Problem with configure MPC8313 MAC address
03/30/2009 6:53 AM
post25511
I am trying to configure the MAC address for MPC8313 target.
The BSP of MPC8313 use a fixed MAC address in the syspage, I have found two possible way to configure the MAC address we
specify, but none of them works properly.
1) io-pkt-v4-hc -d mpc85xx mac=00123456789a
2)ifconfig tsec0 link 00:12:34:56:78:9a active
after either of the configureation above, all the packet sending out by the target is correctly, but the target seems
get problem when pick up the reply packet.
For example:
A: windows XP (fresh rebooted), Wireshark to capture the communication paket, IP:192.168.3.254/24
B: our MPC8313 target, IP:192.168.3.151/24
When I ping from B to A:
B send out:
Summary:CamilleB_56:78:9a Broadcast ARP Who has 192.168.3.254? Tell 192.168.3.151
A reply:
Summary: Belkin_e7:77:eb CamilleB_56:78:9a ARP 192.168.3.254 is at 00:11:50:e7:77:eb
B send out:
A reply:
B send out:
A reply:
But B will never update it is arp table and get the MAC address of A.
when I use arp -a, and alway get:
# arp -a
? (192.168.3.254) at (incomplete) on tsec0
RE: Problem with configure MPC8313 MAC address
03/30/2009 9:09 AM
post25520
Your mac address looks fine to me.
From what information you have provided, it
looks like you can transmit packets, but not
receive them. If you run any of the below:
# nicinfo
# ifconfig -v
# netstat -p ip
you can confirm this. If in fact you are
simply not receiving any packets, I would look
at the hardware interrupt - either it's not
firing, or you're attached to the wrong one.
aboyd
Re: RE: Problem with configure MPC8313 MAC address
03/30/2009 9:24 AM
post25523
Hi Andrew:
the out put of "ifconfig -v" and "netstat -p ip"
ifconfig -v
input: 2 packets, 132 bytes
output: 2 packets, 132 bytes
tsec0: flags=8a43<UP,BROADCAST,RUNNING,ALLMULTI,SIMPLEX,MULTICAST> mtu 1500
capabilities tx=0
enabled=0
address: 00:12:34:56:78:9a
media: Ethernet none
input: 19 packets, 1064 bytes
output: 77 packets, 4168 bytes, 53 multicasts
inet 192.168.3.7 netmask 0xffffff00 broadcast 192.168.3.255
tsec1: flags=8a43<UP,BROADCAST,RUNNING,ALLMULTI,SIMPLEX,MULTICAST> mtu 1500
capabilities tx=0
enabled=0
address: 00:12:34:56:78:9b
output: 73 packets, 4000 bytes, 53 multicasts
inet 192.168.255.7 netmask 0xffffff00 broadcast 192.168.255.255
# netstat -p ip
ip:
42 total packets received
0 bad header checksums
0 with size smaller than minimum
0 with data size < data length
0 with length > max ip packet size
0 with header length < data size
0 with data length < header length
0 with bad options
0 with incorrect version number
0 fragments received
0 fragments dropped (dup or out of space)
0 fragments dropped (out of ipqent)
0 malformed fragments dropped
0 fragments dropped after timeout
0 packets reassembled ok
42 packets for this host
0 packets for unknown/unsupported protocol
32 packets forwarded (0 packets fast forwarded)
0 packets not forwardable
0 redirects sent
0 packets no matching gif found
48 packets sent from this host
80 packets sent with fabricated ip header
0 output packets dropped due to no bufs, etc.
10 output packets discarded due to no route
0 output datagrams fragmented
0 fragments created
0 datagrams that can't be fragmented
0 datagrams with bad address in header
I have tried to use "io-pkt-v4-hc -d mpc85xx syspage" to bring the tcp/ip stack and driver, and it works quite happy
until I use :
to override the MAC address, then it can send out the packets but can not recived packets any more.
But if I use ifconfig tsec0 link mac active to change the MAC address to the sameone write to the syspage, the ethernet
start to work again.
RE: RE: Problem with configure MPC8313 MAC address
03/30/2009 9:32 AM
post25526
> it works quite happy until I use :
> # ifconfig tsec0 link 00:12:34:56:78:9a active
Don't do that. If you want a specific mac address
for an interface, use the "mac=XXX" command line option
to the driver.
aboyd
03/30/2009 9:51 AM
post25533
> to the driver.
