEND_INTEL), dev=108b) # Intel 82573V Gigabit
device(pci, ven=$(PCI_VEND_INTEL), dev=108c) # Intel 82573E Gigabit
device(pci, ven=$(PCI_VEND_INTEL), dev=1096) # Intel 82563 Gigabit
device(pci, ven=$(PCI_VEND_INTEL), dev=1097) # Intel 82563_FIBER Gigabit
device(pci, ven=$(PCI_VEND_INTEL), dev=1098) # Intel 82563_BX Gigabit
device(pci, ven=$(PCI_VEND_INTEL), dev=109a) # Intel 82573L Gigabit
device(pci, ven=$(PCI_VEND_INTEL), dev=10b9) # Intel 82572EI Gigabit
tag(devn)
append(legacy, ",nonet")
requires($(IOPKT_CMD),)
waitfor (/dev/socket)
mount(-Tio-pkt "-opci=$(index),vid=0x$(ven),did=0x$(dev)" /lib/dll/devnp-i82544.so, )
use(symbolic=netmgr)
