QNX7 devnp-e1000.so works for Intel Integrated I350 NIC for x86_64 but not x86_32
12/29/2017 4:26 PM
post118298
I made a bsp with the alpha qnx7 momentics and was able to get a x86_64 bsp to work with a Dell R720 and all it's pci
and integrated interfaces.
I tried to create a x86_32 bsp and the nic isn't compatible. Am I doing something wrong? I made sure to set the
stacksize to 4096 and made sure all of the 32bit architecture parameters were accounted for.
When I would run a ifconfig the bottom of the output would state ifconfig: link_status: ioctl: Bad Address
Along with nicinfo -v would output bad address next to dvcr_config and another attribute.
I am assuming that the x86_32 bit version of the e1000 driver is not compatible with the NIC.
Am I wrong in this assumption?
Thanks! Also if there is any additional information out there for building bsps I would appreciate the help. I have
pulled all the documentation from qnx and foundry but any additional info would be nice!
Re: QNX7 devnp-e1000.so works for Intel Integrated I350 NIC for x86_64 but not x86_32
01/02/2018 9:04 AM
post118301
Please try the attached 32-bit driver.
Thanks, Hugh.
pci and integrated interfaces.
Networking Drivers
http://community.qnx.com/sf/go/post118298
To cancel your subscription to this discussion, please e-mail drivers-networking-unsubscribe@community.qnx.com
01/03/2018 11:02 AM
post118309
So I tried using the driver you supplied but the result was the same. I am posting a picture of what I am seeing.
01/03/2018 11:45 AM
post118310
I have installed the 32-bit X86 BSP on my development machine, created a boot image and booted my PC with this image.
Both e1000 interfaces on my PC work fine with the 32-bit driver. Are you sure that you are not mixing 32 and 64-bit
executables?
Networking Drivers
http://community.qnx.com/sf/go/post118309
01/03/2018 11:55 AM
post118311
I am fairly certain I am using only 32 bit executables.
Do you mind sharing your build file for me to compare. To make sure that I am not accidentally forgetting something?
I appreciate it!
01/03/2018 11:58 AM
post118312
Also I am using the io-pkt-v4-hc driver instead of the io-pkt-v6-hc driver
01/03/2018 12:04 PM
post118314
You should only use the io-pkt-v6-hc driver with SDP7.
Networking Drivers
http://community.qnx.com/sf/go/post118312
01/03/2018 12:19 PM
post118315
I guess what is the difference between io-pkt-v4-hc and io-pkt-v6-hc?
In the alpha of SDP7 I was able to use io-pkt-v4-hc in the x86_64 bit version?
RE: QNX7 devnp-e1000.so works for Intel Integrated I350 NIC for x86_64 but not x86_32
01/03/2018 12:56 PM
post118317
Both io-pkt-v4-hc and io-pkt-v6-hc are supported on both 32bit & 64bit targets in SDP7.
You should not use io-pkt-v4 in SDP7.
For your e1000 issue, check the pci-server configuration -- there may be a base address missing from your build file.
'pci -v' output may help troubleshoot this.
regards,
Dean.
Sent: Wednesday, January 03, 2018 12:19 PM
To: drivers-networking
Subject: Re: QNX7 devnp-e1000.so works for Intel Integrated I350 NIC for x86_64 but not x86_32
Networking Drivers
http://community.qnx.com/sf/go/post118315
Re: RE: QNX7 devnp-e1000.so works for Intel Integrated I350 NIC for x86_64 but not x86_32
01/03/2018 1:34 PM
post118319
Hello Dean,
Can you elaborate what you mean the base address is missing in my build file?
Scott
RE: RE: QNX7 devnp-e1000.so works for Intel Integrated I350 NIC for x86_64 but not x86_32
01/03/2018 1:58 PM
post118322
should be "device id" not "base address" -- the output from "pci" or "pci -v" should indicate the device ID of your NIC,
I usually see them defined in the "net-start.sh" script in the build file.
Sent: Wednesday, January 03, 2018 1:34 PM
Subject: Re: RE: QNX7 devnp-e1000.so works for Intel Integrated I350 NIC for x86_64 but not x86_32
Hello Dean,
Scott
Networking Drivers
http://community.qnx.com/sf/go/post118319
01/03/2018 1:11 PM
post118318
io-pkt-v4-hc was dropped from the official release of SDP7, so only io-pkt-v6-hc is supported.
Networking Drivers
01/03/2018 12:04 PM
post118313
I have attached my build file.
I appreciate it!
Networking Drivers
http://community.qnx.com/sf/go/post118311
01/03/2018 1:37 PM
post118320
Hello Hugh,
So I took your build image and created an image from it and included the 32 bit e1000 driver as well.
I get the same results as before. Is there something wrong with the BSP that I downloaded from QNX.
Also there shouldn't be any issues if I am running the image as a virtual image via a DRAC console correct? It treats it
as if it were a disk image on a harddrive so i figure there shouldn't be any issues from this.
Scott
01/03/2018 1:40 PM
post118321
This sounds as though there could be an incompatibility issue with your virtual machine. I ran on a native PC. The BSP
that you downloaded from QNX should be OK, but to be on the safe side, you should be running the official release of
SDP7.
Hugh.
On 2018-01-03, 1:16 PM, "Scott Poulin" <community-noreply@qnx.com> wrote:
Hello Hugh,
treats it as if it were a disk image on a harddrive so i figure there shouldn't be any issues from this.
Scott
Networking Drivers
http://community.qnx.com/sf/go/post118320
01/03/2018 3:03 PM
post118323
So I went and wrote the image to a harddrive and booted from the harddrive. I achieved the same results as before. I
checked the pci-tool and it shows the nic is there. For some reason, there is still a compatibility issue with the
integrated nic x540/i350
I ran the ixgbe for the x540 and e1000 for i350.
