devn-rtl8169.so doesn't work with RTL8111C
07/28/2008 8:59 AM
post11136
I use a Gigabyte GA-MA78GM-S2H motherboard with onboard Realtek RTL8111C (pci -v see attachment). The io-net driver devn
-rtl8169.so starts with following error message: unable to init dll devn-rtl8169: No such device
# sloginfo
Jul 23 13:40:05 2 10 0 rtl8169: TBI mode not yet supported
Jul 23 13:40:05 2 10 0 devn-rtl8169: Failure, unable to detectMII (PHY) Interface.
Jul 23 13:40:05 2 10 0 devn-rtl8169: Failed rtl_hw_config().
Jul 23 13:40:05 2 10 0 devn-rtl8169: rtl_create_instance() failed for scanned vid: 0x10ec did: 0x8168 idx: 0x0
Jul 23 13:40:05 5 14 0 tcpip starting
Jul 23 13:40:05 3 14 0 Using pseudo random generator. See "random" option
But the driver works if I plug off the ethernet cable:
# sloginfo
Jul 28 14:54:24 5 10 0 rtl_FindPHY(): an_capable 0x8, force_advertise -1, media_rate -1, duplex -1
Jul 28 14:54:24 6 10 0 tcrval 3c000000
Jul 28 14:54:24 5 14 0 tcpip starting
Jul 28 14:54:24 3 14 0 Using pseudo random generator. See "random" option
The driver works too with another motherboard and RTL8111B.
RE: devn-rtl8169.so doesn't work with RTL8111C
08/11/2008 8:15 AM
post11614
Yes, this is currently not supported, as we don't have any hardware with a TBI interface.
From: Steffen Brühl [mailto:community-noreply@qnx.com]
Sent: Monday, July 28, 2008 8:59 AM
To: drivers-networking
Subject: devn-rtl8169.so doesn't work with RTL8111C
# sloginfo
# sloginfo
Networking Drivers
http://community.qnx.com/sf/go/post11136
Re: RE: devn-rtl8169.so doesn't work with RTL8111C
08/11/2008 10:10 AM
post11621
Hi Hugh,
thank you very much for your answer.
I think we use MII interface not TBI, because if I plug off the ethernet cable, start the driver and after that plug in
the ethernet cable the driver works with MII.
Best regards, Steffen
RE: RE: devn-rtl8169.so doesn't work with RTL8111C
08/11/2008 10:19 AM
post11622
Well for some reason the chip is reporting TBI mode, as seen in your sloginfo output, so that is why the driver is not
working. Why the chip doesn't report TBI mode when the cable is unplugged, I have no idea. I have attached a modified
driver that doesn't check for the TBI bit, so please try it and let me know if it works.
Thanks, Hugh.
Sent: Monday, August 11, 2008 10:10 AM
Subject: Re: RE: devn-rtl8169.so doesn't work with RTL8111C
Hi Hugh,
Networking Drivers
http://community.qnx.com/sf/go/post11621
Re: RE: RE: devn-rtl8169.so doesn't work with RTL8111C
08/11/2008 10:47 AM
post11629
The modified driver seems to work.
#sloginfo
Aug 11 16:41:51 6 10 0 tcrval 3f4000c0 - version c
Aug 11 16:41:51 5 10 0 rtl_FindPHY(): an_capable 0x8, force_advertise -1, media_rate -1, duplex -1
Aug 11 16:41:51 5 14 0 tcpip starting
Aug 11 16:41:51 3 14 0 Using pseudo random generator. See "random" option
Aug 11 16:41:52 5 14 0 tcpip starting
Aug 11 16:41:52 3 14 0 Using pseudo random generator. See "random" option
Aug 11 16:41:54 6 10 0 Phy Status 8b
Aug 11 16:41:54 5 10 0 devn-rtl8169: Link up (100 BaseT Full Duplex)
Thank you very much, Steffen
RE: RE: RE: devn-rtl8169.so doesn't work with RTL8111C
08/11/2008 10:49 AM
post11632
Great! Thanks, Hugh.
Sent: Monday, August 11, 2008 10:48 AM
Subject: Re: RE: RE: devn-rtl8169.so doesn't work with RTL8111C
#sloginfo
Networking Drivers
http://community.qnx.com/sf/go/post11629
Re: RE: RE: RE: devn-rtl8169.so doesn't work with RTL8111C
08/14/2008 4:39 AM
post11771
Hi Hugh,
the driver works with the RTL8111C now, but I have problems with RTL8111B. After a few minutes I got timeouts on my
ethernet connection.
