Re: Ethernet driver hangs?
05/05/2008 11:28 AM
post7671
On Fri, May 02, 2008 at 05:12:18PM -0400, Tim Gessner wrote:
> I have an x86 board with two 10/100/1000 ports using RealTek 8169 chipsets. I'm using a driver for the RealTek 8111
family.
> Everything seems to work fine until...
> I have the two ports on different subnets and I put the system under heavy load.
> A common problem is that the second port will lose its IP address. I set it again using ifconfig. After a short
period of time under load the ports stop transmitting. Both ports stop.
> Both ports show that they are up and still have their IP Address. The only thing interesting is that ifconfig flags
returns OACTIVE after they are hung. This flag does not appear when they are working. I have to reboot to get things
working again (I could probably unload and reload the drivers, just haven't bothered yet.)
> Anyone seen this problem before? Does it sound like a problem with the driver or ???
> I'm looking for suggestions on how to proceed.
The tx side of the driver is probably stuck. If ping
returns ENOBUFS that's another indication. Anything
in the sloginfo?
05/07/2008 5:42 PM
post7844
Any suggestions on how to track down the problem?
Thanx
Tim