This should work though. I'll make a PR.
03/30/2009 9:54 AM
post25534
Sorry about that, Sean - I know you're incredibly
busy right now.
aboyd
03/30/2009 9:58 AM
post25535
> busy right now.
Never too busy for PRs :) 66857 has been created.
03/30/2009 10:10 AM
post25537
Slight tangent: many of our drivers have
"hard-coded" mac addresses (eg 00:11:22:33:44:55)
on hardware which does not have persistent hardware
memory to store a world-wide unique MAC address.
I realize that in such a circumstance, have a faked
up address such as the above is better than nothing -
or having the driver choose to terminate - but what
follows, for those still reading this, is a slightly
better receipe for a faked-up mac address.
Please feel free to distribute this code, and use it
in qnx network drivers that do not have a mac address
stored in hardware:
// set default mac address
uint64_t val = ClockCycles();
// 00 C0 0F is owned by QNX software (I bought it, back in the 1980s)
cfg->current_address[0] = 0x00;
cfg->current_address[1] = 0xC0;
cfg->current_address[2] = 0x0F;
// pseudo-random create the lower 3 bytes
cfg->current_address[3] = ((val >> 56) & 0xff) + ((val >> 48) & 0xff) +
((val >> 0) & 0xff);
cfg->current_address[4] = ((val >> 40) & 0xff) + ((val >> 32) & 0xff) +
((val >> 24) & 0xff);
cfg->current_address[5] = ((val >> 16) & 0xff) + ((val >> 8) & 0xff) +
aboyd www.pittspecials.com/movies/tumble.wmv
03/30/2009 10:18 AM
post25540
Are you sure that the problem is with the MAC address or does the driver
just not work if you don't specify syspage? It's possible that the PHY
address may also need to be specified for your board. If you want to
change the MAC, try specifying both the syspage and MAC options and see
if that works.
io-pkt-v4 -dmpc85xx syspage,mac=00123456789a,verbose
And see what sloginfo reports if it doesn't work.
R.
Sent: Monday, March 30, 2009 6:54 AM
To: drivers-networking
Subject: Problem with configure MPC8313 MAC address
two possible way to configure the MAC address we specify, but none of
1) io-pkt-v4-hc -d mpc85xx mac=00123456789a 2)ifconfig tsec0 link
the target is correctly, but the target seems get problem when pick up
the reply packet.
For example:
B send out:
A reply:
B send out:
A reply:
B send out:
A reply:
# arp -a
Networking Drivers
http://community.qnx.com/sf/go/post25511
03/30/2009 11:08 AM
post25550
Hi Craig:
I think you find the problem, after I compare the syslog I found when I have not specify the syspage, the Rx,Tx and Err
IRQ is incorrect.
I have capture one of nic start log as below:
1) with syspage specified
Jan 01 00:00:03 2 14 0 mpc85xx_attach(): IF 0: Base register 0xE0024000
Jan 01 00:00:03 2 14 0 mpc85xx_attach(): IF 0: IRQ Tx 37 Rx 36 Err 35
Jan 01 00:00:03 2 14 0 mpc85xx_attach(): IF 0: MAC 00:01:12:34:56:78
Jan 01 00:00:03 2 14 0 mpc85xx_attach(): IF 0: PHY address 0
Jan 01 00:00:03 5 14 0 MPC85XX TSEC
Jan 01 00:00:03 5 14 0 Vendor .............. 0x0
Jan 01 00:00:03 5 14 0 Device .............. 0x0
Jan 01 00:00:03 5 14 0 Revision ............ 0x0
Jan 01 00:00:03 5 14 0 Memory base ......... 0xe0024000
Jan 01 00:00:03 5 14 0 Interrupt ........... 0x25
Jan 01 00:00:03 5 14 0 Interrupt ........... 0x24
Jan 01 00:00:03 5 14 0 Interrupt ........... 0x23
Jan 01 00:00:03 5 14 0 MAC address ......... 001234 56789a
Jan 01 00:00:03 2 14 0 mpc85xx_attach(): eTsec: yes
2) without syspage specified.