But your experimental driver from the following topic works with RTL8111B:
http://community.qnx.com/sf/discussion/do/listPosts/projects.bsp/discussion.bsp.topc1322
Best regards,
Steffen
09/17/2008 7:53 PM
post13595
I have successfully used the modified driver with a Gigabyte GA-EP45-DS3 motherboard which has two RTL8111C interfaces.
However when I remove and then re-insert a network cable the 'nicinfo' command shows the current operation rate as 0 kb/
s half-duplex instead of the original 100.00 Mb/s full-duplex. I am starting io-net with the command 'io-net -d rtl8169
speed=100,duplex=1 -p tcpip -p qnet'.
RE: RE: RE: RE: devn-rtl8169.so doesn't work with RTL8111C
09/18/2008 8:10 AM
post13606
We will have to take a look at this.
From: Owen Marsh [mailto:community-noreply@qnx.com]
Sent: Wednesday, September 17, 2008 7:54 PM
Subject: Re: RE: RE: RE: devn-rtl8169.so doesn't work with RTL8111C
motherboard which has two RTL8111C interfaces. However when I remove and
operation rate as 0 kb/s half-duplex instead of the original 100.00 Mb/s
Networking Drivers
http://community.qnx.com/sf/go/post13595
Re: RE: RE: RE: RE: devn-rtl8169.so doesn't work with RTL8111C
01/12/2009 4:46 PM
post19911
Hi Hugh,
The driver devn-rtl8169.so was already included in QNX V6.3.0 SP3 released at end of 2007 as a stable version. May I
know what are the changes/improvement done in your experimental version?
We want to use the driver to drive a CPU card with RTL8111C chipset. Haven't got the hardware yet. But a bit worry when
I saw this post in forum. Do you think I can use devn-rtl8169.so in QNX V6.3.0 SP3 official release to drive RTL8111C?
Chengzhi
RE: RE: RE: RE: RE: devn-rtl8169.so doesn't work with RTL8111C
01/13/2009 7:51 AM
post19939
The only change to the driver was to comment out the code that checked
for a TBI interface. This was causing the driver to exit on the 8169C
chip.
From: chengzhi lu [mailto:community-noreply@qnx.com]
Sent: Monday, January 12, 2009 4:46 PM
Subject: Re: RE: RE: RE: RE: devn-rtl8169.so doesn't work with RTL8111C
Hi Hugh,
released at end of 2007 as a stable version. May I know what are the
Haven't got the hardware yet. But a bit worry when I saw this post in
Chengzhi
Networking Drivers
http://community.qnx.com/sf/go/post19911
Re: RE: RE: RE: RE: RE: devn-rtl8169.so doesn't work with RTL8111C
01/13/2009 11:55 PM
post20000
Hugh, thank you very much!
Re: devn-rtl8169.so doesn't work with RTL8111C
04/23/2009 10:35 AM
post27892
I have the same error but my QNX 4.25
The LAN controller used is Realtek RTL8111C-GR based on PCI-express 1X bus. There is no dedicated driver for QNX from
Realtek’s download site. QNX 4.25 should can detect Realtek LAN controller. From your error message” Net.rtl 8169:
Failure, unable to detected MII (PHY) interface. Net.rtl 8169: TBI mode not yet supported”,
I think it should be wrong identified controller. 8169 is PCI based controller.
Please i need the driver because the driver solution in this forum is for QNX 6
Thank You for your support
04/23/2009 10:39 AM
post27893
Here you go.
From: Gerard Pou [mailto:community-noreply@qnx.com]
Sent: Thursday, April 23, 2009 10:35 AM
Subject: Re: devn-rtl8169.so doesn't work with RTL8111C
bus. There is no dedicated driver for QNX from Realtek's download site.
message" Net.rtl 8169: Failure, unable to detected MII (PHY) interface.
Net.rtl 8169: TBI mode not yet supported",
controller.
for QNX 6
Networking Drivers
http://community.qnx.com/sf/go/post27892
05/04/2009 11:43 AM
post28636
It works perfectly!! Tank you very much! ^^
