Multicast not working on QNX 6.6.0 (on ARMv7 Zezboard)
03/18/2015 11:57 PM
post113570
Hi folks :)
We have an interesting problem. We have in our lab two ARMv7 boards running the same binaries. One is the Freescale
sabre lite and the other one is the Zedboard.
The two boards are in the same subnet.
We have been doing multicast tests between each of these two boards, and other boards in the same sabnet (some i86QNX,
some i86Linux).
The only one not working and not communicating via multicast is the zedboard. The libraries and sofwtare we use in the
Zedboard is exactly the same as the one we run on the sabre lite. We use the same binaries, however they work on sabre
lite and they dont in the zedboard.
Now, this is the sabre lite network configuration:
$ ifconfig
inet6 ::1 prefixlen 128
inet6 fe80::1%lo0 prefixlen 64 scopeid 0x1
fec0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> mtu 1500
address: 00:19:b8:01:61:e6
media: Ethernet autoselect (1000baseT full-duplex,rxpause,txpause)
status: active
inet 10.10.65.17 netmask 0xffff0000 broadcast 10.10.255.255
inet6 fe80::219:b8ff:fe01:61e6%fec0 prefixlen 64 scopeid 0x11
And this is the Zedboard network configuration:
xzynq0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> mtu 1500
address: 00:0a:35:11:00:01
media: Ethernet autoselect (1000baseT full-duplex)
status: active
inet 10.10.65.13 netmask 0xffff0000 broadcast 10.10.255.255
inet6 fe80::20a:35ff:fe11:1%xzynq0 prefixlen 64 scopeid 0x11
The only difference that I see is "rxpause,txpause".
Can you see what might be the problem here? Unicast data works just fine, it is just multicast packets somehow not going
out/in from/to the interface.
Could this be a QNX driver issue for the zedboard rather than a board issue?
Thanks a lot for any insight you might provide :)
Thank you!
