Forum Topic - Iopkt driver stops reading after six packets: (8 Items)
I need to write a simple native io-pkt driver. I started with the sample driver code that QNX posted and added a few
lines of code to display the messages coming in. This seemed to work okay. The data displayed looks correct, but after
reading six packets, it seems sam_start() stops being called. Do I need to do anything other than m_freem to free the
mbufs and NW_SIGUNLOCK_P, to let the driver know I am finished with a packet so the driver can keep receiving more? At
the moment all I want to do is see all the packets. I will worry about what I want to do with them later.
I attached the sample driver code with the changes I made to do this test.
The test was done on a Yosemite evaluation board with a 440EP processor.
I am mounting the driver with
mount -Tio-pkt devnp-sample.so
and then setting the ip address with
ifconfig sam0 xxx.xxx.xxx.xxx
at which point it displays six packets and stops.
A G
Attachment: Compressed file iopkt-sample.zip 8.61 KB
Re: Iopkt driver stops reading after six packets
I think 'm' below should be 'm2' but it probably wouldn't cause this
issue.
//Copy the fragment into the transmit buffer
      memcpy((sam->sc_pkt_buf)+len, m->m_data, m->m_len);
      len+=m2->m_len; //Move the pointer to then end of the data in the buffer
I don't see anything obvious.  Is the stack still responding
in general (localhost)?  Does the debugger show anything?
> issue.
You were right about that, I went through a few different iterations trying to track this down and that got lost in the
shuffle when I tried to create a test case with the sample driver to demonstrate the problem.
> -seanb
Pidin shows the same info before and after the mount
  364560   1 /boot/io-pkt-v6-hc  21r SIGWAITINFO
  364560   2 /boot/io-pkt-v6-hc  21r READY
  364560   3 /boot/io-pkt-v6-hc  21r RECEIVE     16
  364560   4 /boot/io-pkt-v6-hc  21r RECEIVE     20
The stack is still responding. If I have a telnet client connected while this is going on, it never stops working.
I did notice though, if I have an ftp client connected when I mount the sample driver, the ftp session will disconnect
after doing the mount. This even happens with the original sample driver code with no changes made to it whatsoever.
I can reconnect the ftp client, but after reconnecting, if I try to transfer a file, the transfer will fail, and the
client will disconnect again.
If I do an ifconfig sam0 destroy, I can transfer files with the ftp client again.
It seems this depends too, in whether or not data transfers have taken place. If the ftp client is just connected but I
haven't transferred anything, the connection doesn't get broken. I can move around, do directory listings, etc.. with no
 issues.
Even while the ftp client is having these issues, the telnet client has no problems at all.
Since you have verified I am not leaving anything out, I will try the debugger next to see if it will reveal any
additional information.
AG
>  driver, the ftp session will disconnect after doing the mount. This even
> whatsoever.
>  file, the transfer will fail, and the client will disconnect again.
> again.
I thought I would mention too that this isn't particularly repeatable. Sometimes the ftp session will stop responding
right away, sometimes it will keep working for awhile before it drops out. Sooner or later though, after loading the
sample driver, the ftp connection will always drop out. I don't understand why it doesn't always do it the same way each
 time, but then again, I don't understand why loading the sample driver would affect the ftp session at all, but it
definitely does.
AG
> > -seanb
More info
I wanted to see if the same behavior would occur on a different system. I wanted to take my environment, my image, my
hardware, out of the equation. To do this, I ran QNX in a QEMU virtual environment by directly booting the ISO image
qnxsdp-6.4.0-200810211530-nto.iso obtained from QNX.
After fixing the m2 error you mentioned, I compiled the same sample code attached at the beginning of this thread for
x86. I then transferred it to the virtual qnx environment running in Qemu. When I loaded the driver it ran, displayed
the 6 packets, and then it doesn't display any more.
> > > -seanb
> More info
I tried your version with the m2 fix and it seem to work fine for me.
What does a pidin show when it's stalled?
-seamb
I didn't have something configured properly. It is working for me as well now. Thank you for your help.
> -seanb
Would it be safe to make the assumption that if you compile and run this exact same sample driver that you don't see it
stop after reading six packets? You see it continually displaying packets to stdout. If this is true, it seems I should
be looking at something other than the driver code to identify the problem.
AG
