Yona Shaposhnik(deleted)
Unable to load packet filter lsm
02/12/2020 8:48 AM
post120251
I'm trying to compile and load the simple packet filter from documentation (http://www.qnx.com/developers/docs/7.0.0/
index.html#com.qnx.doc.core_networking/topic/filtering_PF.html)
I use SDP 7.0 and RTOS vm on vmware also 7.0 version.
the code compiles successfully:
qcc -Wl,-E -Vgcc_ntox86 -c -Wp,-MMD,build/x86-release/src/filter_1.d,-MT,build/x86-release/src/filter_1.o -o build/x86-
release/src/filter_1.o -I /home/alexandr/qnx700/target/qnx7/usr/include/io-pkt/ -Wall -fmessage-length=0 -O2 -fPIC src/
filter_1.c
src/filter_1.c: In function 'deinit_module':
src/filter_1.c:67:16: warning: implicit declaration of function 'pfil_head_get' [-Wimplicit-function-declaration]
pfh_inet = pfil_head_get(PFIL_TYPE_AF, AF_INET);
src/filter_1.c:67:14: warning: assignment makes pointer from integer without a cast [-Wint-conversion]
src/filter_1.c:71:5: warning: implicit declaration of function 'pfil_remove_hook' [-Wimplicit-function-declaration]
pfil_remove_hook(input_hook, NULL, PFIL_IN | PFIL_WAITOK,
src/filter_1.c:75:14: warning: assignment makes pointer from integer without a cast [-Wint-conversion]
pfh_inet = pfil_head_get(PFIL_TYPE_IFNET, 0);
src/filter_1.c: In function 'pfil_entry':
src/filter_1.c:95:14: warning: assignment makes pointer from integer without a cast [-Wint-conversion]
src/filter_1.c:99:5: warning: implicit declaration of function 'pfil_add_hook' [-Wimplicit-function-declaration]
pfil_add_hook(input_hook, NULL, PFIL_IN | PFIL_WAITOK,
src/filter_1.c:104:14: warning: assignment makes pointer from integer without a cast [-Wint-conversion]
pfh_inet = pfil_head_get(PFIL_TYPE_IFNET,0);
qcc -Wl,-E -Vgcc_ntox86 -shared -o build/x86-release/libfilter_1.so build/x86-release/src/filter_1.o
but when I try to load my lsm:
# mount -vvv -Tio-pkt /root/lsm-filter.so
Parsed: mount from [/root/lsm-filter.so] mount on [NULL] type [io-pkt]
exec: mount_io-pkt -o rw -o implied -o nostat /root/lsm-filter.so /
Using internal mount (mount_io-pkt not found)
Type [io-pkt] Flags 0x80080000
Device [/root/lsm-filter.so] Directory [/]
Options [NULL]
mount: Can't mount / (type io-pkt)
mount: Possible reason: No such device or address
and in slog I can see only such line:
Feb 12 13:48:15.543 iopkt.81934 main_buffer 0 Unable to load /root/lsm-filter.so:
(null)
did anybody face such problem? could anybody help me with this?
