Forum Topic - Problems using imx FEC: (3 Items)
I am having some difficulty setting up an ip stack on our platform which uses QNX running on an imx controller. I have
read through all the documentation I can find on the QNX web pages regarding the ip stack as I was unfamiliar with it.
What I now understand is that I need to load the QNX supplied driver for the imx FEC. I am using….
  io-pkt-v4 -d mx53 mac=xxxxxxxxxxxx
With ifconfig I get…
  fec0: flags=802<BROADCAST,SIMPLEX> mtu 1500
  address: xx:xx:xx:xx:xx:xx
                media: Ethernet none
When I connect a cable between my PC and our platform the LAN connection reports “connected”. This possibly indicates
that the HW is working ok.
The next step is to assign a static ip address to this interface. I try…
                ifconfig fec0 192.168.128.161
This hangs. It looks like the imx has stopped so I am assuming, maybe incorrectly, that the driver is the cause of this.
I tried:
  if_up -p fec0
which has exit status of 0 which means the interface is present but not necessarily configured.
  if_up -a fec0
returns  "if_up: retries exhausted" with exit status 7
No sure exactly what the 7 means but this implies that the interface is not configured.
Any ideas what I am missing in configuring the interface? On the same platform the asix driver for usb dongle is working
 fine.
What functions in the driver are called as a result of the ifconfig command? I couldn’t find this information on the
QNX support pages. With this I could attempt to debug the problem.
I am also wondering if my setup is missing something. Do I need to run anything else? Are there any tools that would
help diagnose the problem?
Unfortunately I am new to the finer details of networking and am learning as I go so any useful information would be
appreciated.
Simon
Re: Problems using imx FEC
A bit more info...
with:
#io-pkt-v4 -d mx53 mac=00049fcc9ab5
mx51_attach(): IF 0: Base register 0x63FEC000
mx51_attach(): IF 0: IRQ 87
Which looks ok.
sloginfo...
Jan 01 00:00:09    5    14     0 IMX 51 FEC
Jan 01 00:00:09    5    14     0 Vendor .............. 0x0
Jan 01 00:00:09    5    14     0 Device .............. 0x0
Jan 01 00:00:09    5    14     0 Revision ............ 0x0
Jan 01 00:00:09    5    14     0 Memory base ......... 0x63fec000
Jan 01 00:00:09    5    14     0 Interrupt ........... 0x57
Jan 01 00:00:09    5    14     0 MAC address ......... 00049f cc9ab5
Not sure about the 0x0 - guess they are not set.
Then attempt
# nicinfo fec0
fec0:
  IMX 51 FEC Ethernet Controller
and it hangs!
I guess this is something serious :-(
Any thoughts?
Simon
Now able to use the tools ok.
The reads and writes to the FEC registers were failing. This was becasue the FEC clock had been disabled.
Simon
