12/12/2008 1:32 AM
post18475
While we're on the subject of NetBSD compatibility...
I haven't done any thorough research into the following, so it's equally a question about where NetBSD is at.
In some "really modern" TCP/IP stacks, the window size is no longer something you "set" to some maximum value, but is a
range of values and it dynamically adjusts to whatever is necessary to assure good performance with the smallest
possible memory usage. Obviously, on some connections with large bandwidth * delay products, the only way to get good
performance is with a very large TCP windows.
Anyway, at a minimum, modern Linux and (ugh) Vista appear to do this, and I just assumed that NetBSD would also do so.
However... one thing I noticed over the years, even on 6.3.2, is that setting the TCP send or receive window size much
over 200k causes any connection to get an error. For example:
root@qdev:/root# sysctl -w net.inet.tcp.sendspace=233017
net.inet.tcp.sendspace: 233017 -> 233017
root@qdev:/root# telnet 1.2.3.4
Trying 1.2.3.4...
telnet: socket: No buffer space available
(Note: 233016 works.)
So anyway, I figured with all of this new NetBSD portability, this would certainly be fixed and we'd also have the fancy
new auto-dynamic stuff, but apparently, no such luck. The exact same thing happens on 6.4.0.
This is not a really terrible problem for us, but it would be nice to hear what the roadmap is for the NetBSD stack.
In our particular application, 99% of our TCP connections are relatively short range, so a small window works fine. But
we also have a few connections that go over the Internet and move a lot of data, and it takes a really long time unless
you have a pretty big TCP window.
For the time being, we just set it to 64k, but that's a compromise and the best is where the stack automatically figures
out what it needs.
lew
12/12/2008 9:10 AM
post18490
Hi Lew:
When you bump up the sendspace, the app tries to allocate a send buffer
that exceeds the default maximum. Luckily, this maximum is now a
run-time configurable setting.
# sysctl -w kern.sbmax=500000
This got telnet working for me again.
Robert
From: Lewis Donzis [mailto:community-noreply@qnx.com]
Sent: Friday, December 12, 2008 1:33 AM
To: drivers-networking
Subject: large TCP windows
something you "set" to some maximum value, but is a range of values and
performance with the smallest possible memory usage. Obviously, on some
good performance is with a very large TCP windows.
setting the TCP send or receive window size much over 200k causes any
Trying 1.2.3.4...
certainly be fixed and we'd also have the fancy new auto-dynamic stuff,
short range, so a small window works fine. But we also have a few
takes a really long time unless you have a pretty big TCP window.
the best is where the stack automatically figures out what it needs.
lew
Networking Drivers
http://community.qnx.com/sf/go/post18475
Re: RE: large TCP windows
12/13/2008 11:20 AM
post18572
Thanks, that helps.
What about the new "dynamic window stuff" (I'm not sure of the proper terminology)?
The nice thing about allocating the window dynamically is that for "nearby" connections, you don't waste a bunch of
memory, but for far-away connections, you still get good performance.
lew
RE: RE: large TCP windows
12/15/2008 5:44 PM
post18664
Hi Lew:
And THAT I'm not so sure of. Do you happen to have any web
sites that I can take a look at that describe what's being done? I take
it that it modifies the window size based on the RTT or something along
those lines?
Robert.
Sent: Saturday, December 13, 2008 11:21 AM
Subject: Re: RE: large TCP windows
Thanks, that helps.
terminology)?
"nearby" connections, you don't waste a bunch of memory, but for
lew
Networking Drivers
http://community.qnx.com/sf/go/post18572
Re: RE: RE: large TCP windows
12/17/2008 1:49 AM
post18794
I've been trying to get a handle on it myself. There are a number of keywords, like "dynamic right-sizing" that seem to
have something to do with it. Just by way of example, Ubuntu 6 did not have this capability and you had to tune the
window size the normal way. With Ubuntu 8, it works pretty much out of the box with auto-tuning. You can, however, set
various parameters that control the minimum and maximum window sizes as well as conditions under which "pressure" will
be applied to reduce the window size.
In addition, it appears to be widely understood that in the Microsoft world that, while up to XP you had normal control
of the window size, in Windows Vista, this automatic tuning is now performed. With Vista, you no longer need to tune
the window size and the myriad of tools for doing so under XP and prior no longer work.
Here are some links that may be related: http://www.csm.ornl.gov/~dunigan/netperf/auto.html
http://public.lanl.gov/radiant/pubs/hptcp/hpdc02-drs.pdf
http://woozle.org/~mfisk/papers/tcpwindow-lacsi.pdf
(Note the reference to the NetBSD stack in the first link.)
In short, I've been trying to find the "this is the way everyone is doing it" link/article, but so far, that's proving
elusive. There must be an explanation somewhere of what was put into the Linux stack, and Microsoft does have some
articles about the Vista stack.
lew
RE: RE: RE: large TCP windows
12/17/2008 2:44 PM
post18881
Hi Lew:
http://mail-index.netbsd.org/source-changes/1997/12/11/msg026916.html
Says that auto-tuning of a sort for the initial congestion window size
has been in there since 97.
http://netbsd.gw.com/cgi-bin/man-cgi?sysctl+7+NetBSD-current
Look for the "tcp.init_win" setting (and that value exists and is
settable in our stack). The default value is 0 so it should be doing
some sort of auto-tuning already.
There's also the socket buffer tuning which may be more in line with
what you're thinking of.
http://mail-index.netbsd.org/tech-net/2007/02/04/0006.html
http://mail-index.netbsd.org/current-users/2008/03/13/msg001361.html
http://mail-index.netbsd.org/tech-net/2007/12/06/0003.html
This didn't make it in to the 4.0 release that our implementation is
based on.
Robert.
Sent: Wednesday, December 17, 2008 1:49 AM
Subject: Re: RE: RE: large TCP windows
keywords, like "dynamic right-sizing" that seem to have something to do
and you had to tune the window size the normal way. With Ubuntu 8, it
set various parameters that control the minimum and maximum window sizes
as well as conditions under which "pressure" will be applied to reduce
the window size.
world that, while up to XP you had normal control of the window size, in
no longer need to tune the window size and the myriad of tools for doing
doing it" link/article, but so far, that's proving elusive. There must
Microsoft does have some articles about the Vista stack.
lew
Networking Drivers
http://community.qnx.com/sf/go/post18794
Re: RE: RE: RE: large TCP windows
12/20/2008 11:38 AM
post19099
Yes, that sure sounds like it. You set minimum and maximum boundaries and it automatically uses "the right amount of
memory" to optimize performance over a given connection.
So I suppose when the next TCP/IP stack refresh gets incorporated, it will make its way into QNX?
lew
12/20/2008 12:40 PM
post19101
No comments as to timing (it depends on when NetBSD pull it into their
release and then when we pull in the latest NetBSD code), but it will
end up in here eventually...
Robert.
Sent: Saturday, December 20, 2008 11:38 AM
Subject: Re: RE: RE: RE: large TCP windows
and it automatically uses "the right amount of memory" to optimize
lew
Networking Drivers
http://community.qnx.com/sf/go/post19099
