Is there any change for the interface between io-pkt and wlan driver in SDP700
06/28/2016 6:14 AM
post116490
The following codes work well in SDP600, but there are random crash happen in io-pkt in SDP700.
so is there any interface change between io-pkt and wlan driver in SDP700?
struct do_rtmsg_s {
int dr_what;
struct ifnet *dr_ifp;
void *dr_ptr;
size_t dr_len;
struct stk_callback dr_cb;
static void reset_mtu_to_default_on_disassociate(int what, struct ifnet *ifp)
if ((RTM_IEEE80211_DISASSOC == what) && (NULL != ifp)) {
ifp->if_mtu = ETHERMTU;
static void do_rtmsg(void *arg)
struct do_rtmsg_s *dr;
dr = arg;
reset_mtu_to_default_on_disassociate(dr->dr_what, dr->dr_ifp);
rt_ieee80211msg(dr->dr_ifp, dr->dr_what, dr->dr_ptr, dr->dr_len);
if (dr->dr_ptr)
free(dr->dr_ptr, M_TEMP);
free(dr, M_TEMP);
void do_rtfromstack(struct ifnet *ifp, int what, void *data, size_t data_len)
* Dirty little hack for PR 347908.
* Currently there is an implicit assumption that data pointer is not NULL
* within rt_ieee80211msg() due to an assertion deep within m_copyback0().
* Using a temporary buffer to workaround this issue for now while a better
* solution is proposed.
int temp;
if (NULL == data) {
data = &temp;
data_len = sizeof(temp);
if (!ISIRUPT) {
reset_mtu_to_default_on_disassociate(what, ifp);
rt_ieee80211msg(ifp, what, data, data_len);
} else {
hddLog(VOS_TRACE_LEVEL_INFO, "%s: RTM Event:%d for ifname:%s",
__func__, what, ifp->if_xname);
dr = malloc(sizeof(*dr), M_TEMP, M_NOWAIT);
if (dr == NULL) {
hddLog(VOS_TRACE_LEVEL_ERROR, "%s: No Memory",
__func__);
return;
dr->dr_what = what;
dr->dr_ifp = ifp;
dr->dr_ptr = NULL;
dr->dr_len = 0;
if (data) {
dr->dr_ptr = malloc(data_len, M_TEMP, M_NOWAIT);
if (dr->dr_ptr == NULL) {
free(dr, M_TEMP);
hddLog(VOS_TRACE_LEVEL_ERROR, "%s: No Memory for dr_ptr",
__func__);
return;
memcpy(dr->dr_ptr, data, data_len);
dr->dr_len = data_len;
dr->dr_cb.func = do_rtmsg;
dr->dr_cb.arg = dr;
MsgSendPulse(stk_ctl.coid, -1, NW_DEF_PULSE_CODE_CALLBACK,
(intptr_t)&dr->dr_cb);
thanks
- wenbin