I even used the did and vid when starting the driver.
01/03/2018 3:05 PM
post118324
Does the problem occur with both the x540 and i350? If so, then this isn’t a driver problem. Have you updated to the
official SDP7 release?
Networking Drivers
http://community.qnx.com/sf/go/post118323
01/03/2018 3:17 PM
post118325
It occurs for both the x540 and i350 only on 32bit. I have not tried the x540 for 64bit, but I know the i350 works for
the 64bit using the e1000 driver and io-pkt-v4-hc.
I believe the SDP I am using is the official release of QNX7.
01/03/2018 3:21 PM
post118326
I have attached my boot image to this email. Please can you try it?
Thanks, Hugh.
for the 64bit using the e1000 driver and io-pkt-v4-hc.
Networking Drivers
http://community.qnx.com/sf/go/post118325
01/03/2018 5:07 PM
post118327
Hugh,
I built an image from the binary you sent me and I am getting the same result. When the image boots it actually doesn't
start the network driver. When I start the network driver it gives me the same result as before. I did notice something
odd and I think it may be something with pci-server or when I create the image.(Not sure yet)
But when I go to cat the pcidatabase.com-tab_delimited.txt file it throws a bad address.
Attached is the cat of the pcidatabase.com-tab_delimited.txt file.
Scott
01/04/2018 8:27 AM
post118331
Scott,
Do all commands on your system fail under 32-bit, or only some of them? Do you see any errors on the screen while
booting the system? Does USB work?
Please can you send me the output from “pidin in” and “pidin arg”. Can you run “ls –lR /” to see if the file
system recurses?
I’m trying to figure out why 32-bit isn’t working, but 64-bit is.
Thanks, Hugh.
On 2018-01-03, 4:46 PM, "Scott Poulin" <community-noreply@qnx.com> wrote:
Hugh,
doesn't start the network driver. When I start the network driver it gives me the same result as before. I did notice
something odd and I think it may be something with pci-server or when I create the image.(Not sure yet)
Scott
Networking Drivers
http://community.qnx.com/sf/go/post118327
01/04/2018 9:57 AM
post118332
I wonder why there are no compatibility libs available for running 32bit
drivers within a 64bit environment and vs.
Please explain ..
Armin
Hugh Brown schrieb:
> Scott,
> Please can you send me the output from âpidin inâ and âpidin argâ. Can you run âls âlR /
â to see if the file system recurses?
> Iâm trying to figure out why 32-bit isnât working, but 64-bit is.
> Thanks, Hugh.
> Hugh,
> Thanks,
> Scott
> Networking Drivers
> Networking Drivers
> http://community.qnx.com/sf/go/post118331
01/04/2018 10:14 AM
post118333
Hugh,
When it loads I don't see any errors. Everything works as it should. I am able to run a pidin in, pidin arg, and ls -lR
without any errors.
The only error I see is when I run the ifconfig and nicinfo -v pertaining to the bad address of the nics.
The first image is the pidin in
second image is pidin arg
01/04/2018 10:38 AM
post118334
Scott,
Are you able to insert a USB stick into the machine and mount it? Please let me know, as I would like to capture more
information, rather than screen shots.
Thanks, Hugh.
On 2018-01-04, 9:53 AM, "Scott Poulin" <community-noreply@qnx.com> wrote:
Hugh,
-lR without any errors.
Networking Drivers
http://community.qnx.com/sf/go/post118333
01/05/2018 2:57 PM
post118337
Hey Hugh, it appears that I am able to mount a usb drive and there doesn't appear to be issues there. I happen to be
going through the slog2info and found the attached error. It looks like that there is an issue with the pci_cap-0x10 or
pci_cap-0x11
it states that pci_log says that the pci_cap-0x10 file can't be found for my nics.
I also tested this image an alternate server. It was a different model/make server, but it was able to boot the image
and use the nic and io-blk drivers.
So from the image provided, is there an issue with the NIC and driver compatibility?
Scott
01/05/2018 2:59 PM
post118338
Also there is an error appearing in the slog2info with the dlopen_mod(), dlopen()
it is stating Library cannot be found?
01/18/2018 10:07 AM
post118402
It's in general not a good idea to use a 32bit driver within a 64bit
environment. Other operating systems are providing 32bit libs for that
purpose. What about QNX 7.0 ??
Armin
> Networking Drivers
> http://community.qnx.com/sf/go/post118338
01/18/2018 10:26 AM
post118403
Hello Armin,
I'm not using a 32bit Driver with the 64bit environment. I am using the 32bit driver with the 32bit environment.
The problem is that the 32bit driver in a 32bit environment does not work on a Dell R720 server, but that same server is
able to run the 64bit drivers and environment with no issues.
Some would say, just use the 64bit environment then. My response to them is that I have a requirement to use the 32bit
architecture.
My images are all created using QNX 7.0 standard images that came with QNX 7.0 Momentics.
This is my QNX Version 7.0.0.v201705161739
Scott
01/05/2018 3:11 PM
post118339
Scott,
Don’t worry about the pci_cap-0x10, but you should have one for pci_cap-0x11 as this is MSIX.
Now that you can mount a USB stick, can you please do the following:
pidin in > /path_to_usb/file
pci-tool –vv >> /path_to_usb/file
use –i /proc/boot/* >> /path_to_usb/file
pidin arg >> /path_to_usb/file
Please send me “file” from the USB stick.
Thanks, Hugh.
pci_cap-0x11
image and use the nic and io-blk drivers.
Scott
Networking Drivers
http://community.qnx.com/sf/go/post118337
