Forum Topic - Could not recognize R40 network device en0 under qnx 6.2.1 : (6 Items)
I install qnx 6.2.1 on the R40 laptop. It is okay to have wired ethernet network under windows, but it could not find
the network device en0 under qnx. what's the reason?
And which driver does the R40's network adapter(intel PRO/100 VE ) use under qnx 6.2.1?
Thank u.
RE: Could not recognize R40 network device en0 under qnx 6.2.1
The Intel PRO/100 uses the devn-speedo.so driver. Please post the output
from 'pci -v', so I can see what chip you have.
Sent: Tuesday, March 25, 2008 7:21 AM
To: drivers-networking
Subject: Could not recognize R40 network device en0 under qnx 6.2.1
network under windows, but it could not find the network device en0 under
qnx 6.2.1?
Thank u.
Networking Drivers
http://community.qnx.com/sf/go/post6084
Re: RE: Could not recognize R40 network device en0 under qnx 6.2.1
I used "io-net -d speedo -p tcpip", it said that no such device.
For the pci -v output, the network had 2 parts:
Class = Network(Unknown)
Vendor ID = 8086h, Intel Corporation
Device ID = 1043h, Unknown Unknown
Class = Network(Ethernet)
Device ID = 103dh, Unknown Unknown
So what shall i do next?
> From: Alex Doherty [mailto:dohertytek@gmail.com]
> qnx 6.2.1?
> Thank u.
> Networking Drivers
RE: RE: Could not recognize R40 network device en0 under qnx 6.2. 1
The first device ID is a wireless adapter, so that will not work. The second
device ID is a speedo chip, but it is not in the 6.2.1 driver. Try starting
the driver as follows:
io-net -dspeedo vid=0x8086,did=0x103d -ptcpip
See if that works.
Sent: Tuesday, March 25, 2008 9:10 AM
Subject: Re: RE: Could not recognize R40 network device en0 under qnx 6.2.1
under
> qnx 6.2.1?
> Thank u.
> Networking Drivers
Networking Drivers
http://community.qnx.com/sf/go/post6090
Re: RE: RE: Could not recognize R40 network device en0 under qnx 6.2.
Thank u, Hugh. It works now!
So why do i need to specify the vid and did here? Not specific enough only with the speedo driver?
> See if that works.
> under
> > qnx 6.2.1?
> > Thank u.
> > Networking Drivers
> Networking Drivers
RE: RE: RE: Could not recognize R40 network device en0 under qnx 6.2.
All PCI network drivers have a list of support PCI device IDs, which we
update from time to time. The device ID that you have is a later device ID
which did not make it into the 6.2.1 driver.
Sent: Tuesday, March 25, 2008 9:33 AM
Subject: Re: RE: RE: Could not recognize R40 network device en0 under qnx
6.2.
second
starting
> See if that works.
6.2.1
under
> under
> > qnx 6.2.1?
> > Thank u.
> > Networking Drivers
> Networking Drivers
Networking Drivers
http://community.qnx.com/sf/go/post6093