Jan 01 00:00:03 5 14 0 Interrupt ........... 0xd
Jan 01 00:00:03 5 14 0 Interrupt ........... 0xe
Jan 01 00:00:03 5 14 0 Interrupt ........... 0x12
Now my question is:
How can I configure the interrupt address without specify the syspage, (I couldn't find any on http://www.qnx.com/
developers/docs/6.4.0/neutrino/utilities/d/devnp-mpc85xx.so.html)
Ji
> if that works.
> R.
03/30/2009 11:14 AM
post25552
Hi Ji:
The short answer is that you can't. There are no options to specify the
interrupts from the command line. If all that you want to do is change
the MAC, then you can either update the system page contents in the BSP
source (look in init_hwinfo.c for where the MAC is being set) or try
overriding the MAC address on the command line in combination with the
syspage option (and I can see from your nicinfo output that this worked
for you).
Robert.
Sent: Monday, March 30, 2009 11:09 AM
Subject: Re: RE: Problem with configure MPC8313 MAC address
Hi Craig:
have not specify the syspage, the Rx,Tx and Err IRQ is incorrect.
0xE0024000
Err 35
00:01:12:34:56:78
Now my question is:
http://www.qnx.com/developers/docs/6.4.0/neutrino/utilities/d/devnp-mpc8
5xx.so.html)
Ji
> driver just not work if you don't specify syspage? It's possible that
> the PHY address may also need to be specified for your board. If you
> want to change the MAC, try specifying both the syspage and MAC
> options and see if that works.
> R.
Networking Drivers
http://community.qnx.com/sf/go/post25550
Re: RE: RE: Problem with configure MPC8313 MAC address
03/30/2009 11:25 AM
post25555
Hi Robert:
What I am trying to do is: configure the MAC address which is read from EPROM though I2C driver.
Before I start QNX i2c driver, I can not get the MAC address, so I think I can't write the correct MAC address to the
syspage.
On our target, we have 2 NIC
if i use"io-pkt-v4-hc -d mpc85xx syspage,mac=00123456789a", both nic is confiugred to the same MAC address, is there any
way I can configure both NIC?
Ji
> Hi Ji:
> for you).
> Robert.
RE: RE: RE: Problem with configure MPC8313 MAC address
03/30/2009 11:28 AM
post25556
Hmmmm.... That's an interesting one.
There's a bug in there somewhere since the MAC address should be
incremented before being used by a second interface.
How about
io-pkt-v4 -dmpc85xx pci=0,syspage,mac=0x001122334455 -dmpc85xx
pci=1,syspage,max=0x001122334466
Robert.
Sent: Monday, March 30, 2009 11:26 AM
Subject: Re: RE: RE: Problem with configure MPC8313 MAC address
Hi Robert:
I can't write the correct MAC address to the syspage.
confiugred to the same MAC address, is there any way I can configure
both NIC?
Ji
> Hi Ji:
> the interrupts from the command line. If all that you want to do is
> change the MAC, then you can either update the system page contents in
> the BSP source (look in init_hwinfo.c for where the MAC is being set)
> or try overriding the MAC address on the command line in combination
> with the syspage option (and I can see from your nicinfo output that
> this worked for you).
> Robert.
Networking Drivers
http://community.qnx.com/sf/go/post25555
Re: RE: RE: RE: Problem with configure MPC8313 MAC address
03/30/2009 11:43 AM
post25561
Hi Robert:
I have tried and syslog is:
ouldn't initialize listen service: tcp (Address family not supported by protocol family)
If my understand is correct is pci=0/1 specify the PCI NIC location, actually the target is a MPC8313 based, have 2 on
board CPU, so I have changed the command line to:
io-pkt-v4-hc -dmpc85xx syspage,mac=00123456789a,phy_addr=0,etsec=0,verbose -dmpc85xx syspage,mac=00123456789b,phy_addr=1
,etsec=0,verbose &
now, there are 4 tsec device comes out first two have 00123456789a MAC address, and the other two have 00123456789b as its MAC address.
Ji
> How about
> Robert.
RE: RE: RE: RE: Problem with configure MPC8313 MAC address
03/30/2009 11:47 AM
post25562
Hi Ji:
In this case "pci" actually means "use only interface x" and
doesn't actually refer to PCI. It was a convenient (if confusing)
command line option to use.
Try the command line as specified first and see what it does. The way
that you've specified the command line is starting multiple drivers with
the same hardware so it won't work.
Robert.
