Re: connection to socket is failing with error "connection refused" after ASIX ethernet driver insertion
09/19/2017 6:25 AM
post118048
Thank you Nick for your reply.
Let me simplify the problem statement further,
- I've an application (say XXX), it receives commands over socket from outside, then it sends then to another internal
application (say YYY).
- for XXX, we need ethernet driver. We're starting that in SOCK=/alt3
- for YYY, we need wi-fi driver. We're starting that in SOCK=/alt2
Now, I'm able to receive commands from outside in XXX, but it is not able to connect over tcp6 socket to YYY.
((connect system call fails with error "connection refused"))
So question is, how to make two application running in different context talk to each other over tcp socket.
