Forum Topic - USB WiFi hangs: (4 Items)
USB WiFi hangs
i have an issue with usb wifi connection
i use io-pkt-v4-hc, the devnp-rum.so driver mounts without problem, i configure the network with wpa_supplicant, and i
get ip address with dhcp
everything seems fine but after some time - usually during heavy network traffic - the connection hangs.
the board only has usb 1.1 controller but it should be compatible as far as i know. i also tried to limit the wifi speed
 by setting the mode and media parameters of the driver to different values but i had the same results.
the board is Advantech PCI-6871
the usb stick is ASUS WL-167g
here is the output from sloginfo:
Jan 12 00:09:03    5    14     0 en0USB device vendor 0xb05, device 0x1723 matched.
Jan 12 00:09:03    5    14     0 rum0 at pci0 dev 0 function 0rum0: MAC/BBP RT2573 (rev 0x2573a), RF RT2528, address 00:
1b:fc:8f:ff:96
Jan 12 00:09:03    5    14     0 ether_ifattach: rum0 null if_stop
Jan 12 00:09:03    5    14     0 rum0: 11b rates: 1Mbps 2Mbps 5.5Mbps 11Mbps
Jan 12 00:09:03    5    14     0 rum0: 11g rates: 1Mbps 2Mbps 5.5Mbps 11Mbps 6Mbps 9Mbps 12Mbps 18Mbps 24Mbps 36Mbps
48Mbps 54Mbps
Jan 12 00:11:38    5    14     0 rum0: device timeout
Jan 12 00:11:39    5    14     0 USB error 0x06000000 encountered  in io-pkt.
Jan 12 00:11:44    5    14     0 rum0: device timeout
Jan 12 00:11:49    5    14     0 USB error 0x06000000 encountered  in io-pkt.
Jan 12 00:11:57    5    14     0 rum0: could not multi read MAC register: NOMEM
Jan 12 00:13:34    5    14     0 rum0: could not multi read MAC register: NOMEM
Jan 12 00:13:51    5    14     0 USB error 0x06000000 encountered  in io-pkt.
Jan 12 00:27:40    5    14     0 rum0: timeout waiting for BBP/RF to wakeup
Jan 12 00:27:40    5    14     0 rum0: could not multi read MAC register: NO_ADDR
Jan 12 00:27:40    5    14     0 rum0: could not multi write MAC register: NO_ADDR
RE: USB WiFi hangs
What type of target platform are you on?  We have seen errors like that
when the target wasn't capable of supplying enough power to the dongle.
In those instances, we recommended plugging the dongle into a powered
USB hub and that usually fixed things.
   R.
From: Agoston Feher [mailto:community-noreply@qnx.com]
Sent: Tuesday, April 14, 2009 12:35 PM
To: drivers-networking
Subject: USB WiFi hangs
i have an issue with usb wifi connection i use io-pkt-v4-hc, the
wpa_supplicant, and i get ip address with dhcp everything seems fine but
hangs.
as i know. i also tried to limit the wifi speed by setting the mode and
results.
0x1723 matched.
MAC/BBP RT2573 (rev 0x2573a), RF RT2528, address 00:1b:fc:8f:ff:96
11Mbps
11Mbps 6Mbps 9Mbps 12Mbps 18Mbps 24Mbps 36Mbps 48Mbps 54Mbps
io-pkt.
io-pkt.
register: NOMEM
register: NOMEM
io-pkt.
wakeup
register: NO_ADDR
register: NO_ADDR
register: NO_ADDR
register: NO_ADDR
Networking Drivers
http://community.qnx.com/sf/go/post26946
Re: RE: USB WiFi hangs
Thank you for the fast response, it solved the problem
I have a similar problem. Bought a Belkin F5D7050, plugged into a powered hub and ran the following commands:
io-pkt-v4-hc -d /fs/hd1/lib/devnp-rum.so
wpa_supplicant -B -i rum0 -c /fs/hd1/etc/wpa_supplicant.conf
my conf file:
network={
ssid="mgtsciences"
key_mgmt=WPA-PSK
psk="abcdefghij"
ifconfig shows:
rum0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> mtu 1500
        ssid "" nwkey 65536:"","","",""
        powersave off
        address: 94:44:52:03:ad:89
        media: IEEE802.11 autoselect (DS1 mode 11g)
        status: no network
sloginfo shows:
Jan 16 08:39:59    5    14     0 USB device vendor 0x50d, device 0x705a matched.
Jan 16 08:39:59    5    14     0 rum0 at pci0 dev 0 function 0rum0: MAC/BBP RT2573 (rev 0x2573a), RF RT2528, address 94:
44:52:03:ad:89
Jan 16 08:39:59    5    14     0 ether_ifattach: rum0 null if_stop
Jan 16 08:39:59    5    14     0 rum0: 11b rates: 1Mbps 2Mbps 5.5Mbps 11Mbps
Jan 16 08:39:59    5    14     0 rum0: 11g rates: 1Mbps 2Mbps 5.5Mbps 11Mbps 6Mbps 9Mbps 12Mbps 18Mbps 24Mbps 36Mbps
48Mbps 54Mbps
Jan 16 08:42:46    5    14     0 USB error 0x06000000 encountered  in io-pkt.
Jan 16 08:42:51    5    14     0 USB error 0x06000000 encountered  in io-pkt.
Jan 16 08:43:03    5    14     0 USB error 0x06000000 encountered  in io-pkt.
Jan 16 08:43:08    5    14     0 USB error 0x06000000 encountered  in io-pkt.
Jan 16 08:43:20    5    14     0 USB error 0x06000000 encountered  in io-pkt.
Jan 16 08:43:31    5    14     0 USB error 0x06000000 encountered  in io-pkt.
Any ideas?
Todd
>    R.
> hangs.
> results.
> 0x1723 matched.
> 11Mbps
> io-pkt.
> io-pkt.
> register: NOMEM
> register: NOMEM
> io-pkt.
> Jan 12 00:27:40    5    14     0...