Sent: Monday, March 30, 2009 11:44 AM
Subject: Re: RE: RE: RE: Problem with configure MPC8313 MAC address
Hi Robert:
protocol family)
actually the target is a MPC8313 based, have 2 on board CPU, so I have
syspage,mac=00123456789b,phy_addr=1,etsec=0,verbose &
Ji
> How about
> Robert.
Networking Drivers
http://community.qnx.com/sf/go/post25561
Re: RE: RE: RE: RE: Problem with configure MPC8313 MAC address
03/30/2009 12:09 PM
post25564
Hi Robert:
"io-pkt-v4-hc -dmpc85xx pci=0,syspage,mac=001122334455 -dmpc85xx"
can work as expected, will start the first NIC(phy address 0) and work.
then I tried to add the second in:
o-pkt-v4-hc -dmpc85xx pci=0,syspage,phy_addr=0,mac=001122334455 -dmpc85xx pci=1,syspage,phy_addr=1,max=001122334466
Jan 01 00:00:03 5 14 0 tcpip starting
Jan 01 00:00:03 3 14 0 Unable to attach to pci server: No such file or directory
Jan 01 00:00:03 3 14 0 Using pseudo random generator. See "random" option
Jan 01 00:00:03 5 14 0 initializing IPsec... done
Jan 01 00:00:03 5 14 0 IPsec: Initialized Security Association Processing.
Jan 01 00:00:03 5 14 0 MAC address ......... 001122 334455
Jan 01 00:00:03 2 14 0 mpc85xx_parse_options(): unknown option max=001122334466
Jan 01 00:00:03 2 14 0 Unable to init devnp-mpc85xx.so: Invalid argument
Jan 01 00:00:03 2 14 0 mpc85xx_init(): rx dma buffer size 2048 bytes
Jan 01 00:00:03 2 14 0 mpc85xx_init_phy(): media_rate: -1, duplex: -1, PHY: 0
Jan 01 00:00:03 2 14 0 mpc85xx_init_phy(): PHY found at address 0
Jan 01 00:00:03 2 14 0 mpc85xx->rx_cap_mask: 0x0
Jan 01 00:00:03 2 14 0 mpc85xx->tx_cap_mask: 0x0
Mar 30 16:00:57 5 14 0 mpc85xx_mii_callback(): link up lan 0 idx 0 (100 BaseT Full Duplex)
FYI:
1)without specify the syspage, the MAC address do add 1 for the second NIC, but with the syspage, both MAC address will
be the same
2) if I specify "io-pkt-v4-hc -dmpc85xx pci=0,syspage,phy_addr=1,mac=001122334455 -dmpc85xx"
will start phy address 1 NIC, but still use NIC 0's IRQ
Ji
> Hi Ji:
> Robert.
RE: RE: RE: RE: RE: Problem with configure MPC8313 MAC address
03/30/2009 12:11 PM
post25566
Hi Ji:
Two things. You have a typo in your command line for the second
interface (max vs. mac) and you shouldn't have to specify the phy
address since this is handled by the system page information.
R.
Sent: Monday, March 30, 2009 12:09 PM
Subject: Re: RE: RE: RE: RE: Problem with configure MPC8313 MAC address
Hi Robert:
file or directory
"random" option
Processing.
0xE0024000
Err 35
00:01:12:34:56:78
max=001122334466
Invalid argument
bytes
duplex: -1, PHY: 0
address 0
FYI:
NIC, but with the syspage, both MAC address will be the same
Ji
> Hi Ji:
doesn't
> actually refer to PCI. It was a convenient (if confusing) command
> line option to use.
> with the same hardware so it won't work.
> Robert.
Networking Drivers
http://community.qnx.com/sf/go/post25564
Re: RE: RE: RE: RE: RE: Problem with configure MPC8313 MAC address
03/30/2009 12:23 PM
post25571
Thanks Robert, it works like a dream........
> Hi Ji:
> R.
03/30/2009 12:12 PM
post25567
(And yes... I just noticed that the "max" was MY typo and not yours :>.
Sorry about that. )
R.
Hi Robert:
file or directory
"random" option
Processing.
0xE0024000
Err 35
00:01:12:34:56:78
max=001122334466
Invalid argument
bytes
duplex: -1, PHY: 0
address 0
FYI:
Ji
> Hi Ji:
doesn't
> line option to use.
> Robert.
Networking Drivers
